Question about Microsoft Xbox 360 Console
I just bought an xbox 360 and at first it worked fine, but now since i got registered online it locks up when i try to plan games...especially when playing grand theft auto 1v...the screen just locks up and i can't play any more. it won't play baja 1000 at all. i've only had this thing for 1 week and already we're having major problems...can anyone help?
  • 27 Answers
This happens a lot which is then i followed by the 3 red rings(red rings of death). is what you need to do is open your'e console, their are help video's on U tube for this. Once your is console open and you have the mother board taken out you need to remove the heat sinks which are on top of the chips. just un-snap the x clamps (on the bottom of the motherboard) and take off the heat sinks. unscrew the tabs on the bottom of the heats sinks and take them out. now take one of the heat sinks to a hardware store and find 8 screws about an inch long that screw into the heat sinks, also buy 16 plastic washers and 8 metal washers that fit onto the screws.also trey to find a BUTANE Torch this will save you from the expensive heat guns and work just as good. the last thing you need is Arctic Silver 5 which can be found for 5 bucks on eBay. now once you have this you need to lay your motherboard on a flat inflammable area. light the torch and make sure it is on the LOWEST setting and that the flame is about 3/4 inch long and make a sort on hissing sound. make shure the top of the chips are cleaned with a paper towel of the paste. start with the torch about 3 inches over a chip and keep it moving with a sweeping motion after about 30 seconds start to get close but not to close about an inch an a half away and keep making sweeping and circular movements for about 2 min. do not get to close. now move to the next chip and do the same thing. now after ur done with the chips move the torch away about 3inches and keep heat on both chips for another minute and let them cool for a total of 10 to 15 minutes. once they are cool to the touch clean off the metal parts of the chips with alcohol (I preffer acitone too) make shure they have a mirror like finish and put a very little glob of the artic silver on the metal chips and evenly flaten it out till it covers them evenly, make shure to apply enough! ( i used the side of a allen wrench, its less messy). now on the bottom of both heat sinks, clean them off with acitone or alcohol and scrub them very firmly to get off the grime from the paste. now put one plastic washer on each screw and insert them through the bottom of the holes surrounding the chips flip the mother board over and put the other 8 plastic washers on the screws and on top of these put on the 8 metal washers. then put the heat sinks on and tighten them down. once you put the mother board in the metal casing, plug it in(dont fully essmble it yet) now test out your xbox by pressing the little button on the ring of lights board and let it boot up a usual. If it works then ur done, but if 3 red lights start blinking or two red light start blinking you need to adjust the 8 screws. through the 8 holes in the bottom of the metal casing stick a small screwdriver in there and make shure they are all snug but not to tight and then loosin each one about an 1/8 of a turn till there just a little loose. keep testing and adjusting the screws till it boots up with the green lights.
THIS WILL REPAIR 3RED LIGHTS,FREEZING,NO VIDEO, 2 red LIGHTS. in most cases 1 RED LIGHT will be fixed
GO TO A HAREWARE STORE FIND THE FOLLOWING THINGS IF YOU DONT HAVE THEM
16 platic washers
8 metal washers(make shure all the washers fit snuggly around the screws and are very thin)
8 screws about an inch long that fit heat sinks
Butane blow torch, just a small one will do
small torx wrench kit. big and small flat and phillips head screwdrivers
Posted on Feb 21, 2009
  • Jared Harris Feb 22, 2009
    The torch step may not be needed to fix this
Just bought a used xbox 360 controller online. It is a wired controller. When i plug it in to the xbox I just get green blinking light
that means you have to many controllers registered to the system I have had this problem multiple times with my xbox if anything take a wireless controller or even a guitar hero or rock band guitar and take batteries out if that doesnt work then sync one of the controllers to a different xbox.
Aug 02, 2011 | Microsoft Xbox 360 Controller
Do i register my xbox to activate the gaurantee
Yes, you need to register your 360 for the warranty unless you plan on keeping your receipt for 3 years.
I don't think you have a time limit, but you should register it as soon as you can just in case something goes wrong. Registering your 360 also gets you the 30 day XBL gold membership trial.
Dec 16, 2010 | Microsoft Xbox 360 Console
I have purchased XBOX 360 Video Games
Well if u got a euro xbox 360 most american games WILL NOT work... =[ Ive tryed it myself
Sep 14, 2009 | Rockstar Games Bully: Scholarship Edition...
Pal Game Not working anymore - was fine b4 - still not damaged or
Try making sure you are not online it could be an updae that is not allowing you to access that.. If you do call support again ask for a manager or something that might get you better help.
Sep 03, 2009 | Microsoft Xbox 360 Console
Registering 2 yr service plan for Wii
  • I AM TRYING TO REGISTER A2 YEAR PLAN FOR A WII STATION THAT PURCHASASED AT WAL MART. PLEASE ADVISE ME ON HOW TO TO DO THIS. THANK YOU.
Jan 22, 2009 | Microsoft Xbox 360 Console
Xbox does not read any disc
try the lens cleaner CD then try to replace it if the cleaning did not work
Dec 17, 2008 | Microsoft Xbox 360 Console
Problem
i need help joining online
Feb 03, 2008 | Microsoft Xbox 360 Console
Not letting me play any games online
Apparently Microsoft have people working on this 24/7 to get it fixed its due to them not having enough server capacity. They plan to give all people subsribed to xbox live gold during this time a free xbox live arcade game.
Jan 07, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
87 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
