Question about Maytag CWE5800A Electric Double Oven
Top oven appears to have no power going to it.
I just had this installed last week. It worked perfectly. Today I see that the control panel is off, the lights (in both top and bottom) don't go on, the fan doesn't go on. The bottom oven, aside from the fan, is still working. It looks like there is no power. Coincidentally, on my electric meter outside the house, the wheel has completely stopped turning even though the only thing that doesn't work in the house is this top oven.
  • Maytag Master
  • 3,361 Answers
Contact an electrician and or the power company.
I believe you have lost the neutral/ground in your power service.
Posted on Feb 21, 2009
GE PT916S R2SS Wall Oven gets moisture in the control panel and quits working Then we have to reset the circuit to get it to work again.
There is a good chance you will need to replace it - again and again and again. Electronics were never intended to be utilized in hot or damp/moist environments. But appliance manufacturers could not resist the urge to go modern and replace the perfectly good knobs we all grew up with with buttons and displays that tend to confuse more that help. It is for this reason that appliances today will never last the 10-15 years that the ones our parents bought lasted. The manufacturers know this as well and they're laughing all the way to the bank...
Aug 31, 2016 | GE Profile 30" Built-In Wall Oven PT916
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
mode and verify the error codes. Ensure AM software, UI software and EEPROM
CHECKSUM versions appear on the lower text line. If AM software and EEPROM
versions do not appear, UI and AM may not be communicating. Verify this for the
lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
the AM software version for the lower oven appliance manager, and the microwave
UI will show the AM software and EEPROM versions for the microwave appliance
manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT
DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions,
go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER
OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
Top Oven displays F2 code. Beeps constantly, even after shutting off power and restarting. Need it to work by Xmas!! I have old control panel that still worked, but was extremely dim. Will this fix my...
Looks like you have the key stuck code. To replace the panel, first shut off the power, then take the screw out that are holding the oven into the cabinets. After that you will need to pull it out from the cabinets about 4 inches. Then take off the screws holding the control panel in place. Here is an exploded view of the control panel, this should help. Just use the link here: http://www.partlinx.com/search/SearchImageViewer.asp?cImageURL=http%3A//www.partlinx.com/images/00308/i620620.GIF
Please rate my solution if it was helpful.
Thanks, Repairman45
Dec 19, 2010 | Jenn-Air JJW9627DDW Electric Double Oven
This KitchenAid combination wall oven and microwave unit was purchased in 2002. Except for having to replace a fuse in 2004, it worked fine until the microwave started acting up recently. In September...
Good Question. I work on all brands of appliances, and I swear by KitchenAid-Whirlpool appliances. That being said, I do not recommend oven-microwave combinations, because the ovens will last 30 to 40 years, but the microwaves start having major repairs from 6-10 years on. I would bite the bullet and put in a separate Panasonic microwave (with an inverter) and a seperate KitchenAid Oven. You also need to install a 2000 Joule or higher surge protector, for your microwave oven. Panasonic microwave ovens are better than the KitcheAid ovens at this time.
I would suspect that the touch panel-control board failure may have been caused by the repairman, just because the timing is a little too close to the mag repair. No way to tell you for sure, and I myself have had control board failures the same day that we changed a light bulb, so anything is possible. Usually a factory defect is going to show up before 8 years. In the last 4 years in the greater Seattle area, 70 - 80% of our business is from power surges hitting the electonics in the different appliances, so this could also have been what has caused your repairs. On a 240 volt Oven, the only way to protect it from power surges is to have a whole-house surge protector installed on your house electrical panel. You still need to have individual surge protectors, above 2000 joules, for your appliances that are 120 volts. Good Luck, Appliance Specialists
Dec 09, 2010 | KitchenAid Architect® KEMS378S Electric...
The model number for my oven is MGR5765QDW The panel that control the oven does not work. What can be done to solve this.
You need a new control panel on this unit. We have parts for your Maytag oven. Please give us a call today at your earliest opportunity and I will give you the cost of this part. 972-859-0929 - We can put your part in the mail today so you can repair your oven this week. We hope this answers your question about your oven control panel. We look forward to working with you.
Oct 05, 2009 | Ovens
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 | Ovens
No power on the disply panel
replace the control clock its shot...you may be under warranty,,check the last page in owners manuel,,,
Dec 26, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
KitchenAid Architect Series KEMC308KSS
what if we have a voltage problem in the house, then it would be a lot cheaper to have a ceritifed electrician look at this beacuse there has to be a connection that the service man is overlooking than to purchace a new double oven at a tune of 1500.00
clll me 276-523-4434 David
Apr 12, 2008 | KitchenAid Architect Series KEMC308KSS...
Lower oven won't heat
it must be thermostat in bottom oven
Nov 29, 2007 | Frigidaire PLEB27T9DC Electric Double Oven
Maytag CWE5800A Electric Double Oven Logo
153 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
