Question about GE JE1650AA/WA/GA Microwave Oven
Microwave JE1650AA 002 Light, timer, panel display and beeper all work but the microwave nor the turntable work.
  • 368 Answers
Hi worzelh,
When a microwave suddenly stops heating food, but still appears to run (the control electronics and light are usually a separate circuit), it's usually a defective/dead magnetron.
The turntable _may_ or may not be on the same circuit as the magnetron, that's hard to say without a wiring diagram or schematic.
Prices for replacement/repair will vary, you will need to find out what that service costs in your area before having enough information to decide on repair or replacement. If you tell the repairer that you suspect the magnetron, they should be able to quote you a fairly accurate estimate.
When my first microwave lost it's magnetron (~20 yrs ago), it was 5 years old at the time, and the cost of buying a new oven was only a little more than the repair - but I had the repair done anyhow. Since then, we've replaced the entire oven instead (twice). Newer ones may have more power/less energy wastage, etc.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Posted on Feb 21, 2009
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Panel works. Timer works. Light works. Does not heat. Makes no sound. turntable does not turn.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 25, 2011 | Thermador MBBS Microwave Oven
All leds, timer, fan etc working but microwave will hot even heat water. Control panel, turntable and light inside oven works also.
The problem is one of three things, the magnetron is defective "common issue" or the high voltage capacitor and diode may be a factor, repairs could be close to a new microwave oven.
Feb 20, 2011 | Whirlpool MH6130XEB/Q Microwave Oven
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
Jan 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 03, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Blt In Microwave runs but NO SOUND and shows NO SOUND on control panel
Hello Marlenes,
A 1996 microwave that is still operating at all is the exception rather than the rule..It is possible to resolve the beeper problem but the costs associated with it probably aren't worth it. To get >11 years use from a microwave without major component failure is great.. I would just live with it.... (Your call)
Regards
Oct 11, 2008 | GE Microwave Ovens
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Jun 05, 2008 | Kenmore 80809 Microwave Oven
Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 10, 2007 | GE JVM1350BW/WW/AW/SY Microwave Oven
Microwave Ovens Logo
132 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
