Question about Grilling
Gas grill loses pressure while side burner does not
When igniting center burner of grill, have barely enough pressure to sustain the flame. If ignite side burner, flamer sputters. While side burner works just fine.
I had the exact same problem with my Jenn-Aire and so I replaced the regulator for $20 and it now works fine.
Posted on Feb 28, 2009
Natural gas grill low flame
Did you change the reg , lpg burns at 14 inches wg nat gas burns at 4inches wg
Feb 16, 2013 | Char-Broil Commercial Stainless Steel...
Purchased a grillpro 3 (three burners plus side burner) from orchard. They installed but side burner will ignite. Igniter is working and I hear gas when I turn the burner knob. Fire the igniter and it will...
You're getting gas to the burners, just not enough to ignite the burners.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank.
I hope this helped you & thanks for choosing FixYa.
Jul 28, 2011 | GrillPro Grill Pro 80016 Hose and...
Fan turns on, pilot on left side turns on red light at bottom stays solid during entire time then pilot goes out and blower stops no heat please help
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remaing solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Oct 05, 2010 | Goodman GMS90703BXA Heater
The back burner doesnt consistently light up.
If the flame doesn't go completely around the burner, ther is an obstruction at the outlet holes. Make sure all outlet are clear of dirt, rust,or any material. Even water will block the outlets.
Apr 25, 2010 | Weber Genesis Silver B Grill
Ducane lp gas grill flame pulsates
Have you replaced the battery ? They do rust and lose contact over time outside.
Apr 14, 2010 | Char-Broil Commercial Stainless Steel...
New propane tank won't ignite
The regulator on the on the hose is either gone bad, or could have got a little bit of dirt in it. You could tap the side of the regulator gently and sometimes this will solve it.
Apr 11, 2010 | Char-Broil Designer 463261106 Grill
Propane grill wont ignite
Well, it sounds like your grill is experiencing vapor lock. Vapor lock is basically air caught in the gas line and there is a relatively easy method to fix this. I want you to try this method and tell me what you get, ok? First, open the tank's valve, then open the burner valve and light the grill. Immediately after you see a blue flame, turn off the tank's valve, count to five and then close the burner valve. Repeat this procedure three times, the problem should clear itself.
If you are still experiencing problems, the regulator may be faulty and needs to be tested next, so go get a new regulator from your Lowe's and run the procedure again. If after all this, you are still experiencing the problem, let me know here. Good luck!
Jan 06, 2010 | Grilling
Having problems with Carrier 58RAV furnace. Goes through the motions, but gas never turns on. I think it is a problem with the LPGS. Please advise. Thanks
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
Dec 24, 2009 | Carrier Heating & Cooling
Lighting Problem/2 year-Old Ducane Grill
Do you have enough gas pressure coming out of the regulator and gas valve? You'll need a pressure guage for this.
If yes, try taking out the burners and cleaning them with a wire brush, especially the flame spreading sections.
Sep 15, 2008 | Ducane 30400040 Stainless Steel Grill
Grilling Logo
442 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
