Question about Pioneer DEH-P6800MP CD Player
I need to know how to install a pionear sterio into a 99 ford focas i have the wire harness and kit i just need to know how to dismount the factory sterio and what wires go where
  • 265 Answers
You need the factory car stero keys, its like a u bracket one slides in either side then you just pull it out with them.
as your wires there colour coded :)
Posted on Feb 21, 2009
Ford 150 xlt 1989 truck Wireing manuel for a pioneer mosfet 50 W times 4 deh 250 car sterio
check this out. 1987 91 Ford Series Stereo Wiring
If your factory wiring harness is still in the truck, you can uy a wiring harness that will make the job much easier.
Dec 04, 2014 | Car Audio & Video
2006 ford five hundred
You'll need the electrical wiring diagram for that. You can also buy a universal harness where you bought your sterio with the adapter kit.
Apr 01, 2014 | 2006 Ford Five Hundred
Getting ready to replace my factory radio in 99 ford expedition -- all the guts have been removed where the radio sits --what do i need to fix this to install new radio
At most stores that sell radios ( even Wal-Mart ) sell and installation kit for your car ( yes it'll fit alot of other different cars, You also need a wiring harness adaper for your car too as this gets all the wires connected correctly and comes with directions.
Dec 06, 2010 | 1999 Ford Expedition
I need to know how to install a cd player in my 1997 jeep wrangler sport.
My suggestion would be to buy a wiring harness and a dash mounting kit. After that unscrew or pull out the console/dash part thats around your factory deck. Then unscrew the bolts/screws holding the factory one in place. Remove it. Plug the wiring harness into the factory wire plug. Pull harness wires through the mounting kit. Attach the corresponding colored wires from the harness to your new deck. Slide your deck into the mounting kit and secure it in place. Most decks have little prongs that you can pry up to **** up against the mounting kit so it wont slide out without pushing those down (makes it more secure and harder to steal). Place deck with mounting kit into area factory deck was. Put the screws/bolts back into place tightly. Place console/dash part back on. You will need the mounting kit (99% of new decks are smaller than the factory). Wiring harness is optional but recommended.
Jun 22, 2010 | Panasonic CQ-C7105U CD Player
DEH-1200MP to '95 ford ranger i would like to know how to install it successfully and what sort of adapters and harsnesses i will need
Metra part numbers:
  • dash kit \ 99-5802
  • wire harness \ 70-5600
the dash kit comes with specific instructions and on the pioneer harness and metra harness just match all the colors up and your done
Jun 14, 2010 | Car Audio & Video
How do i connect the wires to put in new cd player in 95 aurora
ok you nee d to go to walmart or your closest car audio center and purchase the wiring kit for your year model vehicle the kit will have the plugs to plug into your factory harness do not cut your wires these plugs will have the wires labeled wire them to your new radio and it should plug in and play you may also need to aquire a face kit for mountring the sterio
Mar 01, 2009 | Dual XD-7500 CD Player
I would like to know what harness & Kit i need to install radio
Metra is the only manufacture I use.
#70-1858 Wire Harness
#99-3101 (with A/C) #99-3102 (w/O A/C) Kit
Also a mini gm to standard antenna adapter is required.
#40-GM10
Jan 22, 2009 | 1989 Chevrolet Beretta
Replace factory radio on 2002 yukon xl
all you gotta do is carfully pry the dash panel off (prying from the far left end is easiest) completely remove panel. then there are 2 clips that hold the factory sterio in place. push on the both clips while pulling the radio out. simply disconnect the wiring harness from the back of the radio. using an adapter avaliable at your local radio shop (scosche p/n gm02, mdarb and gm1483b) wiring harness, dash install kit, and antenna adapter. then simply match the colors on the new radio's harness to the adapter harness, crimping each connection with a "but plug". then simply follow the instructions included with the dash install kit to assemble the kit.connect the antenna adapter to radio, plug in all cables. test to see if everything works properly before the final install. install sterio into dash install kit, re installing kit where origional radio was. then simply put the panel back in its place by firmly pushing on it untill it snaps into place. then enjoy your new radio!
Dec 29, 2008 | 2002 GMC Yukon XL
Need sterio wiring diagram for 1997 1500 gmc p/u ,factory harness
DON'T REMOVE FACTRORY CONNECTORS!!!!!!!!!!!!!! Spend $15 and buy a wiring kit. It plugs right into your vechile wires and the kit tells you what wires are what. Splicing the wires will lead to headaces down the road!!!
Dec 08, 2008 | 1999 GMC Suburban
Swapping out a factory radio in a 2005 ford taurus
I don't know about the air bag but you need a special fit kit and wiring harness due to the climate controls being built in with the radio as one unit. The new kit separates the climate controls from the radio, and leaves a hole for the radio of your choice to fit into. These kits are expensive and I suggest you try to get one from ebay. Sorry, thats the downside of a Taurus.
Dec 07, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Pioneer DEH-P6800MP CD Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
