Question about NEC PlasmaSync 50MP2 50 in. Television
Bars on screen
I have 3 1/2-3/8 inch bars approximately 1 1/2 inches apart extending 12 1/2 in down from the left upper edge of the screen. The bars are visible both when a picture is present and with a blank screen. They are made up of visible pixels generally yellow and pink but do change color depending on what is on screen. There is no discernible pattern visible within the bars and they do not move.
    Problem Solver:
  • 6 Answers
You have a blown circuit on the motherboard of your tv. the only way to fix this is to send it to the manufacturer (hopefully you sent in the warranty). or take it to a tv repair shop.
Posted on Feb 21, 2009
What is a standard kitchen counter depth?
Counter depth is key to functional, comfortable kitchen design. Standard dimensions keep cabinetry within reasonable size for average-height users, and in relation to common sink and appliance sizes, but guidelines allow for slight or moderate changes. The countertop overhang plays a couple of roles and affects counter depth.
Standard lower, or base, cabinets are 24 inches deep, while upper, or wall, cabinets are 12 inches deep. Countertops typically overhang their base cabinets by about 1 inch, or at least 3/4 inch beyond the drawer fronts and cabinet doors. The overhang helps keep crumbs and spills from getting into drawers and cupboards below and completes the comfortable cabinetry contour that includes a 3-inch-deep toe kick on the floor. Island or bar-style overhangs often extend about 15 inches or more to create knee space for people seated at the bar. Deep overhangs require bracing, which may be provided by brackets, legs or even a steel plate underneath the countertop.
Apr 14, 2018 | Refrigerators
Problem rolling bars
It should be a main power regulator baord fault. Contact any service technician.
May 22, 2013 | Panasonic TCP50U2 50 in. TV
On a 58" diagonal plasma, I have an approximate 3-1/4" wide pink vertical bar in the lower left corner of the screen. It does not go all the way to the top of the plasma, it stops mid-way on the scre
There is some connection defects. If you wish to know more about these kind of fault to plasma displays, check this link. There is illustrations to compare with, which cannot be included by this window.
Feb 25, 2013 | Panasonic TH-58PZ700U 58 in. Plasma HDTV
How many climatic adjusters do I need for my 16 foot shuffleboard table?
For tables between 12-16 feet long you will need 4 climatic adjusters. You will need to position two of the on either end, approximately 12 inches from the edge of the playing surface. The remaining two should be spaced equally between them (usually 3-4 feet apart).
Aug 20, 2012 | Sport & Outdoor - Others
Cooling light stays on during dry cycle. no heat is to dry clothes. I've switched the circut breaker numerous times and unplugged the unit many times also to "reset" . What's next..
Try a timed dry cycle instead of an automatic cycle. If that works, then you will need to clean off the moisture detection bars inside the dryer to get the auto cycle to work again. Look for two curved metal bars, about 3/16 inch wide and 4 inches long, about an inch apart, located just inside the front of the dryer, near the right side of the lint filter. (you'll have to stick your head in the dryer drum to see them) Often times, use of dryer sheets will result in a waxy coating forming on these bars, preventing the dryer from detecting the moisture in the clothes. The dryer sees no moisture, it goes into the cool down mode and then stops. Clean the bars off, and you should be back in the laundry business.
Feb 05, 2011 | LG DLE7177 Dryer
The cooling light is always on and the clothes take forever to dry!
Inside the dryer, near the lint filter, you will find two curved metal bars, about 1/4 inch wide each, about an inch apart and about 4 inches long. These sense the moisture in the clothes. When fabric softener sheets are used, a waxy substance will eventually coat the bars, so the dryer will not "see" that the clothes are still wet, and go right to a cool down. Clean them off, or use time dry only.
Jan 17, 2011 | LG DLE2512W Electric Dryer
What size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
How to remove rear seat back 1987 mustang convertable?
Tools Required:
  • 3/8 inch Drive Ratchet
  • 3/8 inch Drive 3” Extension
  • 3/8 inch Drive 10mm Socket
  • 3/8 inch Drive 13mm Socket
  • T-50 Torx Bit
  • 1/4 inch Allen Wrench
  • 3/16 inch Allen Wrench
  • 1/2 inch Wrench
  • Drill Motor
  • 1/8 inch Drill Bit
  • 5/16 inch Drill Bit
  • 2 inch Hole Saw
  • Trim Tool (Fork Tool)
  • Electrical Tape
  • Center Punch
  • Hammer
------------------- Installation:
Remove Back Seat:
  1. Locate the retainers securing the seat bottom into the vehicle, approximately 10 inches from the end of the cushion, either side. Use your thumb to push in retainer release tab. Lift the seat up to remove.
  2. Remove the two 13mm screws securing the seat back, located on each lower corner. Lift seat upward to release seat back from brackets at the top. You can carefully prop the seat back under the retracted top , use caution if choosing this method not to damage or scratch the vinyl of the seat. You can remove the seat from the vehicle completely by disengaging the flanges securing the top of the rear seat to the fabric of the convertible top well .
  3. Remove Quarter Trim Panels:
    1. Grip the Quarter Trim Panel Cap at the shoulder strap opening and lift up to dislodge the retaining clips.
    2. The inside Quarter Trim Panels are two-piece panels. Remove the upper portion of the Quarter Trim Panel from the vehicle; it is not necessary to remove the lower portion. Pull the forward edge of the trim Panel over the pinch weld in the doorjamb.
    3. Use a Door Trim Tool (Fork Tool) to dislodge the pushpin retainer at the rear edge of the Trim Panel approximately 4” down from the top, pry Trim Panel toward the outside of car to release retainer.
    for more help click this link directly
    1. http://www.americanmuscle.com/05-07-lightbar-install.html ---------
Oct 05, 2009 | 1987 Ford Mustang
The left side of the scren is missing
Try to replace the Logic board first to see it is fixed or not.
Dec 30, 2007 | Philips 50PF9830A 50 in. Plasma HDTV
NEC PlasmaSync 50MP2 50 in. Television Logo
282 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
