Question about Proscan 32LA30Q Television
Volume noise after warm up
I have a 32 in Proscan LCD tv and the volume makes a humming noise after it warms up.
Can't find any information on the manufacturer? How do I contact them.
  • Anonymous Mar 25, 2014
    TV makes ringing noise
YES! I had this problem and there are others here under humming.
Standing in front of the TV, make your volume zero.
Punch in --very quickly-- 9876
If it worked, it will open a new menu. Go down to the Backlight and enter. Move it up to 83 from 81.
Hit menu twice.
Now try it and see if your hum is gone! [I think I was starting to go deaf trying to hear the volume over the buzz!]
I will warn you to try it a few times. At one point it shut off on me in the middle and if this happens to you, expect the volume to be BLARING when you turn it on again. :-)
Posted on Mar 10, 2009
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Jul 04, 2009 | Proscan 32LB30H LCD TV
Dell 32 inch LCD Tv volume and menue problems
your main board is not communicating with the tv. it may be on the breaks of going bad, or simply needs a firmware update. questions, email me
May 24, 2009 | Dell W3706MC 37 in. LCD HDTV
Hum in sound volume
It could be a few things. The first thing you want to look at is make sure that the microphone is muted in the mixer controls of your audio cards. These settings are located in the control panel. If you need the mic, look under the advanced settings under it and disable the 20 db option for it.
If that doesn't work I have a few other ideas.
Mar 17, 2009 | Proscan 32LB30QD 32 in. LCD TV
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Feb 26, 2009 | Proscan 42LA30H 42 in. LCD Television
I'm experencings a buzzing noise coming from the speaker when I turn on the tv....How can I get rid of this noise?
Give this a shot, it should fix the hum issue:
1. Turn tv on
Let me know if this works.
Feb 19, 2009 | Proscan 32LB30QD 32 in. LCD TV
Poor sound quality
Hi, I sent an email regarding the issue to OnCorpus (the company who makes ProScan)
This is what I got back:
Thomas,
Follow these steps to correct humming issue:
1. Turn tv on
John
jd@oncorpus.com
I can't confirm if this works at this moment since I don't have access to my TV.
Thomas
Feb 11, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Hum in the audio - 32'' Proscan 1080i
does the hum occur when playing a dvd or only when watching tv ? if the hum occurs only when watching tv, i would like you to disconnect the cable line from either the wall or the back of the cable box and see if this hum disappears. if the hum disappears call your cable company. you have what is called a " 60 cycle ground loop ". hope this helps.
Jan 20, 2009 | Televison & Video
Proscan Tv is humming
This made my humming sound go away completely;
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
John
Dec 15, 2008 | Proscan 32LA30Q Television
Proscan 32LA30Q Television Logo
210 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
