Question about Sony Audio Players & Recorders
We have a Sony Trinitron and a Sony STR-K670P. We use to have it hooked up to a DVR, but now we went down to basic cable. I can't seem to get sound to come through my surround system. Any advise out there? PLEASE!!
  • Anonymous Mar 28, 2014
    sound does not come on my headphones
    Problem Solver:
  • 6 Answers
If your trying to use the dvr still your probably not connecting it all properly. make sure that. having a sony trinitron you have alot of connections on the back. if you connect all of the accessories that you have on your tv directly into each input and use the tvs main output connection to connect straight to your surround sound. this should fix your problem. plus you wont have a bunch of stuff hooked up to your surround sound receiver
Posted on Feb 21, 2009
  • 10,594 Answers
Hook RCA audio cord at TV audio out terminal at rear of TV and put it in to AUX or any free input of Sony receiver. Select that input in receiver and get sound of TV.
  • Shahid Electronics
    Shahid Electronics Feb 21, 2009
    Let me know if you need further help. I need to know bit details of problem.
How do connect Sony audio receiverstr-k670p to Samsung smart tv?
Both should have an optical audio jack. Easiest way to hook the two together
Jul 28, 2015 | Sony Str-k670p
Model Sony KV-G21q2S Problem-STR 6707 has been changed. After an hour the went down. The fuse and STR 6707 are working. But no picture no sound. When plug in it gives "boo" sound for few...
This is the SMPS Power suply drive and the IC fails ONLY if there is fault in the circuit. You need to check on the SMPS section
check this link below for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Next you need to check if the LINE output transformer has failed. If so this will have a higher current drain and so switch off the SMPS unit. check for the EHT drivers, capacitors in the HT circuit.
Jun 25, 2011 | Sony FD Trinitron WEGA KV-20FS120 20" TV
I have an HD PVR (Explorer 8300) and have connected to my Samsung TV using HDMI cable. My question is can I connect my SONY STR DE605 receiver or do I need a new one?
Depending on your tv output, you shpuld be able to hook your TV to receiver via audio output. Running your video components through your receiver will not give you the best performance anyway. Run your HD DVR to TV the way you have it then, if it's possible to run audio out from TV, via, RCA, digital optical, etc., to your receiver. The sound will be transfered through the TV. You may also be able to utilize component out from your HD DVR and a separate audio cable.
May 22, 2011 | Sony STR-DE605 Receiver
I have Sony STR-DH810 Hook up PS3 and Comcast HD Dvr with HDMI. I have Mitsubishi wd-65733 DLP TV. When I am playing my ps3 the screen keeps flickering black more and more until it goes completely black...
I had this problem. If not exact very similar. My video would look like snow for a brief moment, then go black. It was basically loosing sync I believe. I swapped HDMI cables with another component, which resolved the issue. So the issue was bad / cheap HDMI cables. I've since replaced the one, and look to buy slightly better cables. no need to break the bank, just don't go el cheapo. The ones that work great were only $9.99 at Fry's Electronics.
May 18, 2010 | Sony Audio Players & Recorders
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
No sound coming from Sony Receiver STR-DG510?
Sounds like you are pretty close with this one. If you select fm tuner do you get audio. If not you may have the speakers on the wrong a-b setting. Make sure the audio from your cable box is not muted or turned down.
Mar 15, 2009 | Sony STR-DG510 Receiver
Sony trinitron XBR2 32 " can't seem to get the cable working on it
You can hook up to either aux or vhf not converter. then with remote use ant button to select the one you are connected to. then do the auto search. Also can you get to 3 by pushing 3 and ent on the remote?
May 18, 2008 | Televison & Video
No sound from digital out on PS3 using optical cable
Does the end of the optical cable glow red when hooked up to your PS3 while the PS 3 is powered on? Look at it without the cable plugged into the STR-D845.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
562 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
