Question about Bulova Marine Star 96B98 Wrist Watch
96b98 Bulova watch
I need a maual for a 96b98 Bulova watch. I cannot figure out how to set it and dont habe a book. The bulova site only caries the manuals for their current linws and this model is discontinued
Cool_dud 09
  • 206 Answers
SOURCE: Day, date and time for a Bulova TFX watch
Step 1. When the second hand re a ches 12 o ’ clock (the zero or 60th second mark ) , pull the crown all the way to the “OUT ”position (you will hear two “ cl i ck s ” ) .All hands will stop.
Step 2. Turn the crown to move hands FORWARD (clockwise) until you see the date (for date only) or both day and date change.This establishes midnight, t h e b e ginning of the day.
Step 3. For A.M .time, continue to move hands forward until the minute hand is approxim a t e ly 5 minutes beyond the desired minute marker ;then ,gently turn b a ck to the same marke r. For P. M .time , follow the same procedure ,but first a dvance  the hands past 12 o’clock .
N O T E : The date will advance automatically at midnight, p rovided that A . M .a n d P. M .h ave been established (Steps 2 and 3).The watch calendar is pro grammed for a 31-day cycle.The  refore ,on the fi rst day of any month fo l l owing a month with fewer than 31 day s , the date must be advanced manually (see Step 5).
Step 4. When the time standard by which you are setting your wa t ch ( e.g.,telephone beep) re a ches the 60th second, push the crown all the way to the “ I N ”position . All hands will start instantly.
Step 5. Pull the crown to the “ I N T E R M E D I AT E ”position (one “ cl i ck ” ) . Your watch will continue to tell time. S l ow ly turn crown one way until the correct date a p p e a rs .Then for day/date models, s l ow ly turn crown the other way until the correct day appears .
N O T E : The day is printed in two successive positions on the day indicator: i n English and in Spanish on U. S .m o d e l s ; in English and in Fre n ch on Canadian mode l s It is possible to make use of either position. The display will automatically re m a i n in the language ch o s e n .
The date should never be ch a n ged manu a l ly between 9:00 P. M . and 3:00 A . M .a s this might affect the calendar mechanism and the accuracy of the date. ( Theme chanism will not be damaged if the crown is turned accidentally during this
time peri o d ,howeve r. )
Hope it helped U!
Posted on Jul 30, 2009
lazydave
  • 68 Answers
SOURCE: how do I take out links to size my bulova tfx
You have to press the pin out of the side of the ban. I use a tool they sell at harbor freight tools to do it. If you dont have a harbor freight near you they have an online store. You can also use a good push pin and a small hammer to tap the pin out. Put the ban on it's side over a small hole drilled i a flat piece of wood so the pin can come out without bending. do this for each link you want out then tap the pin back in on the last link to put it back togather. Sometimes there is an arrow on the inside of the ban showing you the direction to drive the pin out
Posted on Oct 03, 2009
  • 8 Answers
SOURCE: how much is a bulova watch worth serial numbers
anywhere from $150-$1000.00 depending on the model number. new watch prices
Posted on Mar 21, 2010
SOURCE: how do i value my bulova watch? it has a number
serial no. F 24797 model M 8
Posted on Apr 22, 2010
SOURCE: how to set time on a bulova marine star 96C30
For some reason you cannot find the manuals on the Bulova web site any longer. But don't worry....
I have the manual for the Bulova Marine Star 96C30 Watch. This is easily fixable.
Below, I have typed the instruction on how to fix this issue as well as reset the time and calendar and a few extra tips in case you forgot....
Here is what it says to do if the hands don't match up with the display time (usually happens after you change the battery).
First, you must locate the buttons on the watch.
The "A" button is at the 2 o'clock position (upper right). The "B" button is at the 10 o'clock position (upper left) The "C" button is at the 8 o'clock position (lower left) The "M" (mode) button is at the 4 o'clock position (lower right), and is the only button you can pull out to set the times, calendar and programming.
To RESET the watch and do the ZERO POSITIONING after changing a battery or having a display error, do the following.
RESET 1. Pull the "M" button out to the setting position. 2. hold down the "A", "B", and "C" buttons simultaneously for 3 seconds, then release them. All digit segments will turn on and display completely.
ZERO POSITIONING 1. Press the "B" button and all the segments in the digital time will reset to zero, with "UTC" showing in the main digital window. 2. Zero the "UTC" minute and hour hand (located in 12 o'clock sub-dial) to the 24 o'clock maker (straight up). Button "A" will move the hands clockwise, and button "C" will move the hands counter clockwise. 3. Press button "B" - "HR" shows in the main digital window. Adjust the main (large) hour hand to the 12 o'clock (midnight) position using "A" and "C" buttons. At the same time, observe the synchronized 24 hour hand (small dial to the left of the main dial), to insure that it also moves to point to "24". 4. Press button "B". "MIN" shows in the display window. Adjust the large minute hand to also point to the 12 using the "A" and "C" buttons. 5. Push the "M" (mode) button back in to its normal position. The watch beeps and at the same time the hands jump slightly. ALL RESET and ZERO POSITIONING are now complete. 6. Reset the time, calendar and other modes.
To set the time. Note that changing the time in any of the cities will automatically update the time for all the cities. 1. Press the "M" button to move the mode hand to (TME) 2. Press either the "A" or "C" button to move to the desired city. 3. Pull the "M" button out to the setting position. 4. Press the "A" button. SECONDS will blink. Set them with "C". 5. Press the "A" button again, and MINUTES will blink. Set them with the "C" button. 6. Press the "A" button again, and HOURS will blink. Set with the "C" button. 7. Press the "A" button again, and 12 or 24 hours tim format will appear. 8. Push in the "M" button to its normal position.
To set the calender 1. push the "M" button to move the mode hand to (CAL) 2. Set the city using the "A" or "C" buttons. 3. Pull out the "M" button to the "setting" position. The numbers of the "month" starts to blink. this is an "american" date system with the month first, day second, and year third. Use "C" button to adjust the month. 4. Push the "A" button. The date (day) will flash. Adjust with the "C" button. 5. Push the "A" button. The YEAR flashes. Adjust with the "C" button. 6. Push the "M" button back in. The calender is simultaneously adjusted for all cities.
Couple of other "tips".
Switching the time on the digital display with the time shown on the hands: 1. Press the "M" button until the mode hand is in (TME) or (CAL) mode. 2. Pressing the "A" and "C" button together. The time will switch the between the main hands (analog) and the digital display.
Temporary Hand Retraction Pressing and holding the "B" button will move the hands out of the way of the display. Repressing the "B" button will put the hands back at the correct time.
hope this helps.
Posted on Sep 14, 2011
I NEED MANUAL INSTRUCTION BULOVA MARINE STAR MEN C9333006
You can find it here:
http://www.manualsonline.com/manuals/mfg/bulova/bulova_watch_product_list.html
or you can have a familiar manual from Citizen watches' website (technically almost the same. Citizen owns Bulova now)
Feb 16, 2011 | Bulova Watches
I received a new Bulova Marine Star Men's watch but lost the manual. I need to download a manual. My model is goldtone adjustable band with black coated center line. Besides the clock it has 3 other...
If you go to the Boluva web site http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine Star&gender=1 you will be able to find your watch on their list.
Click on your model and you will see a page with information on the watch which includes operating instructions which you can download.
Dec 08, 2010 | Watches
SET TIME ON BULOVA WATCH
You can go to the following link to find a manual for your watch to get the instructions you need.
Aug 11, 2010 | Bulova Chronograph Watch
Need a maual for the following Citizen Mens Eco-Drive Promaster SST Watch (JW0030-55E)
Copy http://www.citizenwatch.com/COA/English/settings.asp
into your search engine and you should arrive at the Citizen web site for setting instructions. Insert the information asked for and you should be able to download instructions.
Apr 23, 2010 | Bulova Watch
I need a manual to operate a bulova 98G70 marine star wrist watch
Copy "http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine%20Star&gender=1" into your search engine and you should arrive at the Boluva web site page listing Marine Star models.
I couldn't find your particular model but perhaps one of those listed is similar to yours.
Mar 19, 2010 | Bulova Marine Star 98G71 Wrist Watch
I inherited the watch but not the manual. I don't know how to operate it.
Here is the Bulova website that has manuals for most of their watches.
You can print out the manual for free...
Did this help? Good Luck.
http://bulova.com/service/servicecenter.aspx
Jan 08, 2010 | Bulova Marine Star 96B98 Wrist Watch
Setting/manual for leroch digital watch
www.bulova.com
you'll find instruction book to download you and go thur their selection til you find yours
Feb 13, 2009 | Bulova Watch
Need instruction book
Copy and paste this link. It will take you to Bulova's service center where you can download instructions for any of their watches.
Jan 09, 2009 | Bulova Watch
Bulova Marine Star 96B98 Wrist Watch Logo
70 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
