Question about JVC AV-27530 27" TV
Display color changed from green/ white now to Red and blue?
Something happend to our set. The volume display used to be green with the adjust lines yellow....now they are blue with the adjust lines red...this is with all the functions.....i try to manually adjust colors but still have a slight red tint in the picture? Even the animation doesnt show the true colrs...what has happened?? is there a master code or reset or is the set about to expire? It is only about 3 or 4 years old...
  • jed608 Feb 21, 2009
    Updated...after comparing to other TV i noticed my green tint is out? It displays dark or blue sometimes...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem is as you suspected, the green is missing. This is a common failure and is technically an easy/quick repair. Almost always, the culprit would be a cold solder or a faulty color drive transistor/IC. They would be located on the small squarish PCB (printed circuit board) at the very rear of the tube. Of course, worst case scenario would be a faulty CRT (picture tube), but that would be least likely.
Corrective measure would then be initially re-soldering above describe solder joints and/or replacing faulty transistor/IC.
Good luck and thank you for using FixYa.
Posted on Feb 24, 2009
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    How do you set convergence
    What is your Make and Model number?
    My screen turns green and then turns off
    you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
    when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
    Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
    RCA Pearl TH1100A backlight colors
    Pp. 16-17 of your user's manual:
    http://www.rcapearl.com/pdf/TH11xx_IB.pdf
    Settings
    Press forward to enter the Settings menu and then
    press plus or minus or to highlight an item. Press play
    repeatedly to change settings.
    Backlight:
    • to adjust the time before the display light
    turns off (On/10s/20s/30s).
    • to adjust the color of the display light
    (Red/Blue/Green/Yellow/Cyan/Purple/White).
    -Tha Mp3 Doctor
    Dec 13, 2008 | RCA TH1101 MP3 Player
    Color problem
    Did you try alignment of color convergence in setting up. Try this
    1 Press MENU
    2 Select SET UP
    3 Select CONVERGENCE
    4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
    5 Use arrow keys to aline the red cross to the white cross.Press set/enter
    6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
    I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
    Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
    To much red in the picture
    Yes, either some resistor has changed and it's pulling down the blue and green or depending on how much red it could be a short on the red line. Also you can open back of set and try this. Each CRT's have a Focus Block with Screen control. Maybe you can turn down red and align up with blue and green. The professional way of doing color is to get a good grey scale, meaning black and white picture. THis is turning down you color on set to zero and looking and adjusting to black and white as good as possible. You can try this but if there is a serious problem it may not help. The problem may have to be resolved first. Be very careful in touching anything while set is on, unfortunatly you have to have the set on to properly adjust. but you can use something plastic or rubber end screw drivers
    Sep 06, 2007 | Mitsubishi WS-65411 65" Rear Projection...
    How to adjust picture on projection tv
    i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
    Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
    JVC AV-27530 27" TV Logo
    Top JVC Televison & Video Experts
    Jaime Hernandez
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
