Question about JVC KD-G401 CD Player
Universal wiring plug
Where can i buy a replacement wiring plug which fits in the back of my JVC KDG401 . As i left the original in my old car when it was scrapped.
  • 265 Answers
Try maplins.co.uk
Posted on Feb 21, 2009
My jvc stereo will not power up but have found the black wire is live ?
hi peter, before you start using the rest of the harness cables find out if the harness you have is a jvc original for your model. the black wire is the ground/chassis cable only for a jvc kd-r411. you mite be using a compatible fitting harness whose " wire colour configuration" is incorrect for your model. cheers.
Mar 02, 2013 | JVC AM FM CD DET FACE CAR STEREO
Need to find a wire harness to in my radio does not have to on that goes from radio to car harness. where can i find on for a JVC model KD-LH1100
Car harness adapters can be purchased in Best Buy or Crutchfield just give them the make & year of your car. Try Metra and call to see if they still make Universal harnesses for JVC so you can connect it to a universal harness to your type of car. Just click them together to avoid soldering or taping with electrical tape.
I use to work for Circuit City Roadshop and they(METRA) only made it Exclusively for Circuit City and nobody else in 2008.
Apr 09, 2010 | JVC KD-LH1100 CD Player
I've got a 1988 Dodge Ram and I know nothing about Car Stereos
go down to a electronics shop (future shop or best buy) and they will have a connector that will fit the original plug. Some splicing will be required but its all color coded with the deck
hope this helps
Nov 15, 2009 | Alpine CDA-7840
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
Wiring in a new car deck
The easiest and most efficient way to hook up your old radio harness to a new head is to use a harness adapter that is made for your vehicle.
If you have not cut off the old plug that went into the old radio then it would be a simple matter of plugging the adapter harness into the old plug and color matching the wires from the adapter to the new head wires, which will be the same colors.
If you go on line to - Installer.com you probably will find the correct adapter for your vehicle. There are other on-line stores that deal with adapters, as well.
If the old plug was cut, it may be possible to splice the plug back to the original wires, then it's a matter of plugging the adapter plug into it.
Hope this helps...
Jul 13, 2009 | JVC KD-S5050 CD Player
Connect jvc kd-lh1150 in elantra 2001... different connector
Hello claude_bouth,You need a vehicle specific aftermarket connector generally called a "wiring harness". Your JVC came with a plug that fits the back of the receiver with "pigtail" wires which you splice to the harness wires. http://www.SonicElectronix.com sells the Metra 70-7301 which appears to be the correct harness for your Elantra.You can tap into the wiring of the car harness and splice the wires by function into the appropriate car wires, but using the aftermarket vehicle specific wiring harness is a lot easier and you don't need to disturb the vehicle wiring in any way, just plug into it. It also makes it possible to re-install the factory radio if you ever need to do so. If you choose to tap and splice, you can find your Elantra's wiring color code at http://www.modifiedlife.com.Hope this helps.
Jun 05, 2009 | JVC Arsenal KD-LH1150 CD Player
Promblem wiring to my car
GO TO WWW.CRUTCHFIELD.COM AND THEY WILL SELL YOU AN ADAPTER SO YOU DON'T HAVE TO CUT ANY WIRES ON YOUR CAR
Jun 19, 2008 | JVC KD-SC800 CD Player
Wiring
The easiest would be to purchase a harness/connector specifically for a JVC to Toyota. You can try finding one here.
Alternately, you can hardwire or DIY splicing the wires/connectors following below wiring assignment.
You might find this document informative on radio installation in a Toyota 4Runner. Here is the installation manual of the JVC KWXC410. Should you need the owner's manual, it may be downloaded from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | JVC KWXC410
JVC KD-S575
Most versions of the JVC KD-S575 uses the 16pin block connector as shown below. It is available at the JVC Accessory Store.
Below image shows the pin's alphanumeric designation.
Color coding and where connected is shown below.
A2 Brown - cellular phone/mute
A4 Yellow - Always on B+12 (such as the battery's positive terminal)
A5 Blue/White - Power Antenna
A7 Red - Accessory or switched +12VDC
A8 Black - Chassis/Ground/GND
B1 Purple - Right Rear +
B2 Purple/Black - Right Rear -
B3 Gray - Right Front +
B4 Gray/Black - Right Front -
B5 White - Left Front +
B6 White/Black - left Front -
B7 Green - Left Rear +
B8 Green/Black - Left Rear -
Thank you for using FIXYA.
Feb 12, 2008 | JVC KD-S570 CD Player
JVC KD-G401 CD Player Logo
162 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
