Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
I have a desktop and laptop I want to know if I can use the Wire2 Wireless usb adapter to create a network that the laptop can access and how to do this
  • 115 Answers
First of all u hav to get a internet connection in ur home,,ur internet provider will provide u with a modem,if tat modem has wireless capabilities then u dnt need to purchase a router otherwise u hav to do so.then u have to setup the wireless modem or the router and the 2wire wirelss USB adapter on the same wireless network.plz keep me posted for further issues
Posted on May 14, 2009
I have Windows 8 and have not been able to connect to the internet.
There are several possible reasons to have a connection fail. You could have a driver issue, the network adapter may have failed, the passkey/SSID aren't correct (for wireless connections) or the router/WAN network is down. (The WAN being disconnected happens with my systems at regular intervals.) If the router/access point has been secured to limit the number of devices on the network or only allow certain MAC addresses, use a different device to log in to that router and increase the number of allowed devices. (This will depend on the make/model of your router. It's probably under the Advanced settings.)
What type of hardware are you using (laptop/desktop/tablet)? What make and model is it? If you have both wired and wireless network adapters, try making a new network with the other adapter. Also try to create a new network connection for the current adapter.
You can check for driver issues from the desktop clicking the Windows key + X (on systems with keyboards) and choosing the Control Panel. Then under System and Security (or Hardware and Sound) choose the Device Manager. Scroll down to the Network Adapters and expand that section by clicking on the plus sign. If there is a triangle with an exclamation point or a red x, then you have a driver issue. Use another machine to download the drivers and place them on a USB drive or other external media. Install the drivers. (If you can use a different network adapter, then just download and install the drivers.) Try the network trouble-shooter to identify a problem.
If updating the drivers doesn't work, check if other devices do connect to your network. If another device works, try a USB network adapter (or for a desktop, a PCI/PCI-e network card). You may need to disable the on-board network adapter in the BIOS. (This is hardware dependent again.) If other devices can't access the network, try directly connecting a wired network to your DSL, FIOS, or cable modem. If the direct connection doesn't work, then contact your provider. If the direct connection works, try a new router/access point.
I hope this helps.
(note: on an older XP laptop with only USB 1.0 ports, I recommend replacing the device, instead of a USB network adapter. The USB port speed will make the network connection excessively slow.)
Sep 16, 2013 | Computers & Internet
How to go to wifi
Wi-Fi technology enables wireless Internet and network access through public and private hot spots. These hot spots are widely located in homes, restaurants, bookstores, coffee shops and other businesses, so you can keep connected wherever you may travel. To connect to Wi-Fi, you must have an enabled wireless adapter on your computer. Most modern laptops and many desktops have this adapter built into the system, but many lack such capabilities. However, a wireless adapter is easily installed via USB, which allows you to connect to available networks through Windows 7.
Enable your wireless adapter. Most laptops have a hot key labeled with a radio antenna. Hold the "Fn" key and press this key to toggle wireless on or off. Desktops likely have a physical antenna on the back of your computer that is typically always on. If you don't see such a hot key or antenna, you need to acquire a USB wireless adapter. Attach the USB wireless adapter to an available USB port on your computer. Windows 7 will automatically install the necessary drivers for most adapters. If it does not, insert the CD that came with the USB wireless adapter into your drive and choose to install their drivers. Restart your computer if you do not see a wireless icon in your Windows 7 notification area. Click the wireless icon in the Windows 7 notification area and click the network name to which you want to connect. If this is your home network, the correct network will likely be the one with the strongest signal. Click "Connect" and enter the wireless security passphrase, if required. Only secured networks will ask for a passphrase, but some public networks will require browser authentication instead. Open your browser and navigate to any website. If the hot spot requires browser authentication, your website request is redirected to an information page. Follow the instructions on this page to get Wi-Fi. This may entail clicking "Accept," entering a given password or entering a cell phone number. After authentication, attempt your website again to verify accessibility. Hope this helps
b>
Dec 22, 2012 | Computers & Internet
I want to buy a wireless network adapter USB. I do not have internet home, but there is a public connection that is a couple hundred feet away from my house that is public because it is a cafe. Can anyone...
A couple of hundred feet away may be too far for a good signal receiption.
You can increase your signal with an aerial.
You may need to go into the cafe or park yourself nexr door to the cafe.
Use Google to see what is available on the Internet.
Here are a few WEB sites for you to look at.
http://www.gadgetbuy.com.au/index.php?/office-gadgets/usb-802.11n-wifi-dongle-for-desktops-+-laptops-150-mbps.html
http://shop.ebay.com.au/sis.html?_nkw=USB+WiFi+Dongle+Desktops+Laptops+150Mbps+Wireless+Adapt
http://www.mobilefun.co.uk/usb-wifi-dongle-p11590.htm
May 02, 2011 | Computers & Internet
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Can this HP access internet wirelessly?
you need to add a wireless card inside your computer or else you can stick in an external USB wireless in one of your USB slots. then you will be good to go.
Jan 27, 2009 | HP Pavilion 515n (DC471A#ABA) PC Desktop
No WiFi... Please help me!!!
Well this is the best product for you
Click Here
Dual-Band Wireless-N USB Network Adapter
Radio band selectable to avoid wireless congestion!
satellite?blobcol=urldata&blobheadername1=content-type&blobheadername2=content-disposition&blobheadervalue1=image%2fjpeg&blobheadervalue2=inline%3b+filename%3dwusb600n_med.jpg&blobkey=id&blobtable=mungoblobs&blobwhere=1193776891708&ssbinary=true
  • High-speed Wireless-N (draft 802.11n) networking for notebook and desktop computers
  • MIMO technology uses multiple radios per band to create robust signals for maximum range and speed, with reduced dead spots
  • Operates in the 2.4 and 5GHz radio bands -- choose the one with least congestion in your area
  • Also connects to Wireless-G, -B, and -A networks
Dec 16, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Networking question
Ok, you have several options. Go to a website such as bestbuy.com. Type in linksys and look of wireless access points, wireless usb adapters or a wireless desktop adapter. I would go with the third one.
Mar 30, 2008 | Linksys Wireless-G Broadband Router
Not detecting any wireless networks
You have not mentioned having a wireless router or access point to serve as the hub on an infrastructure network. I you have a router please let me know -- the instructions for the solution changes.
The following is an article to create an ad hoc network between wireless cards without a wireless access point or a router. If you ignore the steps about connecting to the internet with a wired connection and the internet sharing instructions. This will allow your machines with wireless adapters to communicate with each other (assuming the operate on a common band). The article goes on to indicate one machine with a wired connection can act as the "router" for the other two when it is on to allow them share internet access with the wired machine (the wired machine also needs a wireless card for this to work).
Ad-hoc networking access point
Jan 03, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Belkin WirelessG Plus Mimo
I'm pretty certain that you can only have 1 host per computer/per name for a network. So, if you want to change the laptop as host you will have to setup a network under the settings. Create a network password along with the network name for that laptop. (Unidentified Network) is a correct network name. It's just that you probably didn't change it to a specific name that you wanted it to be in the box. after doing this, you should be able to go to the other computer's and try to log onto the network domain that you have created. after that in order to get approval to access the network domain you have to enter the encryption key which is the network password. you have to do this to all non hosted computers. after completion, you should be connected to that specific network.
Now you want you're desktop to be the host. Well, from above do the same steps for the desktop. But, instead of (in example) to lets say your laptops network name is (Home). Well, you would have to make the host name on the desktop to be (Home2). then set the encrption key. Then go to all non hosted computers including the laptop that you made the first network. because this is a new hosted network created by you're desktop and connect to that network and then supplying the encrption key to be able to access the network. and you should be good. Just my 2cents. although this may not work because you may have to have to routers to be able to create multiple networks but, like you mentioned earlier you have a wireless on you other laptop you can use the setup for that wireless to make another network. Hope this helps and good luck ;)
Dec 02, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Cannot connect
Hi, A couple of questions to gather more information: On what platform are you using the wireless adapter, a laptop or a desktop PC? What brand/model or motherboard? If it is a laptop, is it built-in, USB or PCM-CIA card? If it is a desktop, USB external or PCI add-in card? What is the brand/model of the wireless adapter? What is your OS? Are you using Windows Wireless Network Configuration Utility or a third party/wireless adapter manufacturer client/utility program? Have you tried NetStubler to verify if your wifi card is receiving something? Post back then we can start figuring things out. Kind regards.
Aug 22, 2007 | Zyxel ZyAIR G-570S - Wireless access point...
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
139 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
