Question about Uniden DECT2085-3 Trio Cordless Phone
Uniden DECT2085-4WX: waterproof handset displays "Please Wait"
Waterproof handset appears to be stuck on "Please Wait" since I bought it a week ago at Fry's. Red charge light is on on the base. Can't get battery cover off because one screw was already stripped. Tried the "resetting handset" in trouble shoot section to no avail. Any suggestions?
Thanks,
Bob
  • Anonymous May 11, 2009
    I wish someone could tell me too! Help
Hey! I have the SAME exact handset. I HAD the same exact problem except this is what you NEED to do:
On the bottom on the handset, there are two "HOLES".
There's a smaller "rubberized" hole and to the right, a later "Double Layer" hole.
The a ball point pen and GENTLY push into the lager, "double layer" hole.
You will then hear a CLICK or a POP. THIS IS OKAY.
Your phone should now be placed on the charger for at least 25 hours prior to first use.
This procedure will ONLY need to be done ONCE.
This is necessary because the battery pack was factory installed by Uniden, therefore the installed battery is NOT "contacted" to the phone's circuit, yet.
WHEN YOU "CLICK" the SEAL w/ a BALL POINT PEN, you are "CLICKING A METAL CONTACT" inside the phone, which causes the battery to make contact with the phone.
After this, I AM SURE YOU WILL NOT have this problem again! :-)
HOPE THIS HELPS!!
Posted on May 16, 2009
I have the same problem. It worked once but now it says "please wait" and does nothing. It shows full battery but when you try to make a call, it goes dead. Any help?
Posted on Feb 01, 2010
CAN NOT CLEAR WATER PROOF DECT 6.0 PHONE TO REGISTER IT SAYS TO PUT ON BASE BUT I WANT TO REGISTER ON MY OTHER UNIDEN BASE BUT PHONE WON'T FIT ON BASE
Not stating the model number of your phone makes it a bit difficult because the process is not the same on all models. I am going to deal with the cordless main base only Remove any handset from the main base cradle. Then
On the waterproof handset Press and Hold the # sign until the Registering handset option shows then release it.Then on the main base, Press and Hold the FIND hs or Find or locator button for 5 seconds ( if there is no IN USE light on the base) or until the IN USE light come on, then release it. Hold the handset near the base and it will register.
Please note the Uniden waterproof handset could be a bit tricky to register and not knowing the model makes it more difficult. and you may have to apply other methods.
May 03, 2017 | Uniden Lands Phones
How can i get my dwx207 to comunicate with a phone line
that is an extension phone only will not work without the control unit e;i answering machine that plugs into phone jack on wall
Apr 12, 2015 | Uniden Dwx207 Dect 6.0 Waterproof...
Uniden DECT 1580-4WXT waterproof unit appears to be dead - will not charge or register with base unit. Just bought system at Sam's Club 2 days ago. The other 3 units work fine.
This phone uses inductive charging because of the waterproof feature. I suggest that you remove the
battery cover from the back of the handset, unplug
the battery, and then plug it back into the handset.
This solution worked for me.
Jun 21, 2010 | Uniden DECT 6.0 Cordless Telephone...
Redistration to other brand DECT 6.0 base failed.
DECT 6.0 IS JUST A MARKET NAME FOR DIFFERENT BRANDS, THE WATERPROOF DWX207 WILL ONLY WORK WITH UNIDEN PHONES, ONLY BECAUSE YOU WANT THEM TO WORK TOGETHER DOES NOT MEAN THEY WILL WORK TOGETHER...
May 22, 2009 | Uniden DECT 6.0 Cordless Telephone...
How do you register a waterproof phone (TWX977) to a TRS9585
Not sure if you still have this problem, but...
Basically go on you base unit, and hit "MENU/SELECT". Scroll down to "REGISTER HANDSET" and click "MENU/SELECT". On your waterproof handset, hold the "#" key until it displays "REGISTERING HANDSET". And voila! After that finishes, your waterproof handset will be good to go!
Feb 03, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
I have a TWX955 cordless phone. one of the recievers is a waterproof phone. Instructions said the rechargeable battery was already in the phone. (all of the other phones required me to install the battery...
Take the cradle for the waterproof phone and plug it into the outlet close to the answering machine base. Hold the waterproof phone in one hand, with the other press the "menu" button, press up to the "register phone", then press "menu" again. The answering machine base should say "registering phone". Once it does press the "#" key on the waterproof phone and it should say registering phone. When they beep the waterproof phone should be working. The reset instructions in the owners manual may work if you move the WP phone and cradle close to the base. I stumbled onto this method after reading about a newer model. As i took the WP phone downstairs the # key would activate the registering feature but would when I walked back upstairs. So i figured Id take both downstairs and BAMMM, it worked. Good Luck all! BTW mine came with a battery, and uniden probably hasnt figured this out either.
Dec 26, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
UNIDEN DWX207 SERIES ITS WATERPROOF
Same thing was happening to my phone...Welcome! Please wait... After at least 40 hours of charging I was getting a little fed up. I picked up the handset, took a ball point pen and pushed the "activation" area on the bottom the phone...heard a click...now it is working. I don't think the tiny pin that comes with the phone activates the phone properly.
Jul 24, 2008 | Uniden DECT 6.0 Cordless Telephone...
Adding speed dial nos to uniden waterproof handset
I found the model no, on the Uniden website DSS 7805WP and down loaded the manual.. there were no instructions .. but i showed where the phone book icon was .. and once inside the phone book the process was the same as the handset that came with the answering machine.
Jun 19, 2008 | Uniden Tru-Digital Expansion Waterproof...
Uniden DECT2085-3 Trio Cordless Phone Logo
694 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
