Question about Logitech Cordless Mouse
How to open battery compartment
How to open battery comaprtment
  • dhoag Apr 17, 2009
    I know it's an optical mouse, but I don't know the model number.
Open battery compartment
Spray WD-40 around the compartment door and try to let it trickle inside the compartment. That should break the acid corrosion buildup that holds the door from opening.
Oct 19, 2013 | Nikon F601 35mm SLR Camera
We recently replaced the engine in my 1999 Mercury Village minivan. Now the wipers won't work when the engine is on Where is the wiper relay located or what could be the problem>?
The wiper governor is in the enigne comaprtment, driver side. You probably have a bad ground in the engine compartment casuing this issue from the engine swap.
Jul 07, 2011 | 1999 Mercury Villager
I have water coming into the freezer through a vent in the back. Where is it coming from and how do I stop it?
Hi and welcome to FixYa, I am Kelly.
Your freezer evaporator drain is clogged. Unplug the unit.... open the lower back of th unit by remvoing the fiberboard cover. Place an external fan directed into the freezer compartment for just over 2 hours. (Water mess) Use a vacuum to clear the debris from the catch pan basin in the bottom of the unit. Make sure to clen off the END of the compartment drain hose. Next revers the vacuum flow to exhaust. Force aire throught the end of the comaprtment drain hose to float out any debris in the evaporator drain funnel. Clean up the residual water and return the unit back to normal service. This should stop the water thatis caused by the automatic defrosting cycle from comeing through the evaporator acess panel vents.
Thanks for choosing FixYa,
Kelly
Jun 06, 2011 | Admiral Refrigerators
My pendrive (sony 8 gb ) not detecting in my computer from yesterday and the same time it is detecting in other computers and other pendrives/hard disc are detecting in my computer
Observe the compartibilities on the drive. The computer has to have compartible requiremetns to capture resources on devices as externals. Recently innovated computers are pen device compartble. prior computers howver require verifications to ascertain whether comaprtible also from which update makes readability in instances attainable.
Feb 20, 2011 | Sony Computers & Internet
I have download a trial version 4.15 and i have given a serial number but after that it was not working so please provde me smark movie of nokia e72 which work successfully in it with serial key
The computer program with a serial number require comaprtible computer systems to perform. For example, the program is provided a serial number from the manufacturer as referecne to the particular software distritubuted. Once the program has been installed on the computer with serial number keyed, the computer has to have the resources either recognied as being compartible with the manufacturers product. For example, purchasing apple mac programs mayhave been provided a functioningseriel number however would least fucntion when installed on microsoft computer. usually with computer programs, verify the computer systems prior to acquirng programs or ascertain the programs compartibilities before attempting to install.
Feb 15, 2011 | Computers & Internet
Hi there my Sanyo VPC-E890 camera connects to my computer i download the software for it and nothing happens my pictures don't show up any where if you could help me with this problem i would be very...
The camera may require a compartible program to recognise the pictures captured. Acquire the programs from www.NCH.com that may be compartible with the camera. Usually the computer may require compartibility to programs, the device may also require compartibity, and the cables connection may require comaprtibility especially with prior computer connectivities. Recent computer would only require compartiblity to the external device if a prior manufactured.
Feb 03, 2011 | Computers & Internet
When i turn my oven on, the flames come up into
If the burner pressure is adjustable(some are not) you can use a small adjustable wrench to turn the gas orfice to lower the gas pressure. The orfice is usually located in the broiler/storage comaprtment at the very bottom of the range. It is the brass piece that goes into the burner venturri and is where the gas comes out. If your turn it clockwise it will decrease pressure & counter clockwise will increase pressure. If the flames are coming into the burner compartment that is quite an increase in pressure!!! Make sure the the range did not have the gas regulator removed. If it was then that would explain why the oven burner pressure is so high.
Nov 11, 2009 | Whirlpool GS460 Gas Kitchen Range
I need to know where the drain is in my airconditioning unit on my 2001 galant. Water is filling up in my dash.
Its behind the dashboard compartment. If you remove the comaprtment cover you will see the filter of the evaporator and below it is the drain.
I hope this helps
Jul 06, 2009 | Heating & Cooling
Which comaprtment for the washing liquid ?
Compartment 1 is for Pre Wash
Compartment 2 is for Main Wash
Compartment marked with what looks like a star is for conditioner.
Bosch manuals can be downloaded from www.bosch-home.co.uk
May 19, 2009 | Bosch Dryers
Ac vent stuck in defrost
find the vacuum leak in the engine compartment vacuum hose from engine to firewall, and vacuum reservoir for hole (in engine comaprtment or wheel well
Oct 31, 2008 | 2002 Ford F250 Super Duty SuperCab
Logitech Cordless Mouse Logo
261 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
