Question about Maytag Dryers
Thumping noise when running---suspect the blower wheel
It only blows air thru vent when making the noise---got the front off---but not sure how to get the cover off to access the blower wheel
    President:
  • 2,992 Answers
Before you can take off the fan housing cover to get at the blower wheel, you have to get the shroud off. On some models there a couple of long screws you can take out and it's simple. On others you need to take off more parts. But either way it's not a bad job for someone who can wield a screwdriver. You should also have a 5/16-inch nutdriver or small ratchet and socket handy.
Here's a website with some good pictures of the innards and procedures for getting to the fan:
http://www.applianceaid.com/maytag-dryers.html
If you find this helps you out, please take a moment to rate the solution. Thanks for asking here!
Posted on Feb 21, 2009
Whirlpool Cabrio Dryer MOD WED5600XW0 making whirring noise
take the bottom panel off,you'll see a metal duct that the lint filter slides down into,there's a blower wheel behind the duct,if the wheel cracks or gets loose where it connects to the motor shaft it can make this sound,start the dryer and listen to see if the noise comes from there.if you can't tell unplug the dryer,pull out the lint filter and then take out the screws that hold the metal duct in place and remove it,now you can see the blower wheel,spin the drum by hand and see if the blower wheel moves with the drum and belt.if it looks fine stop spinning it and grab the wheel and see if it feels loose,if it is you will be able to tell.also while you have the duct off clean it out,you should take it off at least once a year and clean it out,then vac out the cabinet and blow out your vent line with a leaf blower if it's long,just remove it from the back of the dryer,stick a leaf blower into the vent line and blow it out.go outside first and make sure the outside duct is clear,no cage or anything that will block the lint from blowing outside.if the blower wheel is ok then the noise could be the belt roller or belt pulley,thety sell a kit with all the parts together but usually when someone says it's making a whirring sound it most likely is the blower wheel.hope this helps.
Nov 13, 2013 | Whirlpool Dryers
Mastercool has loud thump when blower comes on....
Are you sure the blower wheel is not loose on the shaft. There is a set screw to tighten it to the shaft. How are the bearings?
Jun 10, 2013 | Mastercool 67680 Evaporative Cooler Air...
I have a trailer with a duo therm ac..the outside fan is coming on but nothing is blowing thru the registars
Not sure where your located, so check that unit didn't freeze up on you. Make sure evaporator and condenser coils/fins are clean and run on fan only to aid in thawing them out. Once you see condensation running off roof good, try using cool again and see what happens. When they freeze up, airflow gets restricted through unit. The outside fan and blower wheel for forced air inside are attached to same motor, so if fan is working, blower wheel should be turning as well unless it is broken, or allen key has come loose on clamp around center of blower wheel. Other possibility is that the blower wheel is turning but forced air ducts have blockage at inlet, which will require letting ceiling assembly down to inspect, or removing cover on roof and screws at front evaporator and opening it up. Make sure power is off during inspection.
Sep 12, 2011 | Dometic Rooftop RV Air Conditioner
My outside a/c unit runs but no air is blowing thru my vents. Is the blower motor or could it be a r
Hello, if no air is blowing thru the vents then it could be a bad blower motor, a bad run capacitor, or a bad control board. If the motor is getting voltage from the board and it will start by spinning the blower wheel by hand you capacitor is bad. If it does not the motor is shot, however if you do not get voltage from the board but there is voltage to the furnace then the board is bad.
Jul 01, 2011 | Intertherm Heating & Cooling
Air conditioner isn't blowing any air through the vents. Compressor runs outside but blower isn't blowing air through room vents
Hello, kindly check your air blower if is running if not u need to call a service technician to check it, if it is running and blow some air, i guess you don't have enough freon to your condenser, (freon is a liquid like a liquid nitrogen that running thru the aircon to create a cold air.Thanks
Apr 25, 2011 | Heating & Cooling
The dryer rattles in the motor area also the dryer takes a long time to dry.
You have a bad blower . This piece slides onto the motor shaft and pulls the heat thru the drum and out thru the vent hose . It is easily replaced ( and inexpensive if you do it yourself ) by removing the front of the dryer .
Mar 20, 2011 | Maytag Dryers
Dryer is heating but not blowing air
when was the last time you cleaned the dryer?try removing the vent line from the back of dryer to see if any air is blowing out,also is the dryer noisy?you could have a bad blower wheel.you need to clean out the duct that the lint filter slides into and behind that duct you'll find the blower wheel,also vac out the dryer where the motor is and if the vent line is a long run from the back of dryer to the outside i use a leaf blower to blow it out,make sure the outside vent isn't blocked with anything before you blow the vent line out,send model number if you need help getting the blower wheel part number if that's your problem,you should clean the dryer at least once a year so you don't have a fire,good luck
Apr 11, 2010 | GE Profile Harmony DPGT750EC Electric...
My dryer is taking forever to dry clothes. Very damp and a lot of condensation when I open the dryer. It's model # MDE508DAYW
Good day,
Sounds like the vent system is badly blocked, the blower wheel has stripped off it's shaft, or there is a lot of lint in the blower wheel/lint screen area.
1. Remove the vent hose and see if your getting air moving thru smarty. Maytag moves a lot of air. If O.K. test dryer with vent off for performance. Clean or replace vent hose as needed.
2. Blower wheel sheared on it's shaft. You have to remove the front panel to see if the wheel is loose. Old version had 2 screws on the bottom of the front panel. Remove, disconnect door switch wires and remove. New style (no screws on bottom) requires a putty knife forced on each corner of where the top meets the front. About an 1 1/2 inch in from the edge. Force in, releasing clip, and pulling the top of the front panel toward you. Lift off.
Should the blower wheel be bad, replace but make sure the area between the blower wheel and door filter are cleaned.
Feb 28, 2010 | Maytag Dryers
Dryer doesn't get hot
unplug dryer,take bottom panel off and take out the lint filter,remove the blower wheel duct and clean out the lint,while you have the cover off read out the thermal fuse located on top of the blower wheel housing,remove one of the wires when you read it out, if the air isn't moving outside it will pop the fuse.vac out the inside of dryer and if you have a shop vac switch it on blow and blow off all the lint off of the motor,you should do this once a year so you don't have a fire.if the fuse is good,read out the ignitor,sensor and gas coils.when you get it running go outside and make sure the air is blowing out strong,if it isn't you could have a blocked vent line,if it's a long run use a leaf blower to blow out the vent line.
Nov 28, 2009 | Kenmore Dryers
2003 Ford Explorer. A/c blows cold, but not from front of vents
I have the 03 Expy with continuous rear air unit "clicking" or more accurately flapping of the air damper while the plastic gears in the 2L2H-19E616-AA grind away into toothlessness. Ford designed this unit to find the end of travel by jamming the motor to a stop and monitoring the current to determine when to stop applying voltage. That would probably be fine if the gears were designed to handle the jammed torque or the motor did not slip out of groove and continue turning and cracking the plastic gears.
There are two white colored boxes, one is for the temp plenum door, the other the upper/lower air flow. To be sure, do what I did, turn on the ignition, rear ac/heat and listen for the obnoxious click/thump as you move the temp control from full heat to full cool, you will know which part. Disconnect the electrical connector, four bolts and it is out!
Go to your dealer, part should be about $60 or less, look on line, lots of dealers sell for this or less on internet.
Apr 06, 2009 | 2003 Ford Expedition
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
