Question about Garmin nuvi 205W GPS Receiver
My garmin nuvi 205 lost all recently found and all favorites.
All memory was gone when I turned on the unit this AM All was OK when I shut it down the night before.
  • davidhol Apr 11, 2009
    Twice in the last few weeks I have lost all the recently found items. I have a StreetPilot 530 and I can't tell whether the recently found items are stored in RAM (kept in memory with an internal battery) or flash memory (not needing a battery). It would make sense if they were stored in RAM and the internal battery was going bad.
    If I plug the c530 into my computer and poke around I can't tell where the data is being stored so I can back it up.
    Favorites are also gone. One way around the problem is to find the GPS coordinates of my favorites, using Google Earth, and save them in Extras using POI Loader. Those items saved in Extras are still there even when the Recently Found items disappear.
  • 8 Answers
SOURCE: HELP THE GARMIN NUVI 200 battery died and my favorites are GONE
Try charging the battery (that happened once to me and it worked).
Posted on Jul 22, 2008
bunnydawg
  • 5158 Answers
SOURCE: garmin nuvi 205 can't find satellites
you can get the manual at www.garmin.com
you'll also need to get yourself a usb cable... the normal end for the computer and i believe the other end is called a mini b connector.
Robert
please take a moment to rate this solution.. thanks
Posted on Feb 02, 2009
bernardlunda
  • 318 Answers
SOURCE: My Garmin nuvi 205 will not give voice prompt
The germin nuvi 205 can be pre loaded specific data on the route and has voice. i dont know if yours has been pre loaded, with 3.5 navigation data.
Posted on Mar 19, 2009
RPFinney
  • 385 Answers
SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
Posted on May 19, 2009
  • 156 Answers
SOURCE: Remove a map to make space on my garmin nuvi 205
I would reset the whole unit to factory specs & then load map.
Posted on Jul 06, 2009
Tip
Garmin Nuvi 200W Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 200 and 205 series GPS unit.
I hope that helps.
______________________
Backup & Restore Nuvi Favorites here.
Download Nuvi 200W Manuals here.
Download Garmin WebUpdater here.
on Apr 18, 2010 | Garmin nuvi 200W GPS Receiver
Hi my garmin nuvi 205w has gone into some kind of reset loop. when i power on it shows the garmin logo, then loading maps, then does 2 beeps and shows the garmin logo again and repeats this sequence. any...
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
  3. On the next power cycle, the Favorites will beread from 'temp.gpx' into the non-user accessible memory area on theNuvi where they are actually stored.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
Ifpossible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
Jan 07, 2010 | Garmin nuvi 255W GPS Receiver
I forgot my pin on garmin 205
Try this. You'll lose all your favorites and anything else you have entered though.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Dec 20, 2009 | Garmin nuvi 205 GPS Receiver
Tip
Garmin Nuvi 200 Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
I hope that helps.
Download Nuvi 200 Manuals here.
on Apr 17, 2010 | Garmin nuviĀ® 200 Car GPS Receiver
Tip
Hard Reset your Garmin Nuvi 205W (Mark 2b)
Hard Reset of your Garmin Nuvi 205 and 205W
I hope that helps.
on Mar 22, 2010 | Garmin nuvi 205W GPS Receiver
Entering and deleting addresses in "Favorites"
Probably go to the favorites menu and manually add it there? if not, when you click the address when it ends up in the recently found, is there no menus that say, maybe , add to favorites?
May 25, 2009 | Garmin nuvi 205 GPS Receiver
Tip
Garmin Nuvi 205 Favorites Backup and Restoration Procedure Would you like to...
Would you like to back up a copy of your Garmin Nuvi 205 Favorites and Waypoints?
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
I hope that helps.
on Mar 22, 2010 | Garmin nuvi 205 GPS Receiver
Tip
Perform a Hard Reset of your Garmin Nuvi 205 (Mark 2a)
Perform a Hard Reset of your Garmin Nuvi 205 and 205W
I hope that helps.
Tip
How to Perform a Hard Reset of your Garmin Nuvi 205 and 205W (Mark 2a
How to Perform a Hard Reset of your Garmin Nuvi 205W
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It is generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Your Favorites:
I hope that helps.
Tip
I hope that helps.
_______________________________________
Download Garmin Nuvi 205 Manuals here.
Garmin Nuvi 205 Favorites Backup here.
Garmin Nuvi 205 WebUpdater here.
on Jan 15, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
1,304 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
