Question about Dryers
Frigidaire dryer wont heat
Runs but no heat
  • May 11, 2010
    Model number of the dryer? Need to know if it's gas or electric to get you going in the right direction.
  • 547 Answers
Http://www.partstap.com/ please go here for diagram thank you please rate me change heater element
Posted on Feb 22, 2009
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer wont heat up
Good Afternoon Friend,
I understand that you are having trouble with your Frigidaire Affinity dryer not heating up. There are some things that you are able to try. First check to make sure that the lint filter, the ducting, and the outside vent, are clear of lint and not constricted in any way. Second, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. Once power has been restored, run any cycle. If you are still noticing that your dryer is not heating, I suggest contacting your local authorized technician for further assistance. They should be able to diagnose your dryer and determine why your appliance is not heating. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire Affinity ATF7000E Front Load...
Basement flooded,Dryer runs but wont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 26, 2011 | Frigidaire GLGR341AS Gas Dryer
WHERE IS THE HEATING ELEMENT FOR A FRIGIDAIRE FER341ACO
it is located on the back inside of the dryer, here is a step by step:
http://www.ehow.com/how_4866523_fix-frigidaire-dryer-heating-elements.html
I do not know why you want to replace the element but if the problem is no heat then here is another website that can help,Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Mar 19, 2011 | Frigidaire Electric Dryer
My dryer still runs but it's not drying. It's also not heating. Can this be fixed by replacing a part?
yes, here is a site that can help, Tim:
Nov 28, 2010 | Frigidaire FER211A Electric Dryer
My frigidaire electric dryer wont heat up, only
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Dryers
I'm looking for the two house fuses mentioned in the trouble shooting section of the dryer manual; runs but wont heat. MODEL # is FEQB400FSI
they should be in you fuse panel in the house .how ever you can check the heating element and the thermal fuses located in the cabinet of the dryer
Sep 05, 2009 | Frigidaire FEQ1442ES Electric Dryer
My Frigidaire model GLEQ2152ES0 will run but the air does not get hot.
Need to order the resistant heater, use the mothel of the unit to make the orther
Aug 11, 2009 | Frigidaire Electric Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
193 people viewed this question
Top Dryers Experts
