Question about HP Pavilion DV6500T Laptop
Want charge Battery
Power is on want charge battery but battery is good try powersupply is good
light come up and it show on icon the powersupply is reconized but say not charging
called HP they didnt know told me motherbord but it works fine
i cant run direct of supply want start pc
when battery is in want charge and runs only on battery til dies
can somebody help
Battery and Supply are teset and are good
Thanks
Peter
    President:
  • 2,653 Answers
It's the motherboard for sure. Did they say whether or not your model was under warranty.
You can check that info out here:
http://www13.itrc.hp.com/service/ewarranty/warrantyInput.do?admit=109447627+1235233999988+28353475
Posted on Feb 21, 2009
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
Hello there, I own a toshiba c655-s5049 laptop about a year. When I connect a charger taskbar icon shows plugged-in, not charging and the front panel power/battery indicator lights green not orange. When...
Take some alcohol and a q tip and wipe the battery terminals and the terminals on the battery compartment. The laptop not getting a good connection with the battery
Aug 07, 2017 | Toshiba Satellite C655-S5049 Notebook
I have a laptop satellite m305d-s4831& battery model PA 3634u-1BRS. My battery is not detect show in taskbar icon but battery icon is show red color in laptop and it is not work battery power, not...
Sounds like the cells inside of the battery went bad. Try another known good working battery, if the red X goes away on the battery then you know the original battery is bad. If the red x stays on the new battery then that means either your power adapter is bad, which you can try replacing that as well because it might not be putting out the correct voltages to charge the battery. If that doesn't work then the motherboard is bad for sure.
May 25, 2011 | Computers & Internet
My acer aspire 6530 suddenly stopped charging the battery, it works with battery, works with battery and main power supply (yet, as long as the battery is still charged), and it certainly doesn't work with...
Seems like this is the case of a bad power supply adapter, and needs to be replaced. But to make sure we are on the right track, you mention towards the last statement, you said that when your laptop is off, and the battery is installed on, and without the power supply, the computer power button would flash and no sign of life right? Well take these step to see if it is the power supply, 1, check to see if the small green light is lighting from the powersupply adapter. If it is not, then 100% you have a bad power supply. 2, does the laptop power on when using the power adapter only, and with the battery pulled out? If not, then 85% still is your power supply and the other 15% is your power jack, either is loose, or bent, as we tend to plug in and out alot. 3, Does the laptop power on with the battery itself without the power supply adapter? If it does, it is not your battery. The reason to the laptop power light blinking with the battery installed only could be that the battery is low/drain and does not have issufiect charge to power up your laptop. And to say that when your system is on and your plug in the powersupply, and the small battery icon says it's charging but actually it is not. It could still be your powersupply, it is damaged but a smart chip installed on your powersupply only sending signal to your laptop, this chip is only to prevent the battery from over charging. So if you have another power supply, you cna test this out. But at this point, they was you described things, I believe it to be the power supply. I hope this help, if you have any question, let me know.
Jan 17, 2011 | Acer Aspire 6530-5143 Notebook PC
Toshiba laptop shows that is receiving power but does not power up and battery will not charge
you can take both units to redio shack and they can tell you if the powersupply and the battery are any good
. if you have a volt merter with its instructions you can test these your self
Aug 07, 2010 | Toshiba Computers & Internet
Have a compaq presario running win 7. The system does not recognize when it is running on ac power (original ac adapter). The battery charges but the only sign of this is the battery icon says xx%...
Hi, it seem as if your battery is faulty you should try another battery to see if the computer will recognize when it is charging, you can also try your battery in another compaq presario computer to see if it will have the same problem.
Aug 02, 2010 | Computers & Internet
Acer notebook: But its not charging, 0% and a big X on the
You may have a bad cell in your battery pack (hopefuly its not the powersupply). First remove the battery from the underside of the laptop and replace it. Try charging again.
Check the output of the powersupply with a multi meter and ensure it is providing the proper voltage.
If the PS is good then go on ebay and order a new battery from Hong Kong for cheap (thats what I did :)
Hope this helps,
Cheers,
Kevin
Jan 24, 2010 | Acer Aspire One PC Notebook
Toshiba SP 6100 Battery problem
If the charge light shows a blinking amber, then the battery is dead. If the charge light shows a solid amber, then it's charging.
Which is it?
Dec 31, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Mac Ibook Power supply problem
On Mac iBooks the orange light comes on when it charges the battery. Once the battery is charged it turns green. Im guessing the other powersupply was aftermarket or broken. EIther way, if it starts out green - recognizes the battery isnt full - turns orange for a while - then turns green when the battery is full, then the computer and powersupply are working perfectly. Enjoy your iBook!
Feb 27, 2009 | Apple Computers & Internet
HP Pavilion DV6500T Laptop Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
