Question about Frigidaire 3.0 Cu. Ft. Top Loading Washer, GLWS1339CC
Washing machine frigidaire top loader model fws6976fs1 will not
Fill with water, will cycle thru, but doesn't fill with water. all water connections were checked
help, thanks Rob
  • steve
    steve May 11, 2010
    Does it fill with water initially or not at all?
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 209 Answers
SOURCE: Hoover elite 930 top loader washing machine
I am a recently retired appliance engineer of 20 years start with checking the other solenoid, the conditioner one, it may be that that is not working, and double check the cold one, remove the two wires and check for a circuit, it may be actually filing up initially with hot water without realising it, always work with safety remove the plug before removing panels etc if i have helped rate me please
Posted on Sep 09, 2007
  • 249 Answers
SOURCE: Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Posted on Nov 25, 2007
SOURCE: hoover 750L top loader washing machine
check the screens in the hoses or water valves
Posted on Dec 29, 2007
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
My dark clothes has lint all over it after it has been washed, Is there something like a lint trap to clean?
need brand and model. on top loader washing machines i"ve used bicarb soda to fix problem. -2 pkts soda ___ select high or large water fill______ select hot water fill_______have no clothes in unit____ put soda into machine____ shut lid __ select wash cycle----- let it fill and wash for about 10 min"s------ turn unit off------ do not let wash water drain----- leave over nite--- in the morning restart cycle, unit will just continue to wash it will not refill----let it go thru complete cycle and that should fix problem.please reply with brand and model.
Apr 08, 2010 | Washing Machines
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Frigidaire lws3312d washer not filling up
check the water faucets on the wall and make sure that both hot and cold are completely open.
check the water inlet hoses for any kinks or leaks.
Nov 05, 2008 | Frigidaire CWS3600AS Top Load Washer
Hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Feb 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire 3.0 Cu. Ft. Top Loading Washer, GLWS1339CC Logo
102 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
