Question about Hitachi Televison & Video
Need a mirror 4 my set53fdx20b
Need mirror 4 my set
    Genius:
  • 2,920 Answers
You will need to order one for your set through a tv repair shop or from the company that makes the tv.
Posted on Feb 21, 2009
Screen mirroring
Screen Mirroring:
The screen of your mobile device will be displayed on the tv screen this is known as Roku screen mirroring. That displays the web pages, videos and photos etc.
This feature will not support on all the Roku devices.
To use this feature your Roku and mobile device on the same wireless network.
Steps To Enable Screen Mirroring on your Roku Device:
Press Home button on your Roku remote
Select Settings-->System-->screen Mirroring-->Enable Screen Mirroring
If screen mirroring is not available in menu selection, then your Roku does not support Screen Mirroring.
If need technical guidance for Roku-related issues call this toll-free: +1-844-965-4357 and https://www.rokuactivationcode.com/
Jan 12, 2014 | Roku 3 Streaming Player 4200R
Reset memory on mirror on 1999 town car
Press the set button for the seat for 3 or 4 seconds. Move your mirrors into place, then press the the button for the seat position you are setting the mirrors for 1 or 2. The seats and mirrors are set at the same time.
Sep 02, 2012 | 1999 Lincoln Town Car
Driver side mirror replacement
Instructions1.
    • 1
Remove thedoor panel. Refer to your Honda Accord repair manual for theinstructions in removing the door panel. Unhook the rods and connectors on theinside of the door panel and set it on the floor.
    • 2
Remove thefilm covering the access to the side mirror. It's difficult to avoid damaging thefilm while removing it so you will need to purchase a new piece of filmcovering when you buy a new side view mirror.
    • 3
Reachthrough the service hole into the mirror housing with a screwdriver. Loosen thescrew that holds the mirror. Twist the screw out with your hand.
    • 4
Reacharound the door and support the mirror with your other hand. Continue to twistthe screw out, then catch the mirror as it drops out when you remove the screwcompletely. Put the screw in a safe place so you don't lose it.
    • 5
Installthe new side view mirror by positioning it where the old mirror was. Insert thescrew you took out in Step 4 and twist it in with your hand. Insert ascrewdriver into the service hole to tighten the screw.
    • 6
Replacethe film covering that was damaged when you took out the old mirror. Push itinto place in the indentation on the door.
    • 7
Sit in thecar seat and adjust the mirror so you can use it properly.
Jul 06, 2012 | 2005 Honda Accord
How to replace the electronic interior rear view mirrow on 2004 Envoy SLT. I have a new one to install and need to figure out how to remove the old one on the truck...
Hello lindleyjl,
1. You will need to disconnect the wire cove from the upper mirror base. (See image below)
2. Use a flat blade screw driver to disconnect the electrical connector from the mirror. Number 1 in the image.
3. Use a torx driver to loosen the set screw that holds the mirror base to the windshield button.
4. Slide the mirror upward off the the rear view mirror button; number 1 in the image below.
To install, reverse the above outlined procedure.
I hope this helps.
Regards,
netvan
Jul 24, 2011 | 2004 GMC Envoy
(4) Light Tunnel Mirrors Came Apart
i will email you piks u need to use high temp sealer
May 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
HOW TO CHANGE RIGHT HAND SIDE MIRROR
Relatively easy to do. A 1/4 inch drive socket set and a screwdriver will do this one.
There is a triangular plastic piece on the inside of the door opposite the mirror. Remove this piece ( I don't think there are any screws in it ) by prying gently outwards. You will then see three studs with 10 mm nuts, remove those and the mirror will come off. If you have power mirrors you will need to undo the connector as well.
Oct 29, 2009 | 2004 Toyota RAV4
Re-assembly of 99 Blazer mirror to windshield
This is a relatively easy task, the bulk of the work has been for you. The rear view mirror assembly simply slides onto that metal block that was glued to your windshield. Your mirror mount (the part that slides onto the metal bracket) may be cut differently or shaped different from the rest of that part. you simply need to line that up with the metal mount on your windshield. slide the mirror on and tighten down the set screw if you have one. I've listed the steps below
1. find the base mount for your mirror (this is the bottom of the mirror that sits on the windshield)
2. look for a cut out or flat part of the mirror base.
3. line the flat part of the mirror base with the metal mount bracket on the windshield.
4. slide the mirror onto the metal bracket (this may require you to wiggle while you slide the mirror onto the metal bracket).
5. tighten the set screw on the mirror base ( this is important because your mirror will vibrate off the bracket if you don't.
Note some mirrors slide from the bottom of metal mount bracket and some slide from the top. it sort of depends on the manufacturer and/or the way the bracket was installed.
Hope this helps
Aug 04, 2009 | 1998 GMC Jimmy
I have a 5 year old RCA 61LPW42 HD DLP television. A few months ago a small dark shadow appeared in the upper left corner of the screen. Over time it has creeped down and become larger. Still starting...
It's the light tunnel. The tunnel is a square tube made up of 4 mirrors glued together.
It looks like this from the side: |_| (with a piece on top too.)
When the glue breaks down, it shifts inside the little mirror holder. The shifted mirrors looks like this /_/ what you are seeing is the shadow of the tilted mirror tunnel.
ON the RCA's there's not a good fix.
RCA's response:
"Ok, well sadly they do not offer the light tunnel anymore, which is what you need. Sadly you would be rendered to get a whole new light engine assembly. That would be the D.N.D module, light tunnel,color wheel,optic spanner, and oci. mirror. Your best bet would be to search ebay for a broken engine and replace it that ways."
That is the ONLY response I got from them.
I took the set apart and found the 4 tiny mirrors. I will be attempting to epoxy them together. (The set is dead anyway, why not try?)
Apr 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA dlp - Shadow
RCA's response:
Nov 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
D40x Camera with mirror lens = black pictures
Usually tele lenses need longer exposure,and mirror lenses need more than normal lenses.Try with 1sec, half sec,( 2 in the speed dial, not 2" ) or quarter sec (4 in the speed dial) exposures.
One more thing, you need good sturdy stands to hold cameras.
Apr 02, 2008 | Nikon D40x Digital Camera
Televison & Video Logo
18 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
