Question about SanDisk Sansa e260 MP3 Player
Sansa 260 Won't Let Me Navigate Back to Main Menu
I navigated to the radio menu of the device for the first time and it's not giving me an option to navigate back to the main menu.
I've tried turning it off and pressing every button on the damn thing and it still doesn't give me an option to navigate back to the main screen? I'm trying to run the battery down and then recharge it.
Any other suggestions?
  • 8,596 Answers
The power button is also the Menu button - click and release once while the player is on, and see if it gets you back to the main menu. Or press the left arrow key and see if it will get you back to hte previous menu.
-Tha Mp3 Doctor
Posted on Feb 21, 2009
How to change ip address on hp 5500ps
There are three ways of configuring IP address on any HP Printer:
A.- Using the control panel
B.- Using the web server
C.- Using the Jet Admin Utility
We'll deal with the contro panel setup.
To access the contro panel menus
1. Press OK (Check Mark) button once to access MENUS.
2. Press Up Arrow or Down Arrow buttons to navigate the listings.
3. Press OK (Check Mark) button to select the appropriate option.
4. Press Return to return to the previous level.
5. Press OK (Check Mark) button to exit the menus
So to configure IP address:
Press Check Mark
Navigate to the CONFIGURE DEVICE Menu using Down Arrow (the menu scrolls, so you may use any combination of Up/Down arrows)
Navigate to the I/O Menu
Navigate to the EIO 1 menu
Navigate to TCP/IP
Navigate to BootP entry
Press Check to disable it (Off)
Press return
Navigate to IP Address, press Check
Use Up/Down buttons to change the address, check to move between octets.
When finished, press Return
In the same way, enter Mask and Default Gateway
Press Return until you are out of the Menus.
Done
Jul 30, 2014 | HP DesignJet Office Equipment & Supplies
Netflix wont connect on my apple tv and i'm connected to the enternet
  1. Test the Internet connection on the Apple TV
    1. From the main Apple TV menu, navigate to Trailers.
      • If you don't see Trailers: Select Movies, then In Theaters.
    2. Select any title and click Play. If trailer plays, the device is connected to the Internet.
    3. If you are unable to connect to the Internet, you may be having network connection issues.
  2. Restart the device
    Restart your device by unplugging it from power for at least 10 seconds, then plug it back in and turn it on with the power button. Restarting the device is often enough to restore your ability to connect to our service.
  3. Disconnect Apple TV from your Netflix Account
    1. Navigate to the main Netflix menu inside the application and click Logout.
    2. Select Yes.
    3. You will be returned to the Apple TV's main menu, at which point the device has been successfully disconnected from your Netflix account. You may select Netflix to sign back in with your account information or connect as a different user.
  4. Troubleshoot your Internet Connection
Oct 23, 2013 | Netflix
How to reset filter settings
there is a filter counter option in the settings menu that will give you the option to reset the counter. once in this menu navigate to the "Used Time" option and there wil be a reset button there.
Apr 10, 2013 | Sanyo PLC-XP100L Projector
How to find mtp
Hi Gkirank
In order to find the MTP modes, different devices has different ways. For exxample in SANSA the MTP mode can be viewed in MAIN MENU -> SETTINGS -> USB MODE -> MTP or MSC.
Like wise you need to navigate the menu items, please refer the manuals in which you will get clear picture.
Dec 28, 2010 | Audio Players & Recorders
I forgot my memory card password .. plz help ??? thnx
you can use the Nokia 5310 for many different storage and entertainment functions. The mobile phone has the ability to save all of your large files (such as pictures) to a memory card instead of using up all of the built-in device storage. You may run into issues with the memory card if it is locked. This can happen if you buy a used card or if you forget the password that you programmed into the card at the time of purchase. You can unlock the card with a default password, or you can delete the option that requires the memory card from requiring a password at all.
Instructions
          Unlock the Memory Card
    1. Power off the Nokia 5310. Put the memory card into the memory card slot on the Nokia and then power on the device.
    2. Click the "Menu" key down from the main screen of the 5310. Select the menu option for "Extras."
    3. Navigate the cursor down to the bottom of the page. Press down on the option for "Memory Card."
    4. Click the "Options" selection that appears as a screen prompt. Move through the options until you reach the "Unlock Memory Card" option. Click the cursor to select the "OK" option.
    5. Manually enter in the unlock password with the 5310 keyboard in the password box. When you cannot remember the password, the generic passcode is "12345" or "1357."
          Delete the Memory Card Password
    1. Power off the Nokia 5310. Put the memory card into the memory card slot on the Nokia and then power on the device.Click the "Menu" button down from the main screen of the 5310. Select the menu option for "Fun & Apps."
    2. Scroll down to the selection for "Gallery" and then press on the "OK" key. Navigate to the "Memory Card" screen selection and then press on "Options." Move through the list until you reach "Memory Card."
    3. Press down on the option for "Delete Password" when the screen pop-up menu loads. Verify that the words "Memory card will unlock now, do you wish to proceed?" appears. Select the option for "Yes" to verify the unlocking.
    4. Navigate to the password box and manually type in the default passcode. When you cannot remember the password, the generic passcode is "12345" or "1357." Select the "OK" key when you are complete to remove any passcode requirements from the 5310.
Dec 08, 2010 | Nokia 5310 Cellular Phone
The player is stuck in FM. How do I navigate back to music?
Press the menu/power button to bring up the main menu.
Nov 20, 2010 | SanDisk Sansa e260 MP3 Player
Lost my internet, wont load so need settings please
  • Navigate to your cellular provider's website or call its customer service line. Access the "Support" section of the website or ask for the technical support division. Find the "Access Point," "MMS" and "Wap Gateway" settings and write them down.Power on the HTC phone and then press the soft key on the left side to bring up the main menu screen. Scroll down through the menu and highlight the "Settings" option. Press the square button at the center of the phone to access the settings menu.Choose the "Connections" option from the settings menu. Scroll down through the new list that will appear and choose "GPRS." Highlight the "New" option and press the center button. Choose "Connects To Internet."Scroll down to the "Internet" heading and choose "Change." Key in the Access Point that you wrote down earlier. Scroll down and press "Done.Navigate back through the menu to the "GRPS" option. Press "New" again, and this time, choose "Connects To Wap." Choose the "MMS" option. Key in the MMS settings you wrote down earlier.Return to the main menu screen and then select "Messaging." Highlight "MMS" and press the right soft key to bring up a second menu. Choose "Settings," and then choose "MMSC Settings."Press "Edit" and enter in the "MMS" settings again. Scroll down to "WAP Gateway" and enter in the information you wrote down earlier.Power cycle the phone by turning it off and then back on to complete setting up the WAP settings.
  • Oct 01, 2010 | HTC Cell Phones
    SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
    NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
    Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
    Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
    Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
    2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
    See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
    Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
    A service section installation INF is invalid.
    Just to be clear, no special drives are necessary. MSC mode will work out of the box with just about any OS. MTP mode will work as long as you have WMP 10 or 11 installedFirstly, lets explain MSC mode and MTP mode a bit.
    MSC stands for Mass Storage Class. When your player is in this mode, the computer will see it the same way it would see a flash drive, as a removable disk. It will assign it the first available drive letter, as well as one for the memory card (if applicable). This is probably the more popular of the 2 modes, and is a more "open source" type of standard. Most comptuers detect the player in this mode without a problem.
    MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsofts solution to connecting digital players and cameras to a window based platform. MTP mode must be used in order to transfer ANY Digital Rights Managment (DRM) protected content. Services like Rhapsody and Napster will only function in this MTP mode.
    SanDisk has provided both of these modes at the users options on MOST of the entire Sansa Line mp3 players. The c200, and The View, do not have these 2 options in every version of firmware. Instead those players use an "Auto Detect" function that is suppose to Automaticly use MTP mode. If MTP mode does not work for any reason, it should default to MSC mode.
    Switching between MSC and MTP modes
    • Turn the Sansa on, if it is not already
    • Navigate to the main menu of the player; this is the same menu that gives us options such as Play, Record, Info, etc...
    • Navigate to "Settings" on the main menu of the player.
    • After navigating to "Settings", we should see an option that states "USB" or "USB MODE"
    • From here we can select MSC or MTP modes (could vary based on player model)
    • Highlight the desired mode and select it, at this point it will roll back to the 'Settings' menu
    • Connect the player to the computer and verify it is connecting in the desired mode.
    It should be noted, when a device is in MSC mode, it will appear as a "Removable disk". When connected in MTP mode, it will show up as an "Audio Device"
    You can also try to reinstall Windows Media Player 10 or 11. Next W*ndows has a update to fix if all else fails try this. http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en
    Jan 01, 2010 | SanDisk Sansa MP3 Player
    R66_ AUSTRALIA .gOES STRAIGHT TOM MAIN MENU will not navigate
    My best suggestion is to contact the manufacturer so that you can get the proper software for your gps system.
    Jan 28, 2009 | Route 66 MINI Handheld GPS Receiver
    SanDisk Sansa e260 MP3 Player Logo
    49 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Computer Repairing
    Computer Repairing
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
