Question about Jabra BT350 Bluetooth Headset Headset
Need help syncing to a LG 3850
No mannual and the phone can't find the bluetooth
    Problem Solver:
  • 6 Answers
Make sure you have headset off. Then hold on button until light stays solid blue. This is pairing mode.. Have phone search for bluetooth device.. use pairing code 0000 (4 zeros)
Posted on Mar 25, 2009
How do I connect the LG 750 headset to my phone
Must have headset "on". You need to sync it with your phone. . Check instruction manual of your phone how you should sync a Bloetooth device with it.
Apr 23, 2015 | LG HBS 750 Wireless Bluetooth Headset
I want to sync my LG Voyager phone with my Ford Escape. I have both the voyager and the voyager platinum. It works fine with the platinum but I can't even find sync on the regular voyager
HI Kkasiala it will work on the voygayer but you need to put the phone in discovery mode. Go to the bluetooth menu. Then hit the options when it comes up you need to pot the phone in discovery mode. Now once it is in discovery mode you hit search and let the phone find the car. The phone only stays in discovery mode for three mintues. It is that simple if you need more help please just ask for more help ok .
Dec 06, 2010 | LG VOYAGER VX10000 Cellular Phone
The instruction manual to sync my lg hbm-210 bluetooth headset to my phone
Usually this can be done my turning the blue tooth on and going into your cell phone and finding where it allows you to connect to a bluetooh device once there it will say sync with device, click yes or what ever term it uses, it may then ask for a code to sync the device it's usually a code of 0000 or 1234. Hope that will help you, it's the standard way most bluetooths are synced to cell phones.
Dec 02, 2010 | Cell Phones
Headset
you haveto have the bluetooth connectivity serch for th device. one the device is found then your phone can be linked to that bluetooth adapter.
Jul 15, 2009 | LG HBM-710 Wireless Headset
Can I sync my LG VU with Microsoft Outlook? If
Hi, you're right you'll need usb cable however bluetooth can be used as well.The usb cable is supplied with the phone. Vista use the new Windows Contact and Windows Calendar,but you can use MS Outlook if installed and you'll need MS IE v6.
Rate me if helped.Thanks.
Jun 18, 2009 | LG Vu CU920 Cellular Phone
Bluetooth pairing problem
if your phone does not pair with your jawbone then you might want check you phone's bluetooth visibility which can stop your phone from syncing even if your bluetooth is turned on. You can find it in bluetooth setting
Mar 17, 2009 | Cell Phones
LG enV2 sync to Plantronics bluetooth
Make sure you put the bluetooth in discovery mode, otherwise the phone wont be able to find it. I have a plantronics bluetooth and my env2 works just fine with it. Good luck.
Jan 30, 2009 | LG enV VX9900 Cellular Phone
Headset buttons
press both the volume buttons together for a few seconds... light should flash red & blue
Dec 06, 2008 | LG HBS-200 Bluetooth Headset
LG VU CU920 Sync Software
You don't need software to transfer files. Here is what you need to do.
Go into your phone settings.
Click on Connection
Select USB Connection Mode
Select Mass Storage (You MUST have a 1g memory card or larger in the phone)
Connect the USB to your phone and your PC
Viola! your pc should recognize it as a mass storage device. Put files where you want them etc.
Good luck.
Aug 26, 2008 | LG Vu CU920 Cellular Phone
Sync from LG CU500 TO LAPTOP
hi,
    just tell me r u trying to sync via Bluetooth or via data cable..if u r using any of the method than u need to install the drivers of that & than u can do sync with ur laptop.
Thanks
Gizmo1
Oct 16, 2007 | LG CU500 Cellular Phone
Jabra BT350 Bluetooth Headset Headset Logo
251 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
