Question about RTO 2 Person Spa Hot Tub 8 Hydrotherapy Jets 3/4 Hp Pump
Electric supply to whirlpool bath
Is it ok to have the power socket under the bath,as i carnt get the plug and lead through the wall because of the huge box on the plug lead,or does the socket have to be outside the bathroom. thanks
  • 547 Answers
Remove box then put through wall put it back on other side
Posted on Feb 21, 2009
My avr went off while playing and is not switching on again. shows no sign of power supply
Dear
check power cable
check power outlet or the electricity breaker at home
if all is ok
check internal fuse and be careful to take off the AC plug from the wall socket before opening the device.
hope this resolve the problem
if all is ok
then the AVR needs to be serviced.
Good luck
hope this helps
M.Mathis
Apr 29, 2016 | Audio Players & Recorders
Hi im looking for power leads for a 180s technis hi fi
What do you mean by power leads? Are you talking about the line cord that connects the unit to the electrical wall socket? Do you have a picture? Or a model number? What country is this for?
Mar 08, 2016 | Computers & Internet
My NAD C372 integrated amp was working normally everyday. One day, on pushing in the "Power On" button, it did not light up. No response at all.
It could be anything from a blown fuse from a power surge to a shorted capacitor ijn the power supply. There are fuses in all amplifiers. Locate it and test it with an ohmmeter.
Dec 16, 2013 | NAD C372 Amplifier
Gateway desktop
check at any other power socket or plug any other working equipment on the same wall socket to check if the power is ok in the wall socket
if all ok then either your power cord to the computer is not properly plugged in the computer or the computer power supply may not be working.
you may then require technical assistance of computer mechanic.
Aug 30, 2012 | Gateway Computers & Internet
Unplugged tv and when plugged back in doesn't come on
Hello
If you have unpluged the TV from wall socket and it doesn't come On when you plug in back, either its power supply system or its stored memory has the trouble. Look whether the power indicator light coms on. Ensure that the main power ON/OFF switch at the front panel of the TV is ON. If the front panel power switch, control switch of your wall socket, and all the other electrical connections are OK, and still the TV doesn't come ON, surely the power inverter baord has the trouble and must be either repaired or replaced. if the power indicator light comes on, and your TV doesn't come ON by remote POWER ON button, the settigs that were stored has vanished, and resetting it to its original setting is necessary. Follow its manual for 'initial setup" and so all the recomended setting there. OK.
Apr 11, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Hi I have a jacuzzi. I would like to connect it DIY
You can get 2 types of Jacuzzi baths, 1 with just a pump which just jets the water via a small pump or 1 with the pump and elements that heats the water aswell as pumps the water through the jets. Because the 1 with the elements has a higher amp rating you need to run a cable from your distribution board to your bath but the 1 without the elements you will be able to tap off the nearest socket to the bath, you will be coming from your socket to a fused spur outlet, it would be better to get a switched fused spur outlet as you will be able to isolate the bath when not in use just by switching off the switch. from the spur outlet you will be wiring it into your motor on the bath, it should say the rating of the pump in amps on the tally plate of the motor or on the manual. For example if it says the motor draws 2 amps you will be putting a 3 amp fuse into your spur outlet so if there is a fault with the motor the fuse will blow instead of tripping the whole socket circuit. All jucuzzi baths has to be connected to the RCD side of your distribution board. If you are tapping off a socket don't worry about the RCD because all sockets should be on the RCD anyway, to check that the socket is connected to the RCD plug something into the socket you are tapping off of and press the test button on the RCD, the RCD should trip and while this is tripped check the lamp or whatever you plugged in shoud be off. The Fused spur should be fitted outside of the bathroom.
Mar 29, 2011 | Whirlpool Home
My maytag electric dryer has worked perfectly fine for 10 years. today i unplugged the dryer and did some work on the wall. when i plugged the dryer back in it tripped the breaker. could it be the dryer or...
You already unpluged before the wall work, so the problem is isolated from the dryer from its plug. Take off the wall socket to inspect since it may have damaged. If you have the voltmeter, measure each pair of the terminal. they should have a voltage at least 110V since it is three-phase voltage. If there is no voltage then just replace the socket. Make sure to turn main power off when you do the replacement.
Apr 27, 2010 | Whirlpool LER5636P Electric Dryer
How to connect the inverterto acmains?
Battery to invertor should be quiet clear. Attach the positive then the negative lead.
There needs to be a special socket in the wall. Buy a normal three pin socket. Go to the mains. Take the line coming in and connect it to the L ('Live') marked pin. It is left one. Now take the other pin and trace it back to where electricity was originally going. What you have done is basically placed a socket in the line. See diag below:
Now take a plug. see diag and connect so that it has live going into the invertor and invertor supply coming out.
So basically you have looped the supply thru the invertor.
Be sure to read the manual. Certain invertors may have other wiring.
Electricians are cheap. Get one. It will be worth it, in case you are unsure.
Cheers
TeaCii
LiveOnline
Apr 22, 2010 | Inverter 500 - 1000 Watt DC to AC - Safe...
I have a front load machine that when you cut it on and it cuts off without finishing the cycle. Not everytime just a few times a week. When it sits cut off for a few hours then it will start working...
Suggestion: Remove the plug from the wall & open up the machine. Check to see if all the connections are plugged in well; especially the one harness leading to the motor. Before that check your washer plug for loose connections; also check your wall socket with another electric gadget - could be a loose connection somewhere.
Feb 10, 2010 | Whirlpool Washing Machines
Power supply light is red
This issue occurs when the external power supply has detected a fault. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply itself. The power supply will turn itself off if one of the following conditions is true:
  • There is too much current
  • The voltage is too high
  • The temperature of the power supply is too high
Under these conditions, the light on the power supply turns red.
Step 1: Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light may indicate that the power supply is too hot or that it has already overheated. If the power supply light is red, follow these steps:
  1. Make sure that your Xbox 360 console is turned off.
  2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall socket.
    For more information about how to disconnect the Xbox 360 power supply, click the following article number to view the article in the Microsoft Knowledge Base: 906205 (http://support.microsoft.com/kb/906205/ ) How to connect and disconnect the Xbox 360 power supply
  3. Let the power supply cool for several hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall socket during this time.
  4. After the power supply has cooled for several hours, reconnect the Xbox 360 Power Supply to the console and to the wall socket.
If the power supply light is still red, go to step 2. Step 2: Make sure that the power supply is plugged in correctly loadTOCNode(2, 'whattotry'); If the power cord is plugged in to an extension cord, a surge protector, or a power strip, the current or voltage that flows through the power supply may not be correct. Make sure that the power supply is plugged directly into a working wall outlet.
Step 3: Plug the power supply into a different wall socket loadTOCNode(2, 'whattotry'); Try a different wall socket. Ideally, plug the power supply into a wall outlet that is elsewhere in the house.
Jul 16, 2009 | Microsoft Xbox 360 Console
RTO 2 Person Spa Hot Tub 8 Hydrotherapy Jets 3/4 Hp Pump Logo
161 people viewed this question
Top RTO Pool & Spa Experts
john h
old fart58
Craig Butler
Craig Butler
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
