Question about HP LaserJet 1320 Printer
MY 1320 LASER PRINTER PRINTS TOO LIGHT. RAN SELFTEST CONFIGURATION. I REMEMBER ON SELF HELP IT SAID THAT THE COURIER PRINT SETTING SHOULD BE SET AT DARK NOT REGULAR AND I DON'T KNOW HOW TO DO THAT. I PUT NEW CARTRIDGE IN. IT USED TO PRINT A LITTLE DARKER BUT NOT DARK AS I WOULD LIKE FOR MY TRANSCRIPTS. ALSO PRINT DENSITY SAYS 3 IF THAT MEANS ANYTHING.
  • HP Master
  • 13,433 Answers
  • Ekse Feb 21, 2009
    If the print is light or faded then the toner supply is low. Redistribute the toner. Detailed instructions for this are on page 152 on the manual, or page 162 if we are looking at the page count that showsn on the pdf reader
I have a HP Laser Jet 1320 (Model # Q5927A, if that helps) that will not print at all; sometimes I get a printer error message but most of the time nothing. I deleted and re added it several times. I...
I suggest you hold the green button down for about 10 seconds, press again quickly, so that you get a self test/configuration page and then check the status log on this page to see if there are any error codes.
I would also check that your settings on laptop & make sure the printer port is USB if that is what you are using. If that is ok then try another print cable.
If still not working then I would suggest that the printer has a defective formatter board.
( Putting the board into an oven at 180 degrees for 8 minutes make fix it. Sit the board on four small balls of wrapped up oven foil ) This has worked for me on a number of occasions. You should only do this as a last resort.
Jul 17, 2011 | HP LaserJet 1320 Printer
Have HP LJ 1320 printer, while printing any document in Execel it prints twice, can u help
When you click file print and the Print options page pops up. Look near the bottom of that page and set it to 1 as the number of prints to print.
Would you be so kind as to rate this session, using the thumbs up on the right.
Thanking you
damnor01
Apr 05, 2011 | HP LaserJet 1320 Printer
When printing reports off, all the document does not print to the right of the page. whats the answer to fixing this
Hi
Does print is faded or it prints clear? If faded, just get your cartridge and shake it well to distribute evenly the toner. If prints clear, preview it first before printing and maybe the other print area you want is not included when printing. Just set the print area.
Jan 11, 2011 | HP Laser Jet 1320 Printer
I HAVE A HP LASER JET 1320 PRINTER . HOW CAN I GET IT TO PRINT A LITTLE DARKER.
first your printer connection reset,cover open to set paper correct setting,next manuvel move paper
thats it.
Oct 27, 2010 | HP LaserJet 1320 Printer
My hplaserjet 1320 prints multiple copies when printing Excel Doc
The best thing to do as a starter is:
1. uninstall the print driver THEN
2. download the latest version from the manufacturer and install it
This rules out the driver as the cause of the problem
1. Go to printers
2. Right Click on the Printer HP Laserjet 1320
3. Click on Printing Preferences
4. Click on Advanced
5. Double Click (to open) on Paper Output
6. Ensure that COPY COUNT is set to "1"
If it is already set to one, trick the system a little:
1. set it to 2 and save that setting
2. then go back in and set it to 1
Good luck
Mar 15, 2010 | HP LaserJet 1320 Printer
Alignment/selftest sheets print whenever I turn on the printer.
its up to you if you want to make self test..but you can cancelled it if you dont want to make self test..
Mar 07, 2009 | HP DeskJet 920c InkJet Printer
I have a 1320 printer that just prints blank pages
If ink is ok , then you may need to reinstall printer drivers.
Unplug printer USB.
Go to control panel>>Installed printers and delete existing printer installation.
Reinstall printer driver software using printer CD.
Mar 02, 2009 | HP Laser Jet 1320 Printer
Hp 1320 prints blank pages
My HP 1320 printer is printing blank pages and it will not even print test pages etc
Nov 03, 2008 | HP LaserJet 1320 Printer
HP Laserjet 2300: Prints only one copy
can you print the configuration page or selftest?
Jul 11, 2008 | HP LaserJet 2300 Printer
HP LaserJet 1320 Printer Logo
41 people viewed this question
Ben Johnson
