Question about Acer Aspire 5610-4648 Notebook
My acer 5920 notbook doesnt film in hd
My acer 5920 notbook doesnt seem to film in high def and i was wondering how to film in hd
  • RescueTechLA
    RescueTechLA May 11, 2010
    It won't film in hi-def. You're talking about the built-in camera right? Those are def. not HD. Did yours say it was?
Does the tv Sansui have high definition mode?
No televisions work in the mode they were made in, you can't make them 'less def' or of course make them 4K. The deciding factor though is the signal coming to the television. On my cable box, I have channels with three digits and I have channels with 4 digits. CTV in standard def is 051, but Hi Definition signal is on 1051. Not all content or films are transmitted in HD.
Dec 06, 2017 | Sansui Televison & Video
Are acer monitors unable to pick up HD video inputs?
There are two types cable to connect to LCD Monitor. VGA and the other is DVI,ight need DVI cable it has flat pins and is larger than the VGA small round pin models.
Dec 21, 2009 | Acer X193W LCD Monitor
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Recording HD channels
well you would need to hook up cable box to dvd recorder. the only draw back first off is one you cannot get hd onto a dvd. you can down scale and it will seem a little cleaner than standard def but of coarse it will never be high def. I'm not to familiar with the motorola boxes but if they offer dvr's in your area i would suggestgetting one you can record all channels then afterwards transfer them to a outside device. but as i said before high def cannot fit onto a dvd unless you plan to copy one movie to 6-7 disc. Just keep in mind a standard high def channelcan only fit 2 max on one freq due to the amount of data transfer as opposed to 10 to 12 standard def digital channels
May 08, 2009 | Televison & Video
Toshiba DVD/HD Mod:#sd-H802A ''Cannot read high def dvd movies...
Hi there.
If it's just a case of you not being able to watch HD films, but you can watch normal dvd's, then it sounds like you need to reinstall your High Definition video codec.
What software are you using for your dvd playback?
Tim
Apr 22, 2009 | Computers & Internet
Does my acer aspire 5920 have voice recognition
no the laptop doesnt. but vista has! rabish not very good but I'd recommend the software Dragon for voice recongnition
Mar 24, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 5920 SPDIF problem
You need to go to audio properties and change the output when using headphones. SPDIF is the high def signal that you would use if you had a home theater set without HDMI
Dec 20, 2017 | Computers & Internet
CLEAR PICTURE ON MY 42
Dear LADY DAWN,
In order to get true high definition quality, you would want a high definition source. There really is not much else you can add to make your picture clearer, provided you have it hooked up with the best type of cables possible.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jul 21, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
DBRH197
It only has a standard definition stb in it, the unit doesnt support high def. sorry, ****-face
Jan 11, 2008 | LG DBRH197H DVD Player/HDD Recorder
Acer Aspire 5610-4648 Notebook Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
