Question about GE WBSR3140DW Top Load Washer
GE TOP LOADER DOES NOT AGITATE DURING WASH CYCLE BUT DOES SPIN DURING EXTRACTION
  • Ntrouble Mar 02, 2009
    I have the exact same problem. The washer is doing everything is should except agitating-(washing the clothes). I really need help because I'm visiting my mom and I want to fix it before she realizes that her washer isnt't functioning properly.
    I think I overloaded it, but the good thing is that there was no burning smell or weird noises coming from the machine. I just noticed that it sounded as if the clothes weren't moving around much. PLEASE HELP!
  • mulurab May 11, 2010
    how do i remove the agitator
  • GE Master
  • 3,361 Answers
Remove the agitator and check the agitator splines also the agitator coupling on the shaft may be stripped.
Posted on Mar 04, 2009
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
GE WBSR3140DW Top Load Washer Logo
305 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
