Question about Acer SMS3000BOX2LB CPU for ASPIRE 3003, PRESARIO M2000, AVERATEC 6110, AMD Mobile Semron 3000+ Laptops
Speakers My speakers isn't working. The music appear to be playing, there's no sound coming from my speakers on my desktop computer.
  • alienz999 May 11, 2010
    First you need to determine if it actually is your speakers. Unplug them, and try with a headset, if you hear sound, you can safely assume the speakers may be broken and need to be replaced.
    If you don't hear sound, check your sound settings in control pannel.
    Star>Control pannel>Sound and audio
    Is it on mute?
    If not you might want to uninstall and reinstall your audio drivers.
Speakers wont come on
Lets start with the basics.
1. Make sure the power cord to the computer speakers are plugged in. Check at the wall and make sure the power cord is connect to the back of the speaker. If there is a power button make sure it is pressed in the on position. Make sure the volume level is turned up.
2. Check the computer and make sure the sound is not on mute. Turn the volume level up from the computer settings.
3. Try playing some music. If you hear sound you are good to go.
4. If you are not able to hear anything than continue. I would suggest plugging your speakers into you cell phone. Try playing some music from your cell phone.
5. If music plays through the speakers from your cell phone, something is wrong with the computer. If no sound plays with your cell phone then something is wrong with the speakers.
6. If worse comes to worse bring your computer into a computer store. Tell the salesman you want to buy a new set of speakers. You just want to make sure your computer works with the speakers before you buy them.
7. If all else fails, ask a local tech you trust.
May 25, 2015 | Audio Players & Recorders
During play my music no sound come out
If you have power to the speakers, try them on other devices like a DVD player, Radio, etc. If they work on other devices; they are good to go. The problem is your Computer settings. Go to the Speaker ICON at the lower right of the desktop screen. Right-Click on the ICON and go to the Volume Control Options. Look there for your speaker settings and make adjustments.
Jan 15, 2014 | Audio Players & Recorders
Crackling sound whenever i play music or video on my computer
Make sure that your speakers/headphones are plugged in all the way to the jack you're using, and that there isn't any interference on the line. This is probably the issue.
Nov 16, 2012 | Computers & Internet
Can't get sound out of my speakers although sound registers as playing
Check that your computer isn't muted and the volume on the speakers is up. Check that the plug for the speakers is connected correctly. Check to see if the sound card that the speakers are plugged into is set as the default in the control panel. Is there any sound coming out of the front port (earphones). Try another set of speakers.
Jun 06, 2012 | Computers & Internet
When I have my skype phone plugged into a usb port and not using it I do not get sound from the computers speakers, all the sound comes from the phone. The result of this is I cannot leave the skype phone...
to play music from you phone on the computer you have to open a media player i use VLC (http://www.videolan.org/) then just hit open select your skype phone and then select the song and play it back on the VLC media player.
Jul 31, 2009 | E-Machines eMachines Desktop PC
I have no sound on my computer-emachine T3095
The type of speakers you choose for yourself have several factors that come into play:
your location (does your sound have a volume limit such as a noise ordinance in an apartment complex)
What are they being used for (music, games, movies, work, voip chat)
Your music genre preference (heavier bass means you will want an actual bass)
sound quality (are you an audiophile or does sound quality not truly matter to you.)
I got a decent pair of 5.1 surround sound speakers for just under 100$ by logitech, but a buddy of mine purchased a 300 dollar set that shakes his room when he plays FPSs
Jun 25, 2009 | E-Machines eMachines T3830 PC Desktop
Computer speakers do not work on new Dell computer
Check Bios settings to be sure audio is enabled, then go to control panel, click on sounds, and make sure sound is not muted
Apr 14, 2009 | Dell Inspiron 530 Desktop Computer...
Panasonic Home Theater SC-PT760
This is not a problem, this means that your system is working. Polar Express was recorded in Surround Sound with separate tracks for each speaker channel. In most movies you will find that the rear speakers will only play certain sound effects so that it appears they are coming from behind you (gun shot, train, fireworks). Most of the diaglouge will come through the center channel and music/effects through the front left and right, with bass coming from the subwoofer.
Now, you can still hear more from the rear speakers if you like this enveloping effect, or if you like your music coming from all directions. There are Sound Effects options to have the front and back speakers always playing the front track, there is Dolby Pro Logic II that turns stereo sounds (like many TV shows) automatically into 5.1 Surround Sound, and you can also individually change the volume of each speaker.
These are all explained on page 29 of your owner's manual under Sound Options. If you need specific button to button help, let me kow.
Jun 29, 2008 | Audio Players & Recorders
Sounds not coming out of my speakers
what are you using to play your music ?
May 03, 2008 | Manhattan 1100 Computer Speakers
No sound
check the plug that goes directly to the altec box. or it could be the wire is the culprit..
Apr 08, 2008 | Altec Lansing VS4121 Computer Speakers
Acer SMS3000BOX2LB CPU for ASPIRE 3003, PRESARIO M2000, AVERATEC 6110, AMD Mobile Semron 3000+ Laptops Logo
368 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
