The paper will run through the printer but shows nothing. Toner has been replaced but this does not help at all. It will not print whether it is being used as a copier or a printer.
Comments:
Feb 28, 2009
- We have called--they all say buy a new one. Maybe that's the solution, but it seemed worth seeing if anyone could suggest a solution before we scrapped an otherwise excellent machine.
-   Had the same problem for over a year. Called Canon three times. They suggested downloading an reinstalling vista driver twice and now take it to service center. The machine is basically a very expensive scanner.-   gkh5
Apr 13, 2009
-   I have had the same problem in the past. All of a sudden it will start printing again. It has worked for about two months without a hitch.... Until today. Same problem. -   Guest
Mar 16, 2009
-   same problem, new toner, still won't print-   Guest
Feb 27, 2009
-   My cannon 6550 copier will not print. I have changed the toner and nothing seems to work.-   Guest
I have a EX-3535 fuser error code 004-361 coming up on a new fuser on a machine. I changed the fuser...
(More)
I have a EX-3535 fuser error code 004-361 coming up on a new fuser on a machine. I changed the fuser for another new one and still get it so suspect I need to do an NVM setting but don't know which? Can anyone help?
i have sharp AR5316. when i turn on the copier indicates H2. then i entered "# interrupt C...
(More)
i have sharp AR5316. when i turn on the copier indicates H2. then i entered "# interrupt C interrupt 1 4 START". then it restarts and then it dispays H2 with paper jam bulb.
