Question about Canon Pixma MP450 All-In-One InkJet Printer
Says paper jam but there is none. pixma mp450
My pixma mp450 says "the paper is jammed Clear the paper and press ok" and the alarm light is solid yellow. There is no paper jam as far as I can see.
  • Anonymous Apr 19, 2009
    When it feeds ok, it says it has no paper. So i press ok to try again and it says it's jammed
  • SSO-JOAT Apr 19, 2009
    Any copy or print job causes a paper jam. When loading paper, the printer immediately feeds the first sheet half-way in, then stops and says the printer is ready. When a print job is sent, the printer feeds that first sheet all the way through (without any hang ups), then feeds the second sheet halfway in. The rollers continue to run for several seconds, but the paper doesn't move beyond that half-way mark. It then stops and gives a paper jam error. I have to pull the half-fed sheet out forcefully, then it will clear the error if there is no paper in the tray, but when placing fresh paper in, the exact same process repeats.
    I've shut it off, unplugged the power, and reset the printer a half dozen times without changing this error. This problem started right after changing an ink cartridge and running a single cleaning cycle. The first attempt to run a pattern check started this error. Attempts to make a copy or run any other print job produce the same error.
Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
Posted on Mar 11, 2009
If you want to try to disassemble it, this might be of some help:
https://picasaweb.google.com/114737437459997878992/HowToDisassembleTheCanonPixmaMP450?authuser=0&feat=directlink
Posted on Dec 31, 2011
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 544 Answers
Try a printer reset
Unplug the power cable for 20 seconds
Plug in piower cable
This should reset your printer
Posted on Feb 22, 2009
Printer says paper jam, but there is no jam. Everytime it is to print, the alarm light comes on and says to remove paper jam. No jam is there!
Printers use either small 'flags' to detect paper presence or passage or a photo-optical interrupter. The first can be damaged by a previous jam and the latter can fail.
If you have ever used label stock or another adhesive-treated stock, you may have residue from these and without disassembling the printer, you won't be able to determine the exact cause of the erroneous paper-jam error.
Do a search on your brand and model to see if there is a site or tech with specific knowledge of your printer.
Jan 20, 2011 | Canon Pixma MP450 All-In-One InkJet...
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Printer stopped working. I just added new ink supply. Alarm light flashes. Printer status says "service error 6A00"--"check printer" "cancel printing and press the ok button." None of this works. And I...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Apr 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Have cleared paper jam, but alarm light remains on. there is no paper jammed anywhere. please advise
1. Close the tray deck properly.
2. Hold the print key for a moment ...approx 5 secs...it will solve the problem or else restart it.
Oct 19, 2009 | Canon Pixma MP450 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Persistent paper jam error
How old is your model? This could be dirty rollers. See how I fixed that problem on this site: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html
Let me know if this helped. OK?
May 30, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam alarm in, but there is no jam.
try to reset the printer or turn it off for 1min and then back on. That should work.
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma MP450 All-In-One InkJet Printer Logo
1,120 people viewed this question
old marine
old marine
