Question about Goodman Heating & Cooling
Starts and stops repeatedly
Before it even stats it will repeatedly ignite at 30 second intervals for about 12 times before starting.Then the heater will start up and after about 1 minute will turn off again It will repeat this process until the temperature level of the thermostat has been reached. After the thermostat level has been reached it will blow cold air though the ducts.
    Novelist:
  • 189 Answers
I need more info!
Have you checked the diagnostic indicator?
Some possibilities are....
If the buner lights than rapidly goes out....You have a dirty flame sensor..... Remove the sensor with a 1/4" nutdriver. This sensor is located under the burners. It has "ONE" wire hooked to it. unplug the wire. pull ou the screw. Carefully remove the sensor. Clean it with a small piece of sandpaper. reintall. This should give you heat.
Pressure switch.....If the burner does not light. It can be a variety of problems. Check your flue pipe for obstructions.
Heat anticipator in the t/stat
Posted on Mar 08, 2009
Heater stopped working. Blower comes on for about 30 seconds then turns off
On the passenger side of the dash thereis a fuse block. Find the HVAC blower fuse. Start the car, turn on the blower, and check for power at that fuse. If power disappears when the blower stops than you have a bad ignition switch.
Dec 13, 2012 | 2000 Chevrolet Malibu
When calling for heat, no flame, burner doesn't attempt to ignite, blower starts after about 30 seconds blowing cold air.
If the unit has a induced draft motor on it it then it shoul turn on first when stat is calling for heat. If it does so then in about 30-45 seconds the igniter whether hot surface or spark should try to light pilot. If this is not happening then you probably need to replace the igniter. Hope this helps. Thank you
Apr 15, 2011 | Heating & Cooling
Our whirlpool gas dryer burner only lights one in four or five starts. The igniter always glows but the gas is not always started. Once started the burner stops after 10 or 12 minutes. What should I do?
Call the fire department. That puppy is gonna explode!
Seriously the average time a flame stays on is 25 seconds. 12 minutes would cause a Chernobyl type meltdown. If the burner is lighting intermitantly that is the coils7329710.jpg, feel the coils, the one that is hot is the intermitant one. This 4 wire t-stat could be wank,many have fallen in the past.38bdb0e.jpg
Mar 09, 2010 | Dryers
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
Cannot get original Tstat wiring to work on a furnace.
The symptoms you describe make no sense at all but just connect the wires by color, R = red etc. leave the jumper between Rh and Rc, red goes to Rh, Blue would go to C. C = Common. If at any time you short Red to Common, damage can be done, usually a blown fuse or blown transformer. So unplug the furnace while doing your connections. By the way, the new t-stat you bought uses batteries and the blue wire should not be used. Good luck and comment back if you need more info.
Jan 09, 2010 | Honeywell Programmable Thermostat Heater
I HAVE A CARRIER GAS FURNACE APPROXIMATELY 10 YEARS OLD. IT WAS WORKING FINE LAST FALL. I JUST STARTED USING IT AGAIN AND NOW ITS STARTS UP AND THEN STOPS, STARTS UP AND THEN STOPS? IF I PLACE THE HEATER...
you may need to replace the thermostat or the thermostat batteries if applicable. To replace the thermostat follow the instructions on the new thermostat. Make sure to set the thermostat to the gas setting(see instructions) this should cure your problem. Good Luck on the repairs
Dave
Jan 05, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
The igniter glows and the burner starts but shuts down after abou
one of two things it could be the flame sensor or the control board for the entire unit
Oct 02, 2009 | Goodman GMS90703BXA Heater
Ran out of diesel on a 2002 dodge ram 2500 cummins...need to know how to bleed the system
just bump the ignition without starting it let sit for 20 seconds oruntill you hear lift pump shut off then shut off ignition and repeat do it 2 or 3 times should start then cummins is a self priming system has been for years even in semi trucks
Aug 10, 2008 | 2001 Dodge Ram 2500 Truck
Heating & Cooling Logo
120 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
