Question about Samsung Video Cameras
My SCL906 camcorder keeps flashing emergency eject
My camcorder keeps flashing emergency eject-- then it ejects the tape in either record or play-- it doesn't do it all the time-- what is the problem
  • 128 Answers
SOURCE: Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Posted on Feb 16, 2006
SOURCE: Canon zr300 ejects tapes
The solution for this required sending it to Canon factory service. I was very reluctant to do this because I've heard horror stories about Canon service, but I was actually pleasantly surprised. The total cost was only about $65 and the shipping and service turn around time was amazingly fast. I was expecting weeks to go by. If memory serves me right I shipped it and received it back in less than 2 weeks.
This is a known problem with Canon and would be covered under warranty if your time hasn't run out.
Posted on Sep 25, 2008
SOURCE: Cannon MD101 Wont eject Tape /No Power
same problem :(
Posted on Oct 05, 2008
welcomejee
  • 10594 Answers
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Posted on Feb 26, 2009
SOURCE: Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Posted on Jun 08, 2009
Every time i put a tape in to play or record, it keeps ejecting it why??
Please be more specific. When you insert tape, the tape housing extract to its body, or it just stays still and eject your tape.
Aug 15, 2010 | Canon ZR100 Mini DV Digital Camcorder
When i put a tape in it ejects it..then a tape with a slash appears on the screen
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Feb 26, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Flashing tape!
this is because there is lot of condensation taken place inside.. so keep the eject tray open and most important in a clean dry place say atleast 3 to 4 days...
Aug 02, 2008 | Hitachi VME545 Camcorder
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Camcorder problems
wow this is an old post...but mine used to do that back when I had a charger for it haha...I tightened up the video tape and make sure the tape didnt have wrinkles in it too...and it seemed to alleviate the problem if not for one recording...the stop and go recording though thats when this emergency eject happened to me...but was resolved with my just turning the wheels in the tape to tighten the tention...of course it sometimes didn't work cause I didnt get it tight enough you just gotta play with it...if all else fails send it to the shop though...
Sincerely,
Rabeka Jo
Dec 24, 2007 | Samsung SC-L810 Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Cannot play tape nor record on tape
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Oct 08, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
Sep 04, 2005 | Canon ZR25MC Mini DV Digital Camcorder
Video Cameras Logo
55 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
