Question about Garmin nuvi 780 GPS
My garmin gps 780 does not take my music downloads
I load sd card into gps then connect to pc with proper usb port then computer does not show me nuvi drives/volumes.
so what do i do ?
  • ac2for2 Apr 16, 2009
    I go through the sync process, the unit seems to be accepting the data and after all files have completed synching, they are no where to be found when trying to playback.
I need to get zagat survey rating&reviews for my 2100 max
Posted on Feb 21, 2009
How instal maps on sd memori card for garmin nuvi 250
Insert the memory card into the memory card slot on Garmin Nuvi 250 GPS device. The memory card slot is located on the left side of the device. Push the card in until it clicks. (If you inserted a memory card that already has pre-installed maps and files, there is no further action required. The device will access the new maps based on the address you enter.)
Connect the Garmin GPS to the computer using the USB cable. The mini-USB connector will need to be inserted into the rear of the Nuvi 250; the larger end is inserted into the computer's USB port.
Locate the computer file that you want to download to the Garmin memory card. The Nuvi 250 is capable of reading JPEG formatted images and GPX formatted Waypoints and other mapping-related files. Right-click on it. Select "Copy."
Select the "Computer" folder from the computer's desktop Start menu. Double-click on the "Removable Disk" drive that represents the Garmin Nuvi.
Right-click in an empty space within the drive and select "Paste." The files have now downloaded to the memory card and will be accessible through the Nuvi 250 menu options.
Good Luck, and do rate the solution if got help
Dec 06, 2010 | Garmin nuvi 250 GPS Receiver
By connecting your garmin to your computer via USB, the sd card you have loaded in it will turn up as removable storage on your computer. You can treat it like a hardrive.
Without a cable, you can remove the sd card from the garmin and place it in a card reader hooked up to your computer.
Dec 28, 2009 | Garmin nuvi 255W GPS Receiver
My nuvi 765 will not turn on. Any solutions? How do you reset it? Vista will not even recognize the Garmin in the USB port. I'll assume that it's because it can't communicate to the OS. :) It just shows...
Resetting the Garmin Nuvi 765T: Press and hold your thumb or finger in the lower right hand corner of the screen while powering the unit on. This will erase all USER data, base and detailed maps will remain intact.
Connect your Garmin Nuvi 765T to your computer via USB.
Download Garmin's Communicator plugin and WebUpdater, both applications can be downloaded from their site. By doing so, this will load the necessary USB drivers to your computer, allowing the Garmin Nuvi to communicate and update firmware and software via the plugin and WebUpdater.
On Vista, the Nuvi 765T appears as Garmin Nuvi without the "T" as well, (a blue triangular icon also appears) it does not affect the ability to transfer files or explore the device in any way. If you load an SD card into the Nuvi 765T, it will appear as a removeable disk and assign it a drive letter, in my case H:
Dec 11, 2009 | Garmin nuvi 765T GPS Receiver
Nuvi 350 System Software Missing
If you have a nuvi 350 download the software to your computer and then load the software onto a formatted sd card. Insert the sd card and bootup the Nuvi 350. The sofware will then load onto the Nuvi 350. If you have a Nuvi 200 I would think it works the same but I have not tried it.
Hope this helps
May 12, 2009 | Garmin nuvi 200W GPS Receiver
How to access music from sd card
Hook the Nuvi up to your Computer via USB, then Sync one song from Windows Media player to the SD Card on the Nuvi (it will show up as "Nuvi Memory Card" in WMP) You only need to sync one song and it can already be on the card. This will create the link your Nuvi needs to see the Music. Once you disconnect all your SD music will be available.
Sep 09, 2008 | Garmin GPS
Loading mp3 files to garmin nuvi 350
The device is not recognizing the file name. The Garmin GPS will only recognize MP3 files. Ipod (MP4) and other media files will not play. Converting the files to the MP3 format will correct the problem.
Jul 25, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 310
When connected via USB, the unit should connect with activesync as "Mobile Device". Browse this device with explorer and you should see your (formatted) SD card as \Mobile Device\SDMMC\ or \Mobile Device\sdcard\
Simply drag and drop mp3 files to this folder. If you have a card reader in your computer you can move files to the sd card without having to have
the unit connected.
May 14, 2008 | Garmin nuvi 350 GPS Receiver
How do you get SD cards to play ???
Are the songs in MP3 format? Typically you connect the GPS to the PC using the USB interface and using Windows Explorer, drag & drop the MP3 files into the GPS's MP3 subdirectory.
Then on the main screen, select travel tools and then the MP3 player. Select browse and choose a song.
Please let me know if I can be of further assistance to you.
- Jim
Feb 22, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 650 660 680 6XX SD Card PNY 4GB SDHC Works
just got my A-Data 8GB card today and proceeded to load it up with 7.2GB of MP3s (nearly full capacity).
I timed with my wrist watch the bootup times and there was no difference in the boot times whether the SD card loaded up with MP3's was inserted in the unit or not. What did change is that even one minute after booting up the songs wouldn't show up in the "MP3 Player" window, it just had a blanked out browse button and a generic icon like it has when no music is loaded.
It took a full 90 seconds or so for the MP3 player to actually become responsive and show my selections, but after that it was working normally (from what I can tell).
Best Regards,
Jan 07, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 780 GPS Logo
197 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
