Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
After taking out the filter basket and all the moveable parts, how do you clean the coffee maker itself?
  • 8,596 Answers
You actually have to put the parts back in place (except the charcoal water filter and any paper filter you may or may not be using), pour in 2 cups distilled white vinegar and two cups water, and brew the vinegar/water solution just like it was coffee. Vinegar is very acrid, so you will then need to brew plain water to flush out the vinegar. Now, you can put everything back in place, and you are good to go. Remember - if one part is out of place, your coffee maker may beep at you incessantly.
-Tha Mp3 Doctor (also loves Cuisinart)
Posted on Feb 21, 2009
How do I stop the oily residue in my brewd cup of coffee? The coffee maker is new. The residue is not from our filtered water.
Thoroughly wash the pot and the basket with a good oil/grease remover (detergent) such as DAWN dishwashing liquid.
Then run White Vineger/Water (50/50) mix through the coffee maker TWICE, with the basket and pot in place. (NO coffee, nothing in the basket)
DO NOT RUN any detergent or soap through the coffeemaker at any time.
Then, run straight water through the coffee maker TWICE (no coffee, basket empty)
Then wash the pot and basket out AGAIN with a good detergent.
This will remove any residue that is in the coffeeemaker from the factory.
As coffee brews, there IS a slight amount of oil that is produced. The coffee itself has oils in it, and is part of its flavor, and freshly brewed coffee will have a slight oil residue.
Jun 24, 2011 | Rival Coffee Makers & Espresso Machines
Will not process the water to make coffee
the coffe maker might be clogged up so here' what to do: Look through the clear plastic panel on the side of the coffee maker's water tank to make sure that it has water in it.
  • Clean your Sunbeam coffee maker, You can wash the removable filter basket and carafe in hot, soapy water and pour 4 cups of white vinegar into the water reservoir of your coffee maker. Start the brewing cycle with no coffee grounds to allow the vinegar to clean the inside of the coffee maker. Rinse away the vinegar by running the brewing cycle twice with only clean, fresh water.
  • 8 Check the removable filter basket to see if the filter has collapsed if you find coffee grounds in your brewed coffee. If the paper filters collapse often you can wet them before you place them inside the filter basket so that they will stick to the basket and stay in place. or check this link because it might need a new hose. Coffeemaker Sparepartswww.coffeemaker-spareparts.
  • Jun 12, 2011 | Sunbeam COFFEEMAKER 10C BLACK DR13
    Water not filtering quick enough, basket overflows
    Make sure your sprayhead is the proper one (5 hole) and in good shape. Also make sure that the hole on your filter basket has not been partially closed. This can happen if you set it on the hot warmer. As a last resort, you can slightly enlarge the hole in your filter basket.
    Apr 28, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
    Bunn Coffee Filter Basket Tray Broken
    If you will contact Customer Service at 800-263-2256 with the model and date code, they will be happy to help you. The tray assembling itself is not replaceable but the machine does carry a 3 year warranty.
    Oct 12, 2009 | Bunn NHB Coffee Maker
    How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
    From the manual I found online here.
    CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
    DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
    Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    I have a grind and brew and can't get the grinding basket out to wash.
    Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
    Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    I clean it everynight but it still leaks coffee grins and coffee all over the place...this is the second coffee maker of its kind that i have had and they both have done the same thing. This only happens...
    The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
    Jul 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    Filter Basket pops open while grinding and brewing
    Put the handle to the basket, that holds the coffee grounds toward the front.  If it is not facing front it will pop open.
    Jul 14, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    The coffee maker prematurely turns off at
    Hello 1pro8vo2,
    This is a common problem with Cuisinarts and is fixable.
    I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, evc. Positive feedback is appreciated. Good luck. NormanZ
    Jul 11, 2009 | Cuisinart Coffee Makers & Espresso...
    My grind and brew turns itself off in the middle of brew cycle
    Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
    1. Do not "pack" or otherwise overfill the cone/basket with grinds.
    2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
    3. Do not overfill tank with water. Use the marks on the side of the reservoir as a guide rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. As such, a 12-cup machine actually produces closer to 9 standard 8 oz cups. (See your owner's manual.)
    4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
    5. Try a permanent filter rather than a paper filter or vice versa.
    6. Only use the correct permanent or paper filter (see manual).
    7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
    8. It is extremely important to clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
    9. Ensure that the coffee machine is sitting level on the counter.
    May 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
    109 people viewed this question
    Top Cuisinart Coffee Makers & Espresso Machines Experts
    Greg Cann
    Greg Cann
    Level 1 Expert
    Michael Galve
    Michael Galve
    Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
