Question about DCS RGS-305 Professional Gas Kitchen Range
DCS 304 RGA, Igniters ok. 3.9amps, no oven or broiler. No part #
No oven or broiler gas. Igniters read 3.4 and 3.7 amps. not opening gas valve. No part number for this valve anywhere. All top burners work.
Suspect it is the valve. Was trying to find a 305 parts manual. Suspect valve is the same. So far no part # or oem cross.
Art
Did you ever find a solution to this problem? I think my RGA 304 has the same problem, and plan to go looking for that dual valve today... Peter
Posted on May 17, 2010
Long preheat & strong gas order. Sometimes the oven will heat up & sometimes it wont. The broiler does not heat up at all.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Mar 11, 2011 | Frigidaire FGB24L2A Gas Single Oven
In broiler mode, igniter glows red, gas valve opens and burner lites. In bake mode I here a click from a relay but the igniter does not glow and gas valve stays closed.
Nov 23, 2010 | Ovens
Model # 36275621302 stove not maintaining proper temperature. Takes long to bake. Broiler comes on ok. Bottom burner gas comes on and ignites in preheat but then the igniter glows hot but the gas doesn't...
Oct 28, 2010 | Kenmore Ovens
Oven will not light-broiler works
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jul 26, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Oven flame will not go on. Broiler flame working
May 31, 2010 | Jenn-Air JGS8850BDS Stainless steel Gas...
The Oven Won't Light
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
May 08, 2010 | Dynasty DGRSC 30 Gas Kitchen Range
Gas broiler and bake over do not work, top burners work.
Could be a board problem or the safety valve. Hard to diagnosis without being there. I'm leaning towards the board if both both burners won't light...hope this helps...
Nov 30, 2009 | Kitchen Ranges
Have a GE gas range. Broiler doesn't work while
First clean the terminals at the control and check for tight wires at the incoming terminal block. Check the neutral wire for a good conection. If the ignitor reads less than 3 amps it does not have enough resistance to open the gas valve. Turn the gas off. Put a clamp on amp meter on the broil ignitor wire. Turn the broiler on. If less than 3 amps.replace the ignitor.
Sep 30, 2009 | GE JGBP28 Gas Kitchen Range
BROILER WONT COME ON
If your BAKE function works, but the BROIL does not come on, more than likely you have a bad igniter on your broiler. The igniter is a glow bar type that comes in two basic shapes. One is round, and one is square. The round type igniter should draw between 2.7 to 3.2 amps of current to be considered good, while the square type igniter will draw 3.2 to 3.7 amps. The reason it is important to mention this is because, it is not uncommon for an igniter to still glow. and be bad. The igniter is designed to draw the required amount of current in order for the gas valve to open. Once the valve opens, you have ignition. This is a designed safety feature that prevents free-flowing gas from accumulating without ignition. An easy way to check is to remove the broil cover and turn the broiler on to see if you have any activity out of the igniter. If the igniter does not glow at all, a resistance reading can easily determine if the igniter is bad. It should read avery low resistance if good. If the igniter glows, but the gas valve never opens, take a current reading. If you can provide me with your EXACT model number (located somewhere around the oven door/lower drawer opening, or on the back of the range) I can track down a part number for. I hope this information is helpful to you.
Jan 27, 2008 | DCS RGS-366 Professional Gas Kitchen Range
Broiler Works/Oven Doesn't
Jrzy, even though you can see the bake igniter glowing, that doesn't mean it's good. Igniters actually get weak (unlike a light bulb that simply burns out). It's hooked up in series to a safety valve (the valve that allows main gas into the oven) which actually reads the amps flowing through the igniter. If the igniter is weak and the amps are too low, the valve won't open up. Replace your igniter and you'll be cookin' with gas again. Tip---> before you unscrew your old igniter, put a little liquid dish soap on the threads for lubrication. This'll ensure it comes out with no problems.
Sep 14, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
DCS RGS-305 Professional Gas Kitchen Range Logo
917 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
