Question about Kohler K-10416-BN Fort½ Single Control Kitchen Faucet with Side Spray...
One handle kitchen faucet leaks
When turning on the faucet., it initially gurgles like there is air in the pipe then the stream begins. There is a leak at the base of the faucet as long as it is turned on
  • albert getty
    albert getty May 11, 2010
    changed the washer?
    President:
  • 2,976 Answers
There are "o" rings in the area where it is leaking. You can get them at almost every hardware chain. Clean everything well with scotchbrite ant put silicon grease on before you put it back together.
Posted on Feb 21, 2009
    New Friend:
First, you need to remove handles of your kitchen faucet. Locate the water supply valve under the sink and turn it off. You need to take off the cap of the handle of the fixture that you think that has the broken seal. You need to see the stem of the handle. A rubber washer and O-ring are attached to the stem. All of the parts together make up the seal of the faucet. They may appear worn or split. If so, this is the seal that you need to replace. Expect the repaired faucet to sputter when you first turn it on. This is air pressure being released.
http://www.ibathtile.com/bathrooms-kitchens/hansgrohe-bath.html
Posted on Dec 17, 2013
I want rotate my Grohe ladylux kitchen faucet. The handle is on the left and I want to rotate to the right side. How do I do it? Thank you John
You will presumably be pushing the faucet handle away from you instead of pulling it forward? If you don't like it, you can always put it back.
Turn off the water.
Release the water in the faucet. If you have a faucet in a room on a floor below, open that to drain the water.
From underneath the unit, back off the nut that is gripping the worktop. Slacken off the hot and cold supply pipes. I am hoping you have braided flexible hoses, or you can't do this job very easily.
Spin the faucet 180'.
Retighten the hold and cold supply pipes.
Retighten the holding nut.
Turn on the water and open the faucet.
Check for leaks.
There is an installation video here.
https://www.youtube.com/watch?v=sQgi0CMAxYM
and some further information and diagrams here.
Removing Grohe LadyLux Caf 33 755 Faucet Handle
Jan 02, 2016 | Grohe Plumbing
I have a Price Pfister 34 Series Genesis Single-Control Faucet, 3-hole with side sprayer, in my kitchen and it has developed a leak. Specifically, when I lift the lever it leaks from the handle, and when I...
The cartrididge seals have gone bad for what ever reason and the repair is simple enought but I woul take the replacement unless they want to pay for the plumber to come and fix it.
Feb 18, 2011 | Price Pfister 34-3LC Genesis Kitchen...
Delta Faucet Company 467-SSSD-DST Palo Diamond Seal Technology Pull-out Kitchen Faucet, Stainless, 3 years old and is beginning to drip unless we position the handle just right. Is there a washer? I've...
I hope this will help please go to this web site for a downloadable parts link. If it is leaking from the spout replace the seats and springs to correct the problem. Turn water off and remove handle with a 1/8" allen wrench and remove retaining collar to access the ball assembly to remove the seats and springs.
The parts page on this link will give you a break down and hope this will help.
http://www.deltafaucet.com/kitchen/details/467-SSSD-DST.html
Dec 30, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
My Pegasus kitchen faucet leaks at the top, even when off. I'm not sure which model, it has one handle with a side spray. What do I do.
Turn off water supply to sink. Wrap top of goose neck with rag and use a pipe wrench to remove ( lefty loosey, righty tighty). Inspect interior of faucet for worn o - ring or gasket and take damaged part to local hardware store for replacement parts. The gasket or o - ring may be on the gooseneck ( the part the water comes out of between the handles or below a single handle faucet).
Good luck!!
Nov 29, 2010 | Pegasus Technologies Plumbing
Water leaking from the faucet onto the countertop.
http://docs.homeclick.com/PE-Links/Rohl/Rohl-A3608-specs.pdf
Check out this web site and it looks like it should be a o ring at the base, anyway I hope this will be helpful.
It has a breakdown of faucet internal parts.
Jun 04, 2010 | Rohl A3608LMPN Single Lever Country...
I Have a single handle peerless kitchen faucet that's making a shrill noise,and the water pressure is very weak.
Possible causes:
1. you have a air pocket t in the heated water system. You will need to bleed the system.
2. As to pressure, you may have knick in pipe somewhere due to worned plastic pipe.
Apr 20, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Aug 30, 2009 | Moen 87555C Trianna Single Handle Pulldown...
Moen One-Handle Kitchen Faucet Leak - Hot Only
http://www.moen.com/browsecatalog/catalog/specpartsearch.cfm?location=TopNavCustomerSupport
Moen uses a cartridge on their faucets. You have to remove the handle. You will find the stem and a small U shaped retainer. Pull the retainer out and pull the cargridge straight up. Sometimes the cartridge is in there pretty tight and you have to pull hard. Once you do this, take the cartridge to your local hardware store. Replace it with the one you have because they have 2 different one. Install it back in the same order it was removed. Hope this helps and good luck.
Apr 10, 2009 | Plumbing
Kohler K-10416-BN  Fort½ Single Control Kitchen Faucet with Side Spray... Logo
452 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
