Question about Hayward Heatpro 100,000 Digi. Thermostat Heat Pump
Frost all around outside unit coils
Hayward digital heatpump purchased new 2 years ago, has white chalky build-up on outside coils (when not in use). When i tried to heat spa, I noticed icy frost forming all around unit ( &inside on copper), which caused unit to stop working properly. I sprayed the coils with garden hose water to melt, which caused normal operation to resume. Is there any thing I can do, besides service call?
    Guru:
  • 462 Answers
Well Its a little complicated and unless you understand the heat pump /refrigeration cycle and the need for defrost and how the defrost is limited and initiated, well Id say yep...you need a pro.
About the only thing I can suggest you check is the initiate termination thermostat (assuming your Heat pump works with one of these). It will be identified by 2 wires going to it and it will be clamped on the line (Not brazed on or screwed on). Now there will also be a reversing valve which has 4 tubes going to it and 2 wires. and it could have high, low, pressure switches that have 2 wires. This thermostat is usually mounted 1/3 to 2/3 way down on the coil and is suppose to be mounted on the "U - Bend" of the out door coil tubing. It usually resembles a pancake and will have a wire or metal clip that holds it securely on the coil U bend. Make sure it hasn't fallen off or come loose. This can cause your heat pump to miss its required defrost.
You can try this also. Some defrost timer boards have a set of "test pins" you put them together with a screwdriver or a piece of wire for a few seconds to initiate a defrost. It defeats the time logic in the board It should go on into defrost and stay in until the coil is cleared of frost and or about 10 minutes which ever comes first. If it comes out right away it may be the termination switch I talked about above. It could also be the board. To check out the thermostat locate the 2 wires going to it from the board. pull them off the board and retry it. Sill goes right out of defrost then jumper the 2 wires together and try it again. If it still comes out this time it most likely the board. If it stays in defrost either time when removing the wires or jumping the wires its the thermostat.
Hope this helps you. If so please rate me as high as you can. Thank you for using fixya and good luck.
Hope this helps you
Posted on Mar 25, 2009
  • Farley Redfield
    Farley Redfield Mar 26, 2009
    Oh and by the way frost on the outdoor coil during heating is normal.
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
I purchased danby dehumidifier less that 1 year ago and p1 is on most of the time. What can I do?
According to your Owners Manual:
P1 is part of a normal function of your dehumidifier. When your compressor is working it will build frost on the evaporator coils. When there is enough frost on the coils the unit will go into a P1 deicing program. This deicing cycle will last anywhere from 15-45 minutes. Once complete it will automatically resume normal function. The cooler the room the more often this function will turn on.
If you think it's still staying ON to long, contact Danby Consumer Help 800-263-2629
Hope this helped you.
Apr 28, 2011 | Danby DDR607EE Dehumidifier
Whirlpool model ER8AHKXRQ01 purchased two years ago is not cooling - worth getting fixed?
Hello and Welcome to FixYa!
The Poor cooling that you are facing is caused due to the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing/opening the panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer that is exactly the thing you quoted. Such a frost build-up usually shows a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed/designed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (usually a bi-metallic switch) The defrost heater Also you need to clean the dust, lint from the condenser unit by using a condenser brush or a vacuum cleaner to remove all the dust from the unit (it is usually located at the back of the refrigerator). If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. If the problem still persists and the above quoted techniques/tips didn't work,You may need a qualified appliance repair technician to further diagnose the problem. In most cases, there are very small problems that are causing the device to mal function. The device should be physically examined in order to locate the exact fault. If the repair job is done by the professionals, the device would work for a long time without any further trouble. So I would suggest you to get that diagnosed before buying a new one.
Best of Luck,
Concerned.
Sep 17, 2010 | Whirlpool Refrigerators
Defrost cycles needlessly for extended time period
Without knowing what the problem was with the old board, you're not going to be able to figure much out, I don't think.
Did you check that temperature sensor I mentioned? You will have to pull the top off to get access to it. Normally found connected to one of the tubes for the coil, silver in color, with 2 wires connected to it, near the bottom of the base of the unit.
Dec 13, 2009 | Heating & Cooling
Hello, I have a 1.5 ton rudd ac/heat pump
Your outside unit is not defrosting. You need to call a service tech to check it out. Defrost board sensor or low on gas. Also you amy have an outside tstat that is not working correctly. Rus
Dec 06, 2009 | Ruud UAMB042 Air Conditioner
Whirlpool ED22PQ, 21.7 cubic feet. Freezer is not cold. Sounds like something is trying to "click on", but nothing happens.
unplug your freezer. Move the fridge 1 foot from the wall. Wait 15 minutes and plug again . if it works good , ok . if not you will need to call the technician who will check the starting relay and the compressor
Sep 12, 2009 | Whirlpool ET4WSKXS Top Freezer...
Heat pump outside unit not running
It sounds like your defrost board failed. You will need a tech to replace it. With that model it may have a parts warranty but you pay labor(?)
Jan 18, 2009 | Amana PTH123B25AJ Heat Pump Air...
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heat pump condinser freezing.
YOU HAVE ONE OF SEVERAL PROBLEMS , FIRST AND EASIEST TO REPAIR KEEP FILTERS CLEAN REPLACE EVERY 30 DAYS , #2 LOW CHARGE WILL CAUSE ICE ,# 3 A FAULTY INTERMITTENT FAN CONTROL SWITCH ,THIS WOULD BE MY # 1 GUESS SINCE I HAVE SEEN IT MANY TIME OVER THE YEARS , #3 WOULD BE A FAULTY DEFROST CONTROL BOARD OR SENSOR , THE REASON I LEAN TOWARD THE FAN CONTROL IS YOU SAY THE ICE IS ALSO IN THE INSIDE UNIT AND THIS IS MOST COMMON WITH RESTRICTED AIR FLOW OVER COILS AND SOME TIMES THE FAN SWITCH WILL CAUSE THIS PROBLEM THE DISCHARGE TEMPERATURE IS DIRECTLY RELATED TO THE TYPE OF UNIT ,TYPE OF REFRIGERANT IN SYSTEM AIR BALANCE CFM OF FLOW MANY VARIABLES IN THIS EQUATION,CANT SAY
Dec 20, 2007 | Ruud UAMB Air Conditioner
Hayward Heatpro 100,000 Digi. Thermostat Heat Pump Logo
119 people viewed this question
Top Hayward Garden Experts
Craig Butler
Craig Butler
Bill Boyd
Pushkar Singh
Pushkar Singh
Level 1 Expert
Are you a Hayward Garden Expert? Answer questions, earn points and help others
