Question about Compaq NC6000 Notebook
I have a NC6000 that will turn on the screen for about 2 seconds during boot-up. everything else seems to work ok-- it aquires a wireless link but the screen is dead. If I turn it off and back on rhe same 2 sec. turn off happens. Is it the Power Supply, Inverter or Motherboard? All help is greatly appreaciated. Scott
    President:
  • 2,653 Answers
Usually it's in this order. Inverter, lcd / backlight, gpu
A local repair shop would be able to confirm which one. Or you can just order a replacement from ebay for about 10-15 and try replacing it yourself. It's not hard.
Posted on Feb 21, 2009
  • 233 Answers
I think the problem is on the backlight (small neon bulb on the LCD). because if the problem in the inverter, there will be no light on the lcd at all.
Posted on Dec 17, 2009
Computer shuts Down during boot up
I will need to know at which stage of the boot up it shuts down for example can you see the windows logo? If you can get as far as the windows logo. Turn your pc on and hold f8 after the bios screen.
Oct 20, 2012 | Dell Computers & Internet
Broadcom 802.11b/g Wlan adapter Everything works except it gets stuck on aquiring network adress. Everything is on auto-detect. I get good signal strength from the router. I accessed the gateway fine...
Hi
This Error will come with two condition:1) your ip is conifg and 2) your DHCP server is off.
Check this both and let me know if u get same error again
May 11, 2011 | Socket Go WIFI 80211ABG Sdio Wlan...
My HP nc6000 wont start when I press power button. Fan starts for a few seconds an then the orange led turns on, after that everythig turns off. AC an the battery is ok. Any idea? Thak you.
Hi,these particular brand of Hp series is very problematic,try checking the Ram out,its usually underneath the keyboard,so if you have two installed try using one at a time to boot system,if problem persist have an I.T Technician look at it.
Dec 31, 2010 | HP Compaq nc6000 Notebook
Hi my compaq nc6000 laptop is not working properly. if the wireless is turned on a blue screen with the instruction irql_not_less_or_equal appears. if the wireless is turned off no problem the laptop...
Guest
In regards to getting the "irql_not_less_or_equal" BSOD this can be related to several things. You could be having a driver problem or a hardware related problem. To know exactually what your problem is we need to look at the stop code you are getting as well. The link below will show you what number I need to see exactually where your problem is.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
http://www.fixya.com/users/issken
Jun 14, 2010 | Compaq NC6000 Notebook
Turn on Pc, Continually beeps 6 times then shuts down
it seems that your memory card is out of place. open the pc, reseat the memory, and that should be ok.
Jun 15, 2009 | Dell Dimension 3100 PC Desktop
Aquiring Network Connection over and over. RAWR
How many DHCP devices are there on the network?
There should be only one. Try disabling the DHCP in your device, then your neighbours router should issue IP addresses and all will be ok.
Apr 26, 2009 | NetGear WGR614 Wireless Router
HP compaq nc6000 Start up problems
cpu is getting over heated because the fan cooling it is slow or not working well or stopped . go into setup , see the cpu temperature, and fan speed , if normal , neglect the above cause.
change ram , use any other working ram .
battery may not be fully charged , or old battery.
battery faulty (current leakage or less working voltage or less current storage capacity,
use mains supply , if lap top is ok on mains supply then charging section or battery is faulty.
Aug 15, 2008 | HP Compaq nc6000 Notebook
Laptop can't aquire IP address
This sounds to be a compatibility issue with either the wireless software or wireless card. Check to see if there are any updated drivers for the wireless card at IBM's support site. If there aren't any or the card still doesn't work after the updated drivers are installed, then you might try a different/newer internal wireless card, or a universal external wireless card for use with your home system.
Jul 30, 2008 | IBM ThinkPad R51 Notebook
Cannot aquire IP address through my Desktop using Lynksis Wireless Router
what you do is to reboot your desktop and everything will be fine or either unplug or disable and enable the status of the connestion. But the best way is to reboot the system. Good luck
Jun 29, 2008 | D-Link (DI-784) Wireless Router
Compaq NC6000 Notebook Logo
153 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
