Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Hoover agility steamer lower hose broken
How do you get the thing apart to fix it
  • jbranson3 Mar 25, 2009
    I have to replace the water return hose. How do you get it apart?
  • Lisonh May 13, 2009
    I have the same problem . I just realized that there wasn't much dirty water in my tank , when lowered the handle I noticed it was broken. Now out to find the part .
Take the handle screws all out and take the black peice where the hose attatches to loose. then pry handles apart gently and the hose peice will be able to be reached. not easy but can be done.
Posted on May 12, 2009
How to repair the lower intake flexible hose on the Hoover Agility
hoses are screwed into the end bits by turning in the do up direction
original equipment hoses are normally glued into the end piece but with a bit of determination and a flat bladed screw driver, the glue can be broken and the end removed
fit the good section of the hose into the end and screw it in using an un do direction
if it is the plastic fitting itself that is broken then weld the broken section back together
Basically use a soldering iron and heat the sections until the plastic melts back together
There are u tube pages that show how easy it is to do as they heat weld all sorts of plastic and tips on how to improve the strength of the repair. go google and type in how to weld plastic.
Apr 14, 2015 | Hoover F6212-900 / F6215-900 SteamVac...
I have a Hoover Steam Vac. Even though I don't
There in the trigger assembly is a release button that might be broken.
Nov 28, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Lower hose broken hoover agility how to replace
to replace a hose on the Hoover V2 is a pain in the you know what. i would recommend
1. take it in and have a professional repair shop do it.
2. trade the V2 in for the Hoover PowerMax steam cleaner with spinscrub they are 100X better then the V2's and about 1/2 the price
Jul 28, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Your right there is nothing you really can do . Enginering was very poorly thought out. Sorry . Wish i could do more . Ed.
Jun 18, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Where is schematics online to replace lower hose assembly part
There is no schematic that I am aware of. I can tell you that from experience that this repair is very difficult. Basicaly the upper and lower handle unscrew along with the tank base, the hood comes off. the lower handle will split but not comes completely apart to remove the hose section. When reassembling, be sure to put the back hose gasket in the correct position. Look at it (take a picture) prior to repair first.
Feb 02, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Hose
I ordered it through www.247vacuums.com They shipped immediately.
It is called Lower Hose and it was $13.99 plus shipping. I just went to the website and this is the direct link. Hope it works.
http://www.247vacuums.com/Hoover-Agility-Lower-Hose/M/B0017PPV1K.htm
Also, replacing it didn't turn out to be that difficult. You just have to get all the screws out and there are lots of them. I think I took out 16 and then was able to open the upper compartment enough that I could change the hose without too much of a problem. Good luck.
Sep 19, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover agility--poor suction, still!
When you remove the dirty water tank, on the machine, there is a screen that gets clogged and will prevent good suction, is this one clean? If it is, do you feel suction at that screen, if so then there is a problem with the tank. If no suction there, then you will have to check it over for a air leak or a bad seal.
Apr 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Agility, No Suction!!!
I had the same problem. Lower the handle to the floor and check the black spiral suction hose at the neck of the machine. The lower hose in my Hoover split. Check and see if yours has done the same thing. If so, the lower suction hose will have to be replaced. Hope this helps.
Oct 04, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
313 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
