Question about Garden
Ryobi, 31cc, 2-cycle Roto-tiller, MTD-21A-121R900
The engine assembly has vibrated off from the shaft that turns the tiller's tines. I need a schematic and parts list with cost. Please help.
  • Anonymous Apr 02, 2009
    tiller blades don't turn
  • jim7542 Apr 23, 2009
    how do you take a flywheel off a rototiller troybilt 6hp I chaged plug and still not getting enough spark
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
SOURCE: tines wont turn
Without really knowing what is broken it will be tough to give a firm idea of the cost. However, you can head over to www.partstree.com. They have a great detailed parts break down and costs associated with it. Looked up your part numer and can find at this link: http://www.partstree.com/parts/?lc=mtd&mn=210-031-000+%281990%29
Posted on May 07, 2009
  • 221 Answers
SOURCE: MTD series 410 rear tine tiller drive wheels slip
I have the same issue with one I am working on. It appears the keys in the drive shaft are not rotating far enough out on the drive gear side to fully engage in the gear. I have studied and studied this and so far I have been unable to determine why. If I find out I will let you know. I am also trying to figure out what is supposed to pull these keys out of the till engagement gear.
Posted on May 14, 2010
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
  • 221 Answers
SOURCE: MTD Series 410 rear tine tiller. Tines won't engage.
As much as I hate to admit it, I have one in my shop I have been working on for a friend. Like ehertig_cwc shows in his picture of the shifter forks they can and do bend. The part i hate to admit is I have been unable to fix this one. Yeah, the shifter forks were bent and the pins worn to nothing. I repaired that and put it back together and I'm sure some of you how long that takes. It worked for about 20 minutes and I lost all shift detents. I have studied and studied that drive shaft shifter section and for the life of me I have been unable to determine what keeps the dang detent ball from rotating and getting into the shafts keyed section. As soon as it does, you loose or soon will loose shifting as the clutch just floats around in there. I have two MTD service manuals and neither on shows this drive shaft apart or how to assemble it. I think it is magic how it works. Other than this part I find the gearbox pretty easy to work on.
Posted on Jun 30, 2010
Yard Machine Model 21a-121r900 tiller's pull starter recoil pully slipping
Bend the ears on the flywheel so that they are 90degrees. They are not lining up right.
Feb 16, 2013 | Mtd Garden
I have a Yard Machrines by MTD Yard & Garden Cultivator 31cc: Model No.21A-121R900 Ser.No.1A246DG1150 and I need to replace the primer bulb. How do I do that?
hello l, how to change primmer bulb,,remove the two fuel lines making note which line came off where,use needle nose pliers to push the two ears down and pull bulb out,make note on where the long and short stem was at,go to the mower shop and get a new bulb and install,put lines back on, done start engine,,hope this helps,,
Jan 27, 2012 | Yard Machines Cultivator
TROYBILT BRONCO REAR TINE TILLER Model#21A643B066...HOW DO I CHANGE MY ENGINE OIL?...WHERE IS THE DRAIN PLUG LOCATED?
The drain plug is generally located on either side of the engine near where the block bolts to the frame of the tiller. It can be a square headed plug or an allen socket head plug.
Feb 12, 2011 | Mtd 21a 643b066 Bronco Rear Tine Tiller
I need a diagram for Yard Machines; garden cultivator; 31cc
Here is a parts breakdown for your machine (found under MTD) with parts listings, diagrams and prices.
http://www.partstree.com/parts/?lc=MTD&mn=21A-121R900
Nov 24, 2010 | Yard Machines Cultivator
Mtd rear tines tiller won't engage tines. F and R
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Tines won't turn
Possible broken key where crankshaft meets gearbox.
May 15, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
I need a manual for my MTD Huskee 5hp rear tine tiller. Model # 21A 410 131. Briggs and Stratton motor. 18'' tilling width.
Apr 13, 2009 | Mtd Garden
We have a mtd yard machine roto tiller model 21A-340-06295208
i need a part list for a tiller model 21a
Mar 28, 2009 | Mtd Garden
HELP WITH A HUSKEE TILLER #21A-340-131
The pdf manual can be found at mtdproducts.com. You need to know your model and serial number to access the download. Really not that good a manual.
Mar 23, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
Garden Logo
2,522 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
