Question about Sco UnixWare 7 for Unix
Unix what's details of files ystem
    Brigadier General:
  • 10,406 Answers
Nice try! Find an upper-class student to give you one-on-one tutoring with your homework.
Posted on Dec 02, 2009
Disk full how do i delete
First delete the temporary files.
On unix you can use rm command in folder "/tmp" or "/var/tmp".
On windows, open Internet Explorer and go to menu Tools-->Internet Options and in "General" tab under "Browsing History" block delete the temporary files. This will give you some breathing space to work with other applications. Then open a file manager like "Windows Explorer" (for unix you can find similar applications). Look for the files which you don't need anymore and delete them. You can even move some of the big files onto your external drive connected to the system via usb cable.
Hope this helps.
Feb 09, 2014 | Computers & Internet
I cant play the video
Your thought waves are being blocked by a large pile of Alien toilet roll holders. So I am unable to read your mind. What is the problem????? Give us some details, is it a video file? Is it a DVD? are you using VLC to play it or are you trying to watch it on a Unix media player?
Aug 12, 2013 | Gigabyte GA-6VEML Motherboard
The logic card of my TallyGenicom 6312L line printer has been repaired. it is not working on Unix OS but working in Windows envirinment. what is the solution?
The solution depends very much on the cause of the problem. I note that you can print from Windows, this indicates the intrface you are using is functioning correctly and it should therefor be possible to print from Unix to the same interface if it is connected to the Unix system. If the printer is connected via a network interface, check the IP address on the printer to ensure it matches the IP address set up for the Unix print queue. Try pinging the printer from Unix. Ensure the EMULATION setting on the printer matches the Device Type selected on Unix. You may need to identify if any data is being sent for Unix perhaps try sending a test text file to the printer. A common cause for printers not printing from Unix is no Carriage Returns or Line Feed commands in the data. Try setting Auto CR to ON in the printer, of this does not work try setting Auto LF to on. If there is still a problem please post the connection method and also any errors or symptoms seen when printing from Unix
Sep 27, 2011 | TallyGenicom 6312 Matrix Printer
How to install unix sco kindly give full details
start the computer with the Unix disk in the drive.
Choose the option to run unix without installing to the pc.....(this runs without a HDD>Itll take some time but let it install all the way, and as system is fully running..Choose "install unix " from the drop down menu.
After installation, eject the cd and set up to boot from the HDD.
Jan 27, 2010 | Apple OSX 10.3 for Unix, Mac
Symantec Scan engine sees nothing wrong with eicar test files
in a command line? it looks like you did not put the path of the eicar file that you're scanning...
Aug 11, 2009 | Symantec AntiVirus Scan Engine 3.0 Upgrade...
I am in new in unix operating system please suggest me
Try these links
http://www.debianhelp.co.uk/commands.htm
http://www.linuxlots.com/~jam/guide4.html
http://tldp.org/LDP/Linux-Filesystem-Hierarchy/html/
You will be familier with linux once you understand the files system...
Mar 01, 2009 | Sun Computers & Internet
Unix
Improving UNIX server performance NOTES.INI settings Most NOTES.INI settings that affect IBM® Lotus® Domino® server performance apply to all UNIX® platforms.
NSF_Buffer_Pool_Size_MB Many machines that run UNIX have very large amounts of physical RAM. Use the parameters NSF_Buffer_Pool_Size_MB or PercentSysAvailable Resources to control how much memory Domino is allowed to use. Each Domino instance on a UNIX machine can reference a maximum of 4GB of RAM.
Disk and memory requirements When a UNIX system runs Domino server software, the server must have enough disk space for program and data files and enough memory to handle swapping and the number of processes. You can also change several system parameters to improve server performance.
Disk I/O tuning Maintaining multiple file systems for operating system files, swap space, transaction logs, and data improves overall server performance.
Use RAID 0+1 hardware for the disk drives on which the data files reside. Use multiple smaller disk drives instead of a few large disk drives for Domino data. Domino does not perform simple predictable sequential reads; therefore, disable Read Ahead Cache and enable Write Cache.
Keeping swap space on its own separate striped volumes improves server performance at high loads. The transaction logs should always be on the most reliable and highest performing disk subsystem available to the system hosting the Domino server. Transaction logging must be on its own disk drives for improved server restart time, reliability, and availability. The logged transactions are written to disk as fast serial writes to a sequential file that is of configurable size in 4K blocks.
Console and database logging To improve server performance, limit the amount of information that is logged to the log file (LOG.NSF) and the console.
Feb 21, 2009 | Computers & Internet
Hi!!!!! I hav installed UNIX os in 1 drive..... Now the other three drives showing some problem .... So with out any harm of data to unix drive.....i can re-installation for the other three or not
I would suggest using a "Live" Unix system disk to fix the file system problem. Sometimes file system locking by the host operating system will cause problems accessing secondary HDDs. Try the free Knoppix system (www.knopper.net), this system works from a CD so that you have complete access to all of your drives. Use this to move/copy/save data so that the drives with problems can be formatted/reallocated.
Jan 04, 2009 | Computers & Internet
Create DVD with roxio on windows 2000 machine. Put DVD in unix box and all files have read only permissions for owner, group and world. No execute permissions for any file. Create CD and there is no...
Good day
The reason for this is, that the files on a dvd or cd are always read only, unless the dvd or cd is re writeble, you have to change the attributes for the files from read only to archive after you have copied them to the machine
Unfortunatly I do not know what the Unix command for this is
Hope this helps you
Regards
May 23, 2008 | Computers & Internet
Sco UnixWare 7 for Unix Logo
74 people viewed this question
Top Sco Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Sco Computer and Internet Expert? Answer questions, earn points and help others
