Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Drive belt slips off allis chalmers riding tractor model number 6
Every time its started drive belt slips off
canbruce75
  • 1776 Answers
SOURCE: need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
Posted on Aug 31, 2009
lonewolf1996
  • 142 Answers
SOURCE: How do I replace the Drive Belt on a Craftsman
You need to get underneath the mower.Look in the front on the bottom of the engine.You will see the engine pulley.On the side of the pulley you will see a bracket that keeps the belt from falling off the pulley.It is help on by two bolts.Take the bracket off.Now you will be able to take the belt off.
Reinstall the new belt and replace the bracket.
Posted on Sep 02, 2009
SOURCE: How do I adjust blade drive belt tension on
Belt was excessively worn and after replacement and adjustments made all ran well. Thnaks.
Posted on Sep 03, 2009
mowerman1857
  • 389 Answers
SOURCE: drive belt 42" craftsman tractor model #917.270810
You need to post the 917.xxxxxx model number for some one to help you. There are about 10 different belts that fit different 42" Craftsman mowers.
You could also go to www3,sears.com and put in the same 917.xxxxxx model number and look up the part number. You do not want to buy a belt just by the size alone but must use one that is made for the machine application. The cheaper ones that you pick up in the local hardware store etc. like a 3Lxxx or 4Lxxx are made for low horsepower electric motors and will not last on your lawnmower.
Posted on Sep 15, 2009
SOURCE: I have a scotts turfmaster 12.5 hp riding tractor
The belt travels from eng. pulley directly to the transaxel pulley riding on the inside/center of the tractor side of the idler pulley. make sure the belt retainer is on the idler pulley.
Posted on Mar 16, 2010
My belt is sqceeling on my d17 when i try to turn it right but if i turn i left it does it it does not scqeel
'squeal'
'squealing'
Check the steering pump fluid level and the drive belt tension. Spray all your belts with belt conditioner spray.
For anyone else reading this and wondering what the vehicle is, we are taking about an Allis Chalmers D17 Tractor.
http://www.chatstractors.com/2009%20tractors/1477-Allis-chalmers-D17-left-side.jpg
https://www.google.ca/search?q=d17&sourceid=ie7&rls=com.microsoft:en-CA:IE-ContextMenu&ie=&oe=&gfe_rd=cr&ei=yV9QWKPOAu7L8Ae-rbX4CA#q=d17+tractor+steering
Dec 13, 2016 | Garden
1936 Model M Allis Chalmers crawler. Where can I get a free manual download?
Hi Jason:
I'd try to locate the nearest antique farm equipment club and see if I could connect with someone who had a manual that I could either buy or copy.
Here's a link that will perhaps assist in getting you started.
https://www.google.ca/#q=1936+Model+M+Allis+Chalmers+crawler+manual+
Cheers.
Dec 26, 2015 | Garden
410 allis chalmers
Specs Link:
Allis Chalmers 410
Parts Link:
Simplicity Allis Chalmers Mower Parts
Had a friend who took off his Yamaha branding on a Motorcycle and replace with AC brands - AC rocks.
Mar 03, 2015 | Garden
How to set engine timing on allis chalmers model 2900 engine?
SEARCH ALLIS CHALMERS 2900 ENGINE SPECS, FOR THERE ARE QUITE A FEW SITES.
Sep 05, 2014 | Garden
I have an Allis -Chalmers 416 tractor with mower deck I need to know how to install the deck (I have lost the manual) It is an older model serial number 26002395 Can you help
There are 2 holes at the front on the frame you need to put a pin and cotter pin through each side to hold the front of the mower. Then there will be a hangin piece of straight metal about 2-3 inches long with a hole in it that you need to hook up the chain to also with a pin with a hole in it and a cotter pin. This will allow you to raise and lower the deck with the electric lift. If you need pics let me know i'd be happy to help.That's all there is to it besides putting the belt on.
Jan 21, 2011 | RTO Allis Chalmers Tractor 7010, 7020,...
When setting points on a CA Allis Chalmers Tractor. What should the gap be and do you do it on the lobe or flat service
Set the gap on the high spot on the lob,it should be set at around 50000 or twice the plug gap,this is just a rule of thumb,but changing the timing by turning the distributer will get the engine to max performance after this has been done.
Apr 07, 2010 | B&C Allis Chalmers Tractor B,c,ca Starter...
Tractor will not fire points look clean
I am not familiar with the Allis Chalmers brand, but if the coil is good and you are still not getting spark to the plugs, I would consider a sheared flywheel key as the likely cause. Hope this helped and best wishes.
Aug 03, 2009 | B&C Allis Chalmers Tractor B,c,ca Starter...
Allis chalmers AC 5040 is leaking water/fluid
looking for in the oil cooler inside the radiator maybe is broken.
Jul 11, 2009 | B&C Allis Chalmers Tractor B,c,ca Flywheel...
Allis chalmers 912 hydro belt diagram
I also have the same tractor but i have what your looking for so my email address is rickralston73@yahoo.com
Jun 27, 2009 | RTO Allis Chalmers Tractor 8010, 8030,...
Allis chalmers b starter problem
Two things come to mind. If the plug base is too deep it could bottom out on the piston, and if the cam/shaft timing is off by a tooth or more it could also cause this problem. Check it out.
May 14, 2009 | B&C Allis Chalmers Tractor B,c,ca Starter...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
60 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
