Question about Exercise & Fitness
Bogs down I have a Sportscraft tx 500 treadmill and when i go to walk on it , it slows way down and almost stops and if i get of it runs fine at the right speed. please help its just like new
  • 83 Answers
Sounds like either the belt is loose or the belt/deck need to be lubed.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
To lube the treadmill, use silicone spray and spray between the belt and deck on both sides. I hope this helps. Let me know if you have any other problems.
Posted on Apr 30, 2010
Why is the treadmill slowing down when you walk on it. It slows down when someone get on the machine.Is there a way to adjust the belts or anything that can be done to rectify the problem.
You have adjust the running belt of the treadmill. If you check the bellow added link you can find out how to adjust the running belt of treadmill. Almost all treadmill follow the same procedure. So if your brand mode is not listed you can follow the procedure of listed treadmill.
http://electro-medical.blogspot.com/
Sep 27, 2016 | Sportcraft TX 400 Walking Belt
We picked a TX 440 from a friend and the error button shuts it off
If you wish to get some details About treadmill repair; check the site linked here. Pull up older posts.
Sep 11, 2016 | Sportcraft Tx 455 Sportscraft Treadmill...
Tx 5.0 rc treadmill by sportscraft, manual
Did u find out the problem? Mine just started doing the same thing.
Apr 13, 2013 | Sportcraft Exercise & Fitness
Here's the problem when you turn on the treadmill it runs fine until you put your weight on it. Once you stand on the treadmill with the belt running it gets stuck?
This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the
belt or when the treadmill operates normally for a given period of time
with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time
Test every step.
http://www.youtube.com/watch?v=38w4PkiWIBY&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
Mar 25, 2011 | Proform Crosswalk 500 Treadmill
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
May 27, 2010 | Proform CrossTrainer Treadmill
I have a NordicTrack EXP 1000 X. Just bought it froma guy on craigslist, and it was working fine at his house. Messed with the belt tensioner bolts a bit when I brought it home, and now when I walk/run on...
It sounds like the belt is bogging down, this condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
The only certain way to test for a worn walking belt is to take a DC amp draw . Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test.
The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop fewer steps indicate high friction.
May 23, 2010 | Nordic Track NordicTrack Treadmill, A2550
After walking about 15 seconds the belt slows way down and stops completely.
The walking belt slows when walked on the walking belt maybe overtightened, treadmill performance may decrease and the walking belt may become damaged or the opposite the drive and /or running belt may need tightening. Last thing would be that the belt needs lubrication to be applied between belt and deck.
Apr 26, 2010 | Cadence Weslo 620/630 Treadmill Walking...
I need to know how to tighten the belt
describe how to tighten the belt on a tx 400 sportscraft treadmill.
Dec 16, 2009 | RTO Exercise & Fitness
Exercise & Fitness Logo
213 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
