Question about Whirlpool LER4634J Electric Dryer
Dryer hets to hot
My coil went out and i replaced it and the two limit switches at the same time. now the dryer dryes real good but gets to hot. clothes r to hot to touchwhen they r done. could i have crssed wires whem i hooked the switches up? i also cleaned the vent tube and the vent hood.
  • 40 Answers
I would check the temp at your outside vent while the dryer is running temp should anywhere from 180 to 225 at the high end and should cycle down from there so u should get like 225 then will drop down to 90's then come back up to the high temp and check on all temp settings. if it does not your operating thermostat may be bad go back over the instructions that came with your thermostat kit to double check your wiring the tech sheet should be in the control panel with the wiring diagram.
Posted on Feb 23, 2009
I sent my unit to a repair company in town because the dryer was getting really hot during a cycle and shutting itself off. They gave it back after just cleaning it out. Now when I try to run the drye
You have I think two issues. One is a clogged vent/vent hose. You need to have the vent system cleaned out. If the unit is not getting hot with the vent off, you probably have a defective heating element. This probably went out due to the clogged venting system.
Feb 04, 2015 | Frigidaire Dryers
How I cant start my gas dryer
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Feb 02, 2015 | Kenmore Dryers
Dryer starts and flame ignites three times, but wont flame up after that. did a lot of research and assumed it was the coils. replaced them and still same issue. so i pulled out the ohm meter and set
It is easy to procure the wrong thermostats, sensors, safety switches. They can physically look like just the same old ones, but the voltage limits can be off.
Nov 07, 2014 | Dryers
Thermal limiter
dirt in your tube going outside or remove back pannel and check for dust near your elaments
Nov 16, 2013 | GE Dryers
How how long should it take to dry a load
Your problem is going to be 1 of 2 things either the dryer is not tumbling o you're not getting adequate air flo out of the drye which basically suffocates the drye which basically suffocates the dryer element preventing it from drying, you can check this by turning the dryer on and finding out where the vent is outside and verify airflow is good. My guess would be the second is the problem
Aug 09, 2012 | Roper REX4634KQ Electric Dryer
Maytag Neptune MGD9700A The heater was getting warm but not drying hot. I replaced the coils (servos) first. This did not solve the issue. Then I replaced the Thermistor, the thermostat and a second...
remove venting from back of dryer and run a test load with clothes if it dryes clothes with venting off then its a venting problem.....remove from back of dryer
Jan 31, 2011 | Dryers
I have an armana electric dryer that turns on fine but stopped getting hot. It is 110vac. I tested all the limit switches and thermal fuses and they all have 120 vac thru them when dryer is running. I ran...
Does your volt meter have a buzzer on it that will make noise if it does set it to that with the dryer unplugged and retest the heater and thermostats if it buzzs its good if it doesn't there is your problem and the dryer has 220 volts coming to it 110 for the motor and 110 for the heater but hope this helps and good luck. if everything test good and nothing it could be a bad timer where one of the points is bad or the switch in the motor that goes to the heater is bad and all you can do with that is replace the motor.
Jan 07, 2011 | Amana Dryers
Igniter comes on gas valve only opens for short time . is this the high limit switch
The problem is definitely not the high-limit thermostat but rather the gas valve solenoid coils sitting on top of the gas valve assembly. There are two of them, one with three prongs and the the has two, and held by a bracket. They must be working fine when cool but eventually fail when get hot. Simply replace the coils and the dryer should start heating. Just make sure to disconnect power to the dryer before attempting any repair works.
Aug 27, 2010 | Amana Dryers
Kenmore Gas Dryer won't heat!
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up ( no continuity ) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryers air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, can not be re-set, must be replaced if is open (no continuity between pins).
Jul 11, 2009 | Kenmore Dryers
Whirlpool LER4634J Electric Dryer Logo
79 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
