Question about Kenmore Dryers
Dryer door comes open
Dryer door pops open before clothes are dry
  • Kenmore Master
  • 3,361 Answers
Replace the door latch.
Yours is worn out.
They just pop in.
Posted on Feb 21, 2009
I have a whirlpool gold dryer. I can't keep the dryer door shut while clothes drying. it keeps popping open.
the problem is the door latch have a look and see if the door pin (plastic) still has both prongs they should look the same from side to side if they are then the tension wires in the doors clamp have come apart. if one side of the door pin has snapped off (most common problem from slamming door closed) replace the door pin
hope this helps
please take the time to rate this repair
Aug 03, 2010 | Whirlpool Dryers
Whirpool dryer model wed9400swo the dryer door pops open
This usually occurs when the load is too large, causing the cloths to push the door open. If this is not the case, you should replace the door latch mechanism, which is what keeps the door closed.
Jul 14, 2010 | Whirlpool ET8CHEXSQ Dryer
My duet dryer's door will pop while drying and then the door is not shut tightly. The door never completely opens just not shut tight and the light comes on in it. When this happens the dryer quits, and...
We had the same problem and surprised how rampant the issue was after referring to the internet reviews / troubleshooting, etc. The problem started after about 6 months and the solution came to me after much "headaching" over the problem. There were no 'codes' coming up just the door popping open during the cycle. I purchased a (2) twenty pack of 1/2" diamerter x 1/16" thick N42 Neo Earth Magnets and placed them along the top edge and bottom edge of the dryer opening. Instant fix in less than a minute. The thickness does not interfere with the door opening and the strength of the magnets is obvious. Hope this helps. Fix was less than $10 bucks and no service man, etc.
May 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The dryer door always pops open stopping the dryer... how do I make it stay shut so the clothes will get dry without having to close the door every other minute?
Try putting less of a load in dryer. The weight of the clothes riding against the door, may be the reason why it pops open.
Apr 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer door won't stay shut when drying clothes
There is a clip inside your dryer door that acts as snap (kinda like on baby clothes). It snaps the door closed - so to speak. If the outer part of that 'snap' gets a little stretched out it will not hold as tightly. When those heavy, wet clothes hit against the door it pops it open because the 'snap' is not working right. As long as the outer part of the 'snap' is still intact, you can fix this problem by simply squeezing it together alittle to make it grab tighter so that the door stays closed while drying your clothes. If that doesn't make it tight enough you could tear off a small corner of a paper towel to fill in the hole a little to make it tighter.
Hope this info was helpful to you. Good Luck!
Jan 29, 2010 | Whirlpool Dryers
Dryer drum is turning, but not drying the clothes. When I open the door, there is heat. Lint has been cleaned out
Check where the dryer vent comes out and make sure that there is a good amount of air coming out. If the fan is blowing, the drum is turning, and there is heat, the likely thing is that the dryer vent is partially blocked. Check the pipe leading out. Bird's nests are not uncommon. The only other thing I can think of is that the door catch is wearing out and the door is popping open, shutting the dryer off mid-cycle. Some dryers will continue to run the timer if the cycle is interrupted and it will appear that the dryer ran its full cycle, but in reality it shut off soon after it started.
Dec 06, 2009 | Whirlpool Inglis IP8200 Dryer
MAytag dryer will not run. Has Power but will not start. No sensing light.
Was your dryer taking a long time to dry clothes? If so you should first check your vent and then suspect your dryer thermal cutoff.
this problem could be your door latch switch. Is your door more difficult to open, OR, sometimes pops open / or opens really easy? Then your door latch switch could be bad.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
During the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Feb 25, 2009 | Dryers
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Kenmore He5 Dryer
try replacing the door strikes and catches part # 279570...possible door hinge issue but less likely
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
286 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
