Question about Car Audio & Video
Playing the sound through the car stereo
I have a TV car dvd player #T1048DVFD. I would like to play the sound through the car stereo. I had another one that did this. Can you tell me if there is a way to do this?
    Top Expert:
  • Car Audio & ... Master
  • 77,499 Answers
There is a way, if your DVD player has audio/sound output jacks, here is what you need to do, have a set of RCA intput jacks intalled in your radio, any good car audio installation shop can do this, as to the cost I imagine around $100.00
Posted on Feb 21, 2009
    Genius:
  • 2,920 Answers
You should be able to run wiring to the speakers in the car to make it play through the car speakers. you would have to run the wires from the dvd player to the car speakers but yes you can do it
  • 10,594 Answers
Please connect dvd player audio out cable in to car stereo audio input and select Aux in car stereo to get sound.
  • 19,396 Answers
If you insert an audio cd , then the unit will only play sound.
  • Ginko
    Ginko Feb 21, 2009
    On any in car DVD player, if you play an audio CD, the DVD player will just play the music.
    If you want to listen to the radio you will need to add an in-car stereo with radio.
  • Ginko
    Ginko Feb 21, 2009
    If instead your problem is that you want to route DVD player audio signal through the already present stereo, that is a bit of a problem.
    Your DVD should already use same speaker system as in car stereo, and the audio signal from DVD is alrady amplified and cannot pass through the car radio input.
    The best thing to do in that case is buying and installing an amp into your car and connecting both units to the amp.
Why is there no sound when playing CD, but sound works when playing DVD?
Under settings in the DVD player go to the Audio.
Older CD's have formats that may not have the same digital format as newer DVD's. Set the audio output to PCM
Set the down mix mode if available:
To have the player downmix to normal stereo
Mark down the settings that you change. You may need to change them back for best DVD playback.
Jan 07, 2016 | Televison & Video
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
Jan 07, 2009 | Sony DAV-SB500W System
DVD sound a problem but is playing ok.
try changing your dvd audio settings to stereo
Nov 12, 2008 | Toshiba SD-2800 DVD Player
My DVD player will only play background sound not voices
Go to sound menu of dvd player and select Stereo sound and if surround is enabled, disable it.
You can get help from user manual of dvd player.
Nov 09, 2008 | Televison & Video
No sound when playing dvd or cd
  1. Check aux cables should be in Left and Right fornt speakers
  2. Check your dvd sound Settings under menu mka sure the downmix is stereo
Hope ths help
Jan 20, 2008 | RCA DRC220N DVD Player
No music from player #1 port
i have noticed that playing two player with the sound too.. my disk was dirty too.clean it first.. Second if your just playing through your T.V. well its prob mono.. or if your playing through a home audio/video check your audio rca's make sure there pluged in all the way. if you are using home stereo newer model you can use the fiber optic on your ps2 the sound is better make sure your stereo has the same thing or it would be a wasted trip to the store.
Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
Dvd "Highlander DVX4533 " no sound
sounds like it is set to 5.1 surround when you only have a stereo tv hooked up to it. In audio settings you will need to select 2 channel out.
Jul 29, 2007 | Proscan PS8600
No audio
FM station 88.1 or similar. Set radio to scan while dvd is playing. When the correct frequency is reached, you'll hear sound.
May 06, 2007 | Blaupunkt DVD-ME2 Car DVD Player
Car Audio & Video Logo
129 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
