Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Brother printer and Neygear router wireless connection bad.
I have a Brother HL-2170W printer that does not connect with the Netgear router wirelessly. The wired connection is OK. Brother service support tells me the printer is not receiving the IP address from the router. I know this is so because the printer settings page from the printer "say", Failed to Associate and the IP address, and all the other addresses on the settings sheet, are 0.0.0.0. Any suggestions on how to get the 2 to talk to each other?
  • JFFIXYA Mar 16, 2009
    How are you setting it up? Are you following the instructions that say to first use the wired connection from the Netgear to the printer in order that the router recognizes it during setup?
Had the same issue. Change the router wireless security settings from TKIP to AES algorithms. This did the trick for me.
Posted on Jan 11, 2010
Deactivate MAC filtering on your router. The printer has different MAC addresses for both wired and wireless connections. So if you put the (wrong) wired MAC address to your router, it cannot connect.
After successful connection (with deactivated MAC filtering) you can see the correct wireless MAC address in your Router settings. Just add THIS to the MAC filter range and you're done!
Posted on Apr 03, 2009
:unable to print the wireless printer hl2170w
This is one of the common connectivity issues marring the benefits of having a wireless printer. In this situation your printer will not print when connected wirelessly but would need you to set it up with your system using a USB cable. Try resetting the IP of your system to what is mentioned in the printer and in case there is a router connecting your printer and system then use the IP address of router and put it in your system. This should help you fix this printer issue.
Apr 06, 2011 | Brother HL-2170W Mono Laser Printer
Hi! I have a brother HL-2170W printer. It is connected via ethernet cable to a Dynalink RTA1046VW router (which is sitting on top of the printer) and I have a HP pavillion entertainment PC that is...
Hi!
Your Printer is connected to the (network) router via ethernet cable. Hence, it is a NETWORK PRINTER NOT A WIRELESS DEVICE, no matter your PC is connected to the network wirelessly. So, search for and install the printer as a NETWORK PRINTER. From the printer installation, it should searh and find the printer and susequently install the required drivers.
Moreover, you may checkout the followings link for instructions on how to install/ add a network printer.
LINK-1, LINK-2
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 04, 2011 | Brother HL-2170W Mono Laser Printer
Wireless printer.Lost Manual. Have disk with drivers. Have networked 3 lap top computers with desktop through netgear adsl/router (single unit) and are able to successfully connect to the internet. I now...
Should be able to set all computers to default to Brother printer in the preferences section of the printer control panel ( look in 'control panel' of computer). You ca n also download manual from Brother website. Just type make and model + word Manual into search engine, and it should throw up the appropriate link.
Sep 27, 2010 | Brother HL-2170W Laser Printer
Can not connect to personal Wi-Fi network
This instruction is to setup Brother Laser printer 2170W in windows 7
Turn off Windows Firewall
To reset the printer:
Turn off the printer.
Press and hold the Go Button in front, at the same time turn on the printer from the right side. You will see three lights(Error, Drum, Toner) turn on. Release the Go button. The light is not blue and is off.
Now, Press the Go button 7 times. Wait for some seconds.
The three lights will turn on and off by themselves. The printer warms up and then stops.
Connect the ethernet cable to the wireless router and the printer
in the browser type:
http://192.168.1.1
It shows the device connected and its ip address.
Close the browser and open new browser
on your internet browser type in http://(ip address that you see as device)
click on "Network configuration"
user: admin
Password: access
click on "configure interface". Change it to "Auto Switching" Click OK
You are back in "Network configuration"
click on Configure wireless
Make sure it is "Infrastructure" and the "channel" is correct.
Also "Authentization Method" should be "open system"
Choose your encryption method
type in your password in "hexadecimal format" and click "submit".
If your password is ascii change it to hexadecimal with an online converter
Follow the instructions.
Wait until it prints the papers.
When it tells you to remove the ethernet cable, Do not remove.
Wait until printing is done. Turn off the printer and remove the cable. Turn on printer.
Now Print the printer status:
click on the Go button once to wake up the printer.
Now click on the Go button 3 times. Wait! it will print 4 pages.
Look at the last page
you will see the IP address of the printer.
go to your browser and type in http://( new ip address that you see on last page)
The last step is again in the "configure wireless" to "configure TCP/IP"
choose something like 192.168.1.198 the last 3 digits should be a high number. Close browser.
Now put in the CD and install the wireless Driver only. All Done!
Turn ON Windows Firewall
Jun 23, 2010 | Brother HL-2170W Laser Printer
We just got two brother hl 2170w printers from a lab across campus, they were configured for a wireless connection and now we are trying to connect them to the network via a wired connection. the test page...
hi there, this should work for you:
When you disconnect an Ethernet cable from the printer, wireless network will be enabled.
On the other hand, when the Ethernet cable is connected to the printer, wired network is enabled.
If you press the Go button for approx. 13 seconds, the network setting page will be printed out. Then release the Go button, wired network will be switched to wireless network even if the Ethernet cable is still connected.
You can then verify your network settings and change between wired and wireless setups.
Apr 16, 2010 | Brother HL-2170W Laser Printer
I installed a Brother HL-2170W a month ago and it worked fine on my wireless. Now I cannot get a wireless connection. Can you point me in a direction?
Please check that, can you go online with any wireless computer,if you can go online with that, then try to reconnect your wireless printer again (if can't go online then check wireless router)
Hope it can resolve your query
Thanks for using Fixya
Apr 03, 2010 | Brother HL-2170W Laser Printer
Why is HL 2170W printer saying it is offline. It is wireless and I used Netgear
Go to the computer Control Panel, select Printers, right mouse click on the printer and choose Use Printer Online. See what happens.
Mar 16, 2010 | Brother HL-2170W Laser Printer
How to connect my wireless printer to DIR 615? it is a Brother HL 2170w. They both support one touch hook up, but D'Link doesnt address it in the user manual.
configure the ip manually on ur printer or set ur printer status on accquire ip via DHCP and enable the same in ur router
Jan 07, 2010 | Computers & Internet
No IP address on Brother Printer
Hi, I am assuming that it works whn it is connected directly to your system, as you told that you got your printer replaced. And as you may know that connecting through CAT5 cable is the RECOMEND way..but thats what every1 else tell. So now, the 1st doubt that comes in my mind is about the OS you are using. The model you are using is compatible with Windows, Mac & Linux.
The 2nd possibility rises have you installed the appropriate driver for the printer you are willing to use and check your wireless settings too.
Now the 3rd possibility is that maybe there is something wrong with your router. Maybe you should make sure that the router is working properly.
Nov 26, 2009 | Brother HL-2170W Laser Printer
Lost cd-rom for brother HL-2170W. I need to connect a new laptop to the printer on my wireless network and can't figure out how to do it! It's running Windows XP Pro.
Download the updated firmware, drivers and software for you printer from here (select 'ALL' as Type, and then select your OS and language, to see all downloads available in one page):
Brother HL-2170W downloads Homepage
Also download the manual and guides for your printer:
Brother HL-2170W manuals
And make sure you also look through the FAQs and Troubleshooting under 'Initial Setup' and 'Software' sections:
Bother HL-2170W FAQs & troubleshooting
Sep 02, 2009 | Brother HL-2170W Laser Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
1,937 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
