Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
BOUGHT AND REPLACED A HONEYWELL ROUND THERMOSTAT AND THE HEAT WILL GO ON BUT WILL NOT SHUT ITSELF OFF WHEN THE TEMPERATURE GETS TO THERE. IT KEEPS RUNNING TILL I SHUT THE THERMOSTAT OFF. I FOLLOWED THE DIRECTIONS AND MADE SURE IT WAS WIRED THE SAME AS THE OLDER ONE.I HAVE TRIED CHANGING THE SETTINGS ON THE NEW ONE AND THEN BACK BECAUSE IT DID NOT WORK. I JUST DO NOT GET WHY THIS THING WILL RUN TILL THE COWS COME HOME AND WILL NOT SHUT OFF AT THE TEMP IT WAS SET AT.
  • 700 Answers
Look at the old thermostat and in the middle of it theres a arrow that is pointing at numbers that is called a heat anticipator. then on the new thermostat make sure that its set the same.
Posted on Feb 22, 2009
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat Lock Cover
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Honeywell Electronic Programmable...
Honeywell TH8320u Vision Pro 8000 Digital keeps calling for heat
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
Heatman101
Dec 28, 2009 | Honeywell Programmable Thermostat Heater
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
How to use a round circular honeywell thermostat? I turned round casing to mark heat , no heat on??
If you turned the ring and the pointer moved, then you are using the thermostat correctly. Turn the thermostat up above room temperature (the temp on the bottom of the thermostat) Make sure all your switches are on, and that the fuse or circuit breaker is also on. If you still do not have heat after verifing all these things, then it is most likely a problem with the heating appliance.
Also, if it is a heating and cooling thermostat, make sure your lever is in the heating mode. Hope this helps
Sep 17, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell Thermostat RTH7400D
The thermostat will not cut off the A/C until the thermometer reading gets to 76.
If there is not a heat source near/behind the thermostat which is causing the thermometer to read higher than actual room temperature, it sounds like the thermostat thermometer is out of calibration.
There are ways to calibrate it, but much to involved to go into here.
One solution is to just set the thermostat at 80, knowing that it's really set on 76.
Another solution is to replace the thermostat.
Charlie
Aug 14, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Fan on but no heat
I never liked the user un-friendliness of the Chromatherm, I would suggest finding a thermostat that you can understand and operate. Yes the Chromatherm is a good one, but so damned hard to figure out. Stay away from thermostats that still use mercury. Good Luck!
Oct 20, 2008 | Honeywell Heating & Cooling
Thermostate temperature setting wrong
Are you saying that the temperature over-shoots it's setting by 5 degrees? If so and if the thermostat has an inticipator device in it you can adjust it. After removing the cover on the thermostat, look for a little brass triangle on the lower right hand side. There will be a scale with numbers on it and they are very hard to see. This device heats up prior to shutting off the thermostat so it will not over-shoot by more than a few degrees. Move the brass triangle either up or down and let the heater cycle a few times. If the temperature swing gets worse, go the other way next time.
If the thermostat is not heat inticipated, there will be a small "Dip" switch where you can adjust to a specific degree of under-shoot.
Visit the Honeywell website and you can pull up the installation/owners manual for your model. www.honeywell.com
Nov 27, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
374 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
