Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Picture has a red "haze"
I have a Magnavox 37" LCD tv model# 37MF331D the darker parts of the picture have a red haze to them, and when there is no signal to the tv the screen is red and not black.
The color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Posted on Mar 04, 2009
Why toymax magnavox 37mf331d 37 in tv worked good i turned it off came back to turn it on and it wont come on the green light that is usually there its not on ?
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 27, 2014 | Toymax Magnavox 37MF331D 37 in. LCD TV
Magnavox tv won't turn on or off
The typical cause of power up problems in a failure of the power supply filter capacitors. The board can be repaired by replacing the bad components. Below is a picture of the power supply board with the bad capacitors circled and below that is a link to a it that is available with the correct parts to rebuild that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=216
I hope this helps you out,
BuddyMc
Sep 25, 2012 | Toymax Magnavox 37MF331D 37 in. LCD TV
I lost the picture on my 37" LCD model 37MF331D/3. The audio is fine.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 03, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
My 2 year old Magnavox 37MF231D/37 LCD TV just blew the picture screen. The audio comes through fine, but the screen is dead black with no menus, info, nothing. I tried various inputs, same result. I...
The problem can be in the backlight inverter board (hard to get to), or the main power supply module may not be working. Look at the power supply first since it is easy to get to, look for burnt parts, bad capacitors.
Please
Nov 11, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Magnavox 37MF331D 37 in. LCD TV tv will not come on, power light blinks. I tried disconnecting power cord and hold power button to discharge, still will not come on and as soon as I apply power again the...
I had the same problem with a Magnavox LCD TV. It would not turn on and the light on the external PSU flashed. I found a replacement 12V 5A power supply on EBAY. It brought the set back to life.
Sep 12, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Magnavox 37MF331D/37 keep asking for software upgrade
Your set either has a bad SSB (small signal board) or needs a software upgrade. Try the upgrade first by going to http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=FLAT_TV_CA&sct=LCD_LARGE_30_40_SU&grp=TV_GR&session=20090830171041_4.131.87.247&ctn=37MF331D/37&mid=Link_Software&hlt=Link_Software
Download the latest software release for your set then follow install instructions that are contained in the user manual for your set.
Jul 22, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Philips Magnavox 37" LCD Flat Screen 37MF331D Have replaced power board,main board,hit power a faint light on whole screen for about 2 seconds the nothing.
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Feb 19, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
476 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
