Question about Motorola Mobility TracFone® V170 Cellular Phone
Power On I KEEP FINDING MY PHONE TURNED ON, WHEN I AM SURE I SHUT IT DOWN BEFORE PUTING AWAY. IS THIS EVEN POSSIBLE OR IS SOMEONE MESSING WITH ME?
  • Christopher Chapman Aug 04, 2007
    I"m not kidding,I paying close attension to it and has done it several more times since I posted this. The only problem this creates is a phone with little power left if I don't catch it for awhile.
These phones have an option to auto turn on and off. Under setting, then othersettings, then Initial Setup, then power on/off. Check the time setting in the power on/off and see if this helps.
Posted on Nov 16, 2007
  • 100 Answers
Someone is messing with you, lol.
Posted on Aug 02, 2007
SOURCE:
How To Fix Tenda Router's Internet Connection Issues?
You didn't mention what issues you're having. Shut down the router for a few seconds, then restart. Routers use convection to cool; there's no fan. So you should keep the router away from other heat sources, cool if possible, and have no blockage of its air holes. You could even have a small fan blow across the router to keep it from resetting, and to help it last longer.
Apr 16, 2018 | Internet Computers & Internet
Hi I m sanchit.I want some help from all of you.I have forgot my security code.I have used nokia n72.Its serial no. is 353089020693285.I have use all 4,5,6digits code but these are not work.plz told me...
Hi! The only possible free solution is to format your phone, that erases all your codes, but, even all info from your phone. Shut down the phone, press *, 3 and green(answer) key, keeping pressing power on the phone, keep pressing, after 15 seconds release all. If operation finishes with success, you will need to enter time, data, location.
Jun 06, 2011 | Nokia Lands Phones
The computer was given to us. the lady that gave it to me said it had problems connecting to the internet but that was it...when i got it home and hooked it up it turned on for a brief second and shut off...
Do not attempt to turn on again:
Do the following:
Step 1
-Check the voltage switch (if it has one) on the back of the PS. Make sure it matches your home voltage. If yes proceed to step 2.
Step 2
-Check for heavy dust/debris inside computer case and inside PS. Clean with can of air as needed to prevent possible overheating.
Step 3
-Check all connections to motherboard and try restarting again. Look for the green light to appear on the PS.
Notes:
-Improperly installed or incompatible memory modules will also keep PC from starting up properly, although this usually is communicated through a series of beeps at start up. If no memory upgrade has been made recently, this is probably not the issue.
Most power supplies last well beyond other PC parts. Finding a replacement should be pretty simple. A used PS will do just fine. Test before buying unless New In Box.
Jan 11, 2011 | HP Pavilion a450n PC Desktop
Env3 turns off by its self
this happens to mine too! it has already turned off 8 times today. I started messing with things on the phone...pressing on buttons..opening it and closing it quickly...and stuff like that and I think I found that when you push hard on the middle of the battery..it just turns off. (try pushing on it and checking that). I don't know how to fix it but I do want to know if that is why yours turns off like that too....
Oct 14, 2009 | LG enV3 VX9200 Cell Phone
My phone is stuck in on and off mode
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.try
Aug 17, 2009 | Apple iPhone 3G
I keep losing my wifi connection with edimax router maybe twice a day on average. i have to power off the router then on again.. can anyone explain this and a cure? [email protected]
It is more than possible that it is the "wireless zero config" service or the location of your router. It coulcd even by channel interference.
If its channel interference try setting your router to auto for channle selection.
If you are not getting any more than a 10mb conectionto the router consider moving the router
to turn of wireless zero config open control panel, click administrative tools, now services, then scrol down to wireless zero config.
Double click on it then click stop. Then set the service to disabled. make sure you click the APPLY button before hitting OK. you can now close the rest of the windows.
I would suggest at this point you also do a shut down and restart.
What you have just done is tell windows to stop messing about looking at other peoples wif to see if it fancies somthing better (sound familiar ?)
You told it that it only has eyes for you ;-)
If this information was useful please click
Aug 13, 2009 | Edimax 54G BROADBAND WIRELESS WIFI ROUTER...
External buttons not working and battery acting up
Same with me! My OK and # buttons constantly stop working X-X I just have to hold them down, keep hitting them, or hit them with another button. But usually Ill have to open the phone.
May 29, 2009 | Verizon Communications enV2 Cellular Phone
Subwoofer makes a sound at computer startup
1.yes the electric shock can damage the subwoofer  2.some times a sudden switch off or power cut can result in for such issue . 3.for this issue just make sure that you switch on the speaker 1st before starting the PC, then switch on the PC, & while closing time also make sure you 1st switch off or shut down the PC 1st & then the speaker in last   & more ???...! do keep on writing untill then have happy computing sir...till then See you soon...!
May 24, 2009 | Altec Lansing VS2221 Computer Speakers
CTR Television will not power up
What has happened is that the horizontal output transistor has shorted. The squeal you hear is the power supply running under a heavy load. The picture narrowing or being distorted indicate that the horizontal output was not operating clean. Something in the output section was not as it should be. Possible short in the output transformer/tripler unit or something loading down the secondary voltages generated by the horizontal output. You will need a tech to figure this out....If you are not a tech, then this ones a goner as far as fix it at home goes.....If you are a tech I might be able to talk you through the repair. Have someone remove the horizontal output transistor and I bet the squeal goes away.
Feb 10, 2008 | Televison & Video
Frozen?!
Sounds like liquid damage, may be able to dry for phone and with the battery removed clean the contacts in the charging/data connector with 99.9% rubbing alcohol and a tooth brush, keep away from the baby, dry out in gentle warm moving air for a while and hope for the best. Good Luck!
Jul 11, 2007 | Sanyo SCP-3100 Cellular Phone
Motorola Mobility TracFone® V170 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
