The 'antenna in' cable hook up spins
Which has broken the soder to the board. Can I re-soder it or find a new part. The tag on the cover of part is: Samsung DTVS205CH201A 070419 BBS LF. Tried looking on the Samsung site but couldn't find anything. Vizio 26' HDTV
I was a Tech for Vizio for 3 months I Have a couple board Brand new one of them in label Samung dtvs205ch201a 070705 IDT-LF
Let me know if that s what you looking for
my email is
Posted on Mar 01, 2009
The part that the TV antena or cable screws into is broken. The whole piece spins freely instead of allowing me to tighten down the outer ring on the antenna cable
Oct 08, 2015 | Televison & Video
How do I hook up an antenna to the tv? There is no antenna in coax connection. Do I need a converter box too?
there HAS to be a coax connection,unless it is broken off,in that case you need to replace the control board you wont be able to use an antena without it,if using cable box,use hdmi input
Jul 16, 2015 | Televison & Video
Antenna input on back of tv broken off
if your converter box has rca output toy can hook it up that away. Or you can look on ebay for a new main board. very easy to replace. be sure at all time to unplug tv while back cover is removed.........hope this helps
Dec 01, 2013 | Sharp Televison & Video
Standby power failure
If warrantee still good get new one if not check for broken solder joint on transistor works until it gets hot may need new transistor should have numbers on it., If to hot will need schematic. first get sodering iron and soder 60/40 remove all covers, get(freeze it) a can of cold spray and keep hands away from power supply board the board with the wall plug coming out of it and the thick wires connected to it. do not touch, Plug it in the wall and wait until it turns off, spray the componets that you think are the problem the cold will allow it to turn on for a while check the transistors first (little black box with three leggs) then the capacitors (the little blue barrels with the black lines on them) when you find the componet call the company for the replacement part find the manufacturing company on the internet they will have it.simply make a drawing of the way the componet was in the curcuit and put the new one in,tip on how to soder pull the soder off the roll about five inches, Place the hot tip on the leg and the board wait a second and drop the soder on the hot tip for just one more second, letting a small amount melt this on each leg remember that a transistor has a ground,a hot, and a base,The cap has only a positive and a negative.Good luck
Aug 26, 2012 | Denon AVR-2308 AV RECEIVER 220 Volts-19407
My 1990 Honda Accord radio antenna motor functions opposite to what it is suppose to be. When radio is on the antenna down, when the radio is off antenna up. Even with this reverse function I can feed the...
first of all, is your radio factory or aftermarket? If its factory the you probably have a bad ground or a short in the radio power to antenna. If its after market, then the remote antenna wire is hooked up wrong. Check to make sure the antenna wire is hooked up to the antenna. Good luck
Feb 21, 2011 | 1990 Honda Accord
Broken antenna - 1996 oldsmoblie ciera
I assume it is an extendable antenna, if so loosen the ring around the antenna base there are usually like 4 slots on it, after you have removed the ring, have some one turn your car to the accessory mode and turn the radio on, your antenna or what is left should come right out, to install your new one just feed cable down hole and have them turn your radio off you may need to spin the antenna just a touch to let it catch cable, be sure to put your antenna ring back on.
May 27, 2009 | 1996 Oldsmobile Cutlass Ciera
Saab 9-3 convertable antenna will not go up. there is a clickng sound when the engine is turned off and on at the antenna.
antenna mast is no good.. you can buy a mast and have it installed or buy a used antenna and have it installed im sure Elite foreign auto parts has only saab parts.. tested and used,
Feb 17, 2009 | 2003 Saab 9-3
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
Televison & Video Logo
419 people viewed this question
Top Televison & Video Experts
